Old 21-03-2005, 04:39 PM   #1 (permalink)
Default red hat 9 help..
i recently installed red hat 9 .. installation was fine.. but the problem is after logging in and typing startx, i get the error " no screens found" ...
i should tell u tht while config. graphics card in the setup, i used the "default" option coz my onboard card was not shown ( my mobo is asus k8-smx)
pls help..
prankzter is offline
Old 22-03-2005, 11:40 AM   #2 (permalink)
tuxfan's Avatar
Why use Red Hat 9? There are 3 versions after that and fourth one is about to come!! For customised distro based on Fedora Core 3 (Red Hat 12), buy the March 2005 issue of PCQuest
tuxfan is offline
Old 22-03-2005, 12:07 PM   #3 (permalink)
As tuxfan said, better try Fedora or another newer linux distro, the chance of your card being supported is more
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
ujjwal is offline
Old 23-03-2005, 12:42 PM   #4 (permalink)
if u have installed graphics like (gnome or kde) then use the following command
# redhat-config-xfree86
and follow the screen instruction ( please take very good care of it's resolution i,e horizontal and vertical if all of them fails then feed 30-50 for horizontal and 50-70 for vertical)
live life linux size
grub is offline
- by soumya
