Old 03-11-2007, 05:15 PM   #1 (permalink)
NBC(Next Bill Candinate)
100.dx's Avatar
Default Open Suse Some Problem Yaar
Hey I Install Open Suse Distributed By Digit This Month
When I Change My Wallpaper It Gives A White Wallpaper On My Desktop Whats The Problem
And I Wana Increase Boot Time Only 5 Seconds Suse Automatically Started I Wana Increase Time When I Computer Started I Dont Get Much To Choose Windows Aur Linux Plz Tell
And How Can Ii Configure My Modem In Open Suse
100.dx is offline
Old 03-11-2007, 05:44 PM   #2 (permalink)
bharat_r's Avatar
Default Re: Open Suse Some Problem Yaar
The answer for ur 2nd & 3rd question is YaST.
YaSt is the control center of Suse(like control panel of Windows).
Go to YaST->System->Boot Loader
Go to the Boot Loader Installation tab.Click on Boot Loader Options.Change the timeout to the desired value.
(See screenshots)
Or you can also make Windows as ur default OS.Just select windows,move it up & click on Set as Default.
bharat_r is offline
Old 07-11-2007, 08:40 AM   #3 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
On searching Net connection on Open Suse I found so may thread, but I am unable to solve my problem. Hence I decided to write in this thread instead of creating new thread.
I have installed Open Suse 10.3 from this month Digit DVD, just for leaning and take test of New OS. Now my most prefered thing is Net Connection, which I am unable to configure.
I have a BSNL BB conection through DSL Modem (LAN). Modem Model : Utstarcom(UT300R2U). Now what is the step by step procedure to configure the DSL connection. I tried my best to configure the DSL, but all are in vain.
After configuring it shows a icon at the status bar which indicated that "net connection is wired through eth0), but the icon is not glowing also not open any web sites.
Thanks is advance.
{{EXPERIMENT MAKES A PERSON EXPERT)
Dont know who says that.
________________________________________________
I like signature after 10 P.M.
skghosh44 is offline
Old 07-11-2007, 08:50 AM   #4 (permalink)
left this forum longback
praka123's Avatar
Smile Re: Open Suse Some Problem Yaar
need to use "yast" manager to configure pppoe connxn.then use kinternet shortcut for dialer.pls move this thread to opensource section.the solution is somewhere in oss section given by @nucleuscore.
MOD please move to OSS section.
you need to edit lilo/grub conffiles to increase waiting to boot seconds.
internal modems may not work in Linux as they are made for windows or "winmodems".
reg white screen,whats ya configuration.are ur graphics driver detected and installed.that all matters.
praka123 is offline
Old 11-11-2007, 09:57 PM   #5 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
How to access drive/folder/files etc in Linux Open Suse 10.3. like Ubuntu/kubuntu etc.
Old 11-11-2007, 10:08 PM   #6 (permalink)
TheSaint
NucleusKore's Avatar
This thread is all muddled. Please search the forums before posting
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 11-11-2007, 10:20 PM   #7 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
I think u dont know the answer. If u know the answer please provide the thread link here.
Old 11-11-2007, 11:35 PM   #8 (permalink)
TheSaint
Bridged mode on opensuse 10.3
Just remember to set your lan card to DHCP, and tick the enable device control for non root user via KInternet
To configure your boot manager
1. Open yast
2. System->boot loader
3. Select your default os and click set as default
4. Click on boot loader installation tab, and in that click on boot loader options, the last entry there is the countdown in seconds
Make you changes, click ok, finish
If you want me to attempt to fix your problem with your wallpaper you will have to type in English. I cannot follow what your problem exactly is. Its very irritating to decipher bad posts, as if I have nothing better to do in my life. Its not fashionable to type with spelling mistakes.
Old 11-11-2007, 11:48 PM   #9 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
[QUOTE]
Originally Posted by NucleusKore
I think you have not got my point. I have asked for "How to access windows OS DRIVE/FOLDER/FILES ETC" in Linus Open SUSE 1.03. What we can access automatically in Ubuntu/Kubuntu OS.
Old 12-11-2007, 12:46 AM   #10 (permalink)
TheSaint
[QUOTE=skghosh44]
Now I get your point, it would have really helped if you did not club your query in this thread. SuSe mounts all partitions at install, however, if you went for manual partitioning, then it would not have done anything automatically. Anyway, you will have to mount the windows partitions. The base filesystem is root or /, on which everything is mounted. Your home directory for example is mounted on root so that its location would read as /home. So you will have to specify a mount point, say /windows and mount your windows partitions there
1. Open Yast
2. Click Partitioner
3. You will get a warning, read it and click yes
4. Now you will see the fstab entries in partitioner. I have enclosed mine as an example. You will have to know which are your windows partitions, they will be ntfs or vfat.
5. Select the partition and click edit
6. This is what you'll see. The mount point has to be specified in the lower right hand corner
7. Click fstab options to configure further. As I have installed the ntfs-3g driver, mount as read only has not been ticked. Mountable by user has been ticked so that you do not have to become root and mount it every time you want to work on the drive.
8. After setting everything click ok, apply, finish
Old 12-11-2007, 07:57 PM   #11 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
@NucleusKore
Nice presentation, thnaks.
As per your guidelines while I was trying to do the same, I was unable to do the same, because the "fstab" is disable by default.
What is the wrong, I cant understand, I seek your help.
Old 12-11-2007, 09:22 PM   #12 (permalink)
TheSaint
That's funny. Do one thing. Press Alt+F2, type konsole and press enter. Type the following
cat /etc/fstab
and press enter. You will have to now provide me the output, there are two ways of doing it.
1. Select all text with your mouse, click Edit->Copy, and paste the output here
OR
2. Now in konsole, click Session->print screen-> and from that drop down list select pdf and click print
You will find the output in a file named print.pdf in your home folder. Copy paste those contents here.
Here is an example of mine:
neville@linux-nucleuskore:~> cat /etc/fstab
# /etc/fstab: static file system information.
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
proc    /proc   proc    defaults        0       0
sysfs   /sys    sysfs   noauto  0       0
usbfs   /proc/bus/usb   usbfs   noauto  0       0
devpts  /dev/pts        devpts  mode=0620,gid=5 0       0
/dev/disk/by-id/scsi-SATA_WDC_WD1600AABS-_WD-WMAP93914663-part8 /       ext3    acl,user_xattr  1       1
/dev/disk/by-id/scsi-SATA_WDC_WD1600AABS-_WD-WMAP93914663-part7 /ubuntu ext3    defaults        1       2
/dev/disk/by-id/scsi-SATA_WDC_WD1600AABS-_WD-WMAP93914663-part1 /windows/C      ntfs-3g defaults,user,users,locale=en_US.UTF-8 0       0
/dev/disk/by-id/scsi-SATA_WDC_WD1600AABS-_WD-WMAP93914663-part5 /windows/D      ntfs-3g defaults,user,users,locale=en_US.UTF-8 0       0
/dev/disk/by-id/scsi-SATA_WDC_WD1600AABS-_WD-WMAP93914663-part9 /windows/E      ntfs-3g defaults,user,users,locale=en_US.UTF-8 0       0
/dev/disk/by-id/scsi-SATA_WDC_WD1600AABS-_WD-WMAP93914663-part6 swap    swap    defaults        0       0
debugfs /sys/kernel/debug       debugfs noauto  0       0
/dev/fd0        /media/floppy   auto    noauto,user,sync        0       0
Old 13-11-2007, 07:38 PM   #13 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Please note I have during installation I have selected the GNOME desktop.
Here is the output of cat/etc/fstab
skg@skg:~> cat /etc/fstab
/dev/disk/by-id/scsi-SATA_ST380215A_9QZ1RTM3-part11 / ext3 acl,user_xattr 1 1
/dev/disk/by-id/scsi-SATA_ST380215A_9QZ1RTM3-part9 swap swap defaults 0 0
Old 13-11-2007, 08:00 PM   #14 (permalink)
TheSaint
Could you give me a screen shot of partitioner as in my third picture in the above post so that I can see all the partitions. As part 9 is swap and 11 is root, and you do not have a separate home partition, there should be another 5 or 6 partitions to mount.
If you find that difficult do the following:
1.Open Konsole or Xterm
2.Type su, press enter and become root
3.Give the following command at prompt
fdisk /dev/sda
and press enter.
4.Then type p (to print the partition table) and press enter
5.Then type q (to quit without saving changes)
6.Post the output here
Old 13-11-2007, 08:02 PM   #15 (permalink)
praka123's Avatar
@nucleuscore:better ask him to post the o/p of "fdisk -l"
praka123 is offline
Old 13-11-2007, 08:08 PM   #16 (permalink)
TheSaint
Yes that's far easier
Old 13-11-2007, 08:13 PM   #17 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
As desired here is the screenshot
Old 13-11-2007, 08:53 PM   #18 (permalink)
TheSaint
1. Make two new mount points in root. Open a shell, become superuser by su
2. cd /
3. For example,
mkdir windows
mkdir other
4.You will have to add the following lines to your /etc/fstab file.
/dev/sda1 /windows/C vfat defaults,user,users,umask=0002 0 0
/dev/sda5 /windows/D vfat defaults,user,users,umask=0002 0 0
/dev/sda6 /windows/E vfat defaults,user,users,umask=0002 0 0
/dev/sda7 /windows/F vfat defaults,user,users,umask=0002 0 0
/dev/sda8 /windows/G vfat defaults,user,users,umask=0002 0 0
And an optional
/dev/sda10 /other ext3 defaults 1 2
For that, better rename your old fstab file to something like old_fstab and note down the name somewhere, don't delete the file.
Copy paste its contents to an empty text file and add the above lines, and save it as fstab in etc folder. Note that unlike windows, no file extension is required here.
Reboot and check if you can see everything in your filesystem.
Post edited, see again
Old 13-11-2007, 10:12 PM   #19 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
As per your direction I have done everything but all are in vain. Still I am not able to access the drive/folder/ file etc.
I have make 2 dir viz. Windows and Other which are shown at Filesystems/windows, but the folder is empty.
Here is the screen shot of the edited file /etc/fstab
Old 13-11-2007, 10:20 PM   #20 (permalink)
praka123's Avatar
/dev/sda1 /windows/C vfat defaults 0 0
@skghosh44:Sir,do as above for all windows partitions.[b]make sure of the words being small or capital accdngly as its needed in linux.it will work though the permissions are for root to write.also make sure u have made those directories.as root in a terminal:
cd /
then
mkdir windows;cd windows
then
mkdir C D E F G
now,
mount -a
^^^check for any error messages,note that down if any and post here.
after mount -a ,open nautilus file manager and browse to /windows dir to see whether it is mounted or not.
edit for "other" dir,
 mkdir /other
praka123 is offline
Old 13-11-2007, 10:36 PM   #21 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
If I run the above command, err occured as under
bash: /dev/sda1: Permission denied
The dir made by me is "Windows" and "Other", I used the first alphabet as Capial.
Old 13-11-2007, 10:43 PM   #22 (permalink)
praka123's Avatar
edit ur /etc/fstab "windows" to "Windows" and do u remember u created root account while installing?unlike ubuntu(sudo),most other distros needs separate root password.u can press ALT+F2 in Gnome to get a run dialogue and run "gksu gedit /etc/fstab[/code] to edit it as root.
for mount -a,u need to open terminal run:
"su -" press enter;give root's password.and then run mount -a.
praka123 is offline
Old 13-11-2007, 10:58 PM   #23 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
@praka123
Now the "other" folder is working and I can access the "Kubundu" drive here.
But the "windows" folder is not working it is still empty. I make another folder viz "windows" and restarted the pc and also edit the /etc/fstab visa versa, but the "windows" or "windows" both are empty.
Old 13-11-2007, 11:05 PM   #24 (permalink)
praka123's Avatar
post no screenshot please.open terminal and post the o/p of "fdisk -l" here.u may need root permission(su) to do this.
praka123 is offline
Old 13-11-2007, 11:11 PM   #25 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Here is the o/p of fdist -l
skg:/home/skg # fdisk -l
Disk /dev/sda: 80.0 GB, 80026361856 bytes
255 heads, 63 sectors/track, 9729 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0xc42fc42f
Device Boot Start End Blocks Id System
/dev/sda1 * 1 2550 20482843+ c W95 FAT32 (LBA)
/dev/sda2 2551 9729 57665317+ f W95 Ext'd (LBA)
/dev/sda5 2551 5161 20972826 b W95 FAT32
/dev/sda6 5162 6439 10265503+ b W95 FAT32
/dev/sda7 6440 7511 8610808+ b W95 FAT32
/dev/sda8 7512 8119 4883728+ b W95 FAT32
/dev/sda9 8120 8180 489951 82 Linux swap / Solaris
/dev/sda10 8181 8803 5004216 83 Linux
/dev/sda11 8804 9729 7438063+ 83 Linux
Old 13-11-2007, 11:19 PM   #26 (permalink)
praka123's Avatar
  /dev/sda5  /windows/D  vfat   defaults 0 0
  /dev/sda6  /windows/E  vfat   defaults 0 0
  /dev/sda7  /windows/F   vfat   defaults 0 0
  /dev/sda8  /windows/G  vfat   defaults 0 0
  /dev/sda1  /other    ext3   defaults 0 1
^^^^^^does ur /etc/fstab looks like this?also the directories made are exactly the same-like windows/C ,windows/D etc?
try mounting after editing ur /etc/fstab entries as above.
praka123 is offline
Old 13-11-2007, 11:35 PM   #27 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
There is some difference what u described with mine.
/dev/sda5 /Windows/D vfat defaults,user,users,umask=0002 0 0
/dev/sda6 /Windows/E vfat defaults,user,users,umask=0002 0 0
/dev/sda7 /Windows/F vfat defaults,user,users,umask=0002 0 0
/dev/sda8 /Windows/G vfat defaults,user,users,unmask=0002 0 0
Old 13-11-2007, 11:36 PM   #28 (permalink)
praka123's Avatar
^then try mine.it works!no uid,gid mess.will post later on how u can have write access.make sure of the dir for windows,others made!
praka123 is offline
Old 14-11-2007, 08:22 AM   #29 (permalink)
TheSaint
Yes do note the case, what is in the fstab should be in the filesystem. If you could access the fstab button from partitioner its a lot easier. Do try again and see, select a windows partition in partitioner and click edit and see if you can access the fstab button
And I think i forgot to mention to create the C D E F G.........sheesh
You can also do that in GUI in nautilus provided you are superuser
Old 14-11-2007, 09:05 AM   #30 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
@ praka123
@ nucleusKore
Many Many thanks both of you,
Today I removed the Dir Windows/windows which was created yestarday and created created DIR as per praka123's recommendation as windows and then C D E F I and mount -a. But there was an error during mount -a. Unfortunately due to power failure my system gone off.
While restarted I go to filesystem/windows and found there C D E F G and I delighted there is all the windows files are present. Now I can share all the files/audio.video etc in Open SuSe.
Thanks again to u all for taking pains to solve the problem.
Will u solve another problem please. Some where in the Open suse I read that there is a option of dialer to connect the internet i.e "kinternet". Now how to configure it. I am tried my best to solve the problem but failed. When my system starts it displays err msg as under :
Presently I connect the net as under
Click double computer icon on the status bar then click "dial up connection" then "connect to BSNL vida DSL(dsl0).
Note that while I was 1st configured the DSL during that time name the service provider as "BSNL". Also note I have a BSNL Dataone connection.
Open Suse 10.2 problem antoniobc Open Source 5 20-10-2007 02:22 PM
need Open SuSE 10.2 DVD Garbage Open Source 9 15-07-2007 08:08 PM
- by soumya
