Old 28-10-2007, 10:04 AM   #1 (permalink)
Proud to be Linux
abhinandh's Avatar
Default help!! gusty very slow.i think xgl prob
my intel 845 card ran feisty very smoothly and i also had compiz installed.
i upgraded to gutsy in morning and the video was very crappy and so slow
after a bit researching i found that gusty starts "xgl" by default on my card!!!!
how do i change it.
http://abhinandh.com
abhinandh is offline
Old 28-10-2007, 11:08 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: help!! gusty very slow.i think xgl prob
remove xserver-xgl package via synaptic.edit /etc/X11/xorg.conf accordingly to work with default Xorg AIGLX.
since i am on Debian,not sure with xserver-xgl is the package name.
also maintain minimum packages that are useful to you and remove/purge other packages during house keeping system.
praka123 is offline
Old 28-10-2007, 11:09 AM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Or maybe just disable Desktop Effects for the time being?
QwertyManiac is offline
Old 28-10-2007, 12:10 PM   #4 (permalink)
Proud to be Linux
abhinandh's Avatar
ok i removed the xgl package.but how yo configure xorg aiglx.i have no direct rendering now.
Old 28-10-2007, 02:01 PM   #5 (permalink)
praka123's Avatar
DRI is supported for sure for onboard intel,infact intel cards are best supported in Linux.if u can,paste ur /etc/X11/xorg.conf .
have ur net connxn ON,then apt-get update ,
u need to make sure u have xserver-xorg-video-i810 or xserver-xorg-video-intel installed and in xorg.conf u have to use that.
praka123 is offline
Old 28-10-2007, 02:34 PM   #6 (permalink)
Proud to be Linux
abhinandh's Avatar
heres my xorg.conf.both the packages you told are installed
# xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "Files"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "CoreKeyboard"
Option "XkbRules" "xorg"
Option "XkbModel" "pc101"
Option "XkbLayout" "us"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option "Device" "/dev/input/mice"
Option "Protocol" "ImPS/2"
Option "ZAxisMapping" "4 5"
Option "Emulate3Buttons" "true"
EndSection
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/input/wacom"
Option "Type" "stylus"
Option "ForceDevice" "ISDV4" # Tablet PC ONLY
EndSection
Driver "wacom"
Identifier "eraser"
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
Option "Type" "cursor"
EndSection
Section "Device"
Identifier "Intel Corporation 82845G/GL[Brookdale-G]/GE Chipset Integrated Graphics Device"
Driver "intel"
BusID "PCI:0:2:0"
EndSection
Section "Monitor"
Identifier "Philips 105S"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Intel Corporation 82845G/GL[Brookdale-G]/GE Chipset Integrated Graphics Device"
Monitor "Philips 105S"
DefaultDepth 24
SubSection "Display"
Modes "1280x1024" "1024x768" "800x600" "720x400" "640x480"
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
# Uncomment if you have a wacom tablet
# InputDevice "stylus" "SendCoreEvents"
# InputDevice "cursor" "SendCoreEvents"
# InputDevice "eraser" "SendCoreEvents"
EndSection
Old 28-10-2007, 02:57 PM   #7 (permalink)
praka123's Avatar
Smile Re: help!! gusty very slow.i think xgl prob
OK.
the best method is written in ur xorg.conf itself.
do a
if it errx,
replace with below xorg.conf -expecting that xserver-intel is installed.
also wacom tablet are u using?expecting not.
then restart gdm after replacing xorg.conf also,if X fails starting edit xorg.conf modes delete the 1280x entry.
# package.
Section "Files"
FontPath        "/usr/share/fonts/X11/misc"
FontPath        "/usr/share/fonts/X11/cyrillic"
FontPath        "/usr/share/fonts/X11/100dpi/:unscaled"
FontPath        "/usr/share/fonts/X11/75dpi/:unscaled"
FontPath        "/usr/share/fonts/X11/Type1"
FontPath        "/usr/share/fonts/X11/100dpi"
FontPath        "/usr/share/fonts/X11/75dpi"
  # path to defoma fonts
 FontPath        "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
       Load    "i2c"
       Load    "bitmap"
       Load    "ddc"
       Load    "dri"
       Load    "extmod"
       Load    "freetype"
       Load    "glx"
       Load    "int10"
       Load    "vbe"
EndSection
Driver "kbd"
EndSection
Driver "mouse"
EndSection
Section "Device"
Driver "intel"
BusID "PCI:0:2:0"
EndSection
Section "Monitor"
Option "DPMS"
EndSection
Section "Screen"
DefaultDepth 24
Depth           24
EndSubSection
EndSection
EndSection
a good read for later use:
http://www.linux.com/feature/118108
praka123 is offline
Old 28-10-2007, 03:36 PM   #8 (permalink)
Evil Genius
faraaz's Avatar
@Thread Creator: Just one small point I'd like to point out...ITS CALLED GUTSY GODDAMNIT! STOP SAYING GUSTY! ITS NOT A FREAKIN GIBBON WHO FARTS A LOT! FEISTY...THEN GUTSY! OKAY?
Thank you for listening...
Roses are #FF0000, Violets are #0000FF...All of my base are belong to you!
faraaz is offline
Old 28-10-2007, 03:54 PM   #9 (permalink)
Proud to be Linux
abhinandh's Avatar
sorry.mispelt it.
OK.
do a
if it errx,
hey that did'nt work.look like its an unsolved problem....
http://ubuntuforums.org/showthread.p...04#post3651004
guess i have to clean install gutsy
Old 29-10-2007, 04:09 AM   #10 (permalink)
praka123's Avatar
I dont think 845 chip is not running on gutsy.the thread u linked seems to do with latest intel 965,infact DRI may be enabled already for u.try above xorg.conf i pasted and run "glxgears" if available or in terminal :
glxinfo |grep render
edit:@abhinandh:do this.it seems gutsy does not install DRI by default.
sudo apt-get install libgl1-mesa-dri
^this will be the problem.
praka123 is offline
Old 30-10-2007, 07:49 AM   #11 (permalink)
Proud to be Linux
abhinandh's Avatar
Unhappy Re: help!! gusty very slow.i think xgl prob
hey heres the output
direct rendering: No (If you want to find out why, try setting LIBGL_DEBUG=verbose)
    GLX_ATI_pixel_format_float, GLX_ATI_render_texture
OpenGL renderer string: Mesa DRI Intel(R) 845G 20061017 x86/MMX/SSE2
and that libgl1-mesa-dri is installed
anyways waiting for the shipit cd to arrive.guess i have to reinstall.
hey look at this pic.think u would find it useful
Old 30-10-2007, 09:46 AM   #12 (permalink)
praka123's Avatar
guess u dont have to reinstall,format etc.that is for regular windows users to reinstall whenever any problem pops up.
@abhinandh:there are two drivers?
I'll suggest,u install: http://packages.ubuntu.com/gutsy/x11...org-video-i810
and try.
for that when internet is on,sudo apt-get update,
sudo apt-get install xserver-xorg-video-i810
or use synaptic manager after pressing "reload" select and install above driver if already not installed.
as of now,ur using the new driver from intel for mod-setting which is not what we want:
http://packages.ubuntu.com/gutsy/x11...rg-video-intel
Use my-given xorg.conf in #7 then edit
Section "Device"
Driver "i810"
BusID "PCI:0:2:0"
EndSection
I hope u already use the modified xorg.conf given #7
if u dont know how to edit as sudo,
press alt+f2 to get run dialog,inside run gedit as follows and replace with the xorg.conf given in .
gksudo gedit /etc/X11/xorg.conf
use "i810" instead of "intel" in device driver.
Also,restart gdm after editing the xorg.conf.
sudo /etc/init.d/gdm restart
or reboot.
praka123 is offline
Old 30-10-2007, 03:20 PM   #13 (permalink)
Proud to be Linux
abhinandh's Avatar
@praka123
looks like i pinpointed the problem.
/usr/lib/dri/i915_dri.so
why the hell is it loading i915 kern module and loading
/usr/lib/dri/i915_dri.so when i have /usr/lib/dri/i810_dri.so
i_810 driver is also giving a BAD V_BIOS CHECKSUM???
Old 30-10-2007, 07:45 PM   #14 (permalink)
praka123's Avatar
^i915 maybe the new driver.but tell me-does ur 3D works?
praka123 is offline
Old 31-10-2007, 09:52 PM   #15 (permalink)
Proud to be Linux
abhinandh's Avatar
no
anyways will boot fom fiesty live cd and see which module is being loaded.
Old 31-10-2007, 09:57 PM   #16 (permalink)
praka123's Avatar
Intel gfx are the one of the easiest and auto configured gfx cards.It seems weird.I think if u can,install linux-image-2.6.2xxx-686 or -386 instead of linux-image-generic.
praka123 is offline
Old 02-11-2007, 03:56 PM   #17 (permalink)
Proud to be Linux
abhinandh's Avatar
Talking Re: help!! gusty very slow.i think xgl prob
hey i just reinstalled all the xorg and bang i got direct rendering!!!!
wish me happy compiz --repalce.
all hail ubuntu.
@praka123 : thank you very much for all your guidance and good luck
Old 03-11-2007, 11:40 AM   #18 (permalink)
praka123's Avatar
yeah.am doubting how come intel onboard gfx not supported?OK
praka123 is offline
Clock getting slow everyday by few mins !! plus more prob zero Hardware Q&A 9 23-07-2007 03:58 AM
New PC - IDE too slow Sukhdeep Singh Hardware Q&A 9 03-06-2007 02:55 AM
Very Slow N70 Manshahia Mobiles and Tablets 4 22-12-2006 03:11 PM
Pc Fan prob.(Pls help this interesting prob.) Ishan Hardware Q&A 4 24-01-2006 09:38 AM
Why is my pc slow??? nishantv2003 QnA (read only) 25 26-05-2005 04:26 PM
- by soumya
