Old 02-11-2007, 09:53 PM   #1 (permalink)
Dark Star's Avatar
Question Manually setting Grub splash?
Help me manually setting grub I copied few files from Mac4 lin ver3 but the Startup manager did not set it up though it show the file and let me select but after I select and close the default Ubuntu spalsh again get set up To experiment I del Ubuntu splash by backing the file now I am not getting splash I mean blank screen how to set spalsh of Booting Windows Manually
Regards
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 02-11-2007, 11:31 PM   #2 (permalink)
sachin_kothari's Avatar
Default Re: Manually setting Grub splash?
If u still use ubuntu then this should help.
You will have to this from inside ubuntu.
I am currently using this splash screen.
sachin_kothari is online now
Old 03-11-2007, 09:00 AM   #3 (permalink)
Dark Star's Avatar
Baah.. I am not asking for splash screen parka ,vish, Ani and Qwerty plz help
Old 03-11-2007, 09:05 AM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
sachin_kothari was referring to the method mentioned in that release.
Installation:
Copy the file (*.xpm.gz) to e.g. /boot/grub/
(sudo cp *.xpm.gz /boot/grub)
Then add the following line to your /boot/grub/menu.lst:
splashimage=(hdx,x)/boot/grub/<filename>.xpm.gz
Change the (hdx,x) appropriately.
QwertyManiac is offline
Old 03-11-2007, 12:23 PM   #5 (permalink)
Dark Star's Avatar
I am asking about Boot splash screen not Grub which I copied inti /usr/lib/usplash wit .so as the ext file
Old 03-11-2007, 01:05 PM   #6 (permalink)
And Now
Your title says "setting Grub Splash" and now you are asking for boot splash.
May be this is what you want.
Last edited by sachin_kothari; 03-11-2007 at 01:06 PM. Reason: Automerged Doublepost
Old 03-11-2007, 01:24 PM   #7 (permalink)
Wire muncher!
infra_red_dude's Avatar
@Shashwat
The title is misleading. Anyways, here is what you are looking for: https://help.ubuntu.com/community/US...omizationHowto
It has not been tested by me so I can't give any guarantee that it'll work.
Before doing that you may try renaming the usplash theme you want to ubuntu-usplash.so or whatever the default name is and try.
infra_red_dude is offline
Old 03-11-2007, 01:38 PM   #8 (permalink)
Dark Star's Avatar
^^$hit my bad I was trying to say abut Boot and by mistake wrote Grub
Old 03-11-2007, 03:02 PM   #9 (permalink)
left this forum longback
praka123's Avatar
apt-get install splashy(debian way for boot splash)? or if gnome boot splash=>apt-get install gnome-splashscreen-manager
praka123 is offline
Splash Screen .. ? Help Dark Star Open Source 3 04-07-2007 11:25 PM
GRUB splash screen, 2 of those? aditya.shevade Open Source 14 28-02-2007 10:54 PM
Splash screen using VB.Net bizzare_blue QnA (read only) 8 11-04-2006 05:24 AM
BIOS splash digitizen Hardware Q&A 16 02-12-2005 04:52 PM
- by soumya
