Old 28-10-2007, 05:45 PM   #1 (permalink)
Mclaren F1 Long tail
aneesh kalra's Avatar
Default Compiz problems
Recently I installed 3d desktop and 3d chess from the synaptic package manager but it did not work so I proceeded as per the instructions on the compiz page in ubuntu ;i.e;by adding third party repositories and then installing them.Now when i go to the compiz settings manager it doesn't open.Please help i am using ubuntu fiesty fawn.
Ok here is the error message that I get on typing ccsm in terminal
"no python found but don't worry its an optional component ".I installed python 2.5 from synaptic but I am still getting the same old error message.
Computers are like air conditioners. They work fine until you start opening windows.
Last edited by aneesh kalra; 28-10-2007 at 05:45 PM. Reason: Automerged Doublepost
aneesh kalra is offline
Old 02-11-2007, 11:14 AM   #2 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Default Re: Compiz problems
Even I'm facing the same problem. Decided to Mint though
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 02-11-2007, 12:19 PM   #3 (permalink)
18 Till I Die............
It's solved after updates. I believe it was solved when we were discussing on IRC.
http://www.bash.org/?258908
mehulved is offline
Old 19-11-2007, 02:47 PM   #4 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
sorry for bumping this not-so-old thread.
I installed gutsy gibbon a few days ago.I thought compiz fusion would be activated by default but it isn't.I tried preferences-->appearance-->Visual effects-->normal/extra but it shows "Desktop effects could not be enabled".What am I missing?
I tried
sudo apt-get install compiz compizconfig-settings-manager
it shows:compiz is already the newest version.
E: Couldn't find package compizconfig-settings-manager
what is the problem?
BTW I have a c2d processor,intel 946gzis mobo,512mb ddr2 RAM,and all the other normal stuff.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 19-11-2007, 02:58 PM   #5 (permalink)
Think Zen.
ray|raven's Avatar
perhaps dri isnt enabled?
Regards,
ray
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 19-11-2007, 03:02 PM   #6 (permalink)
^please be a lil more elaborative.what is dri?and how do I enable it if it is disabled?
BTW I am on a clean gutsy install.
Old 19-11-2007, 03:28 PM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
Try:
sudo apt-get install xserver-xorg-video-intel
Harsh J
www.harshj.com
QwertyManiac is offline
Old 19-11-2007, 03:31 PM   #8 (permalink)
root@edubuntu:/home/ravi# sudo apt-get install xserver-xorg-video-intel
Reading package lists... Done
Building dependency tree
Reading state information... Done
xserver-xorg-video-intel is already the newest version.
xserver-xorg-video-intel set to manual installed.
0 upgraded, 0 newly installed, 0 to remove and 23 not upgraded.
Old 19-11-2007, 03:35 PM   #9 (permalink)
try installing restricted drivers for ur gfx card
SunnyChahal is offline
Old 19-11-2007, 03:38 PM   #10 (permalink)
^no graphic card...only onboard gma 3000 graphics with 128mb of dedicated video memory.
Old 19-11-2007, 04:00 PM   #11 (permalink)
Think Zen.
ray|raven's Avatar
dri - Direct Rendering Infrastructure
To know whether dri is enabled try this,
glxinfo | grep direct
and post output here.
Regards,
ray
Old 19-11-2007, 04:08 PM   #12 (permalink)
output:
direct rendering: Yes
Old 19-11-2007, 04:19 PM   #13 (permalink)
Think Zen.
ray|raven's Avatar
Hmm,dri is enabled.
i cant think of anything else that might be the reason for compiz effects being disabled.
Btw,did the effects work when u used the live-cd?
Regards,
ray
Old 19-11-2007, 04:41 PM   #14 (permalink)
dint try.
Old 19-11-2007, 06:23 PM   #15 (permalink)
Commander in Chief
X3100 is blacklisted hardware but X3000 is not, I don't understand what's going wrong
Try starting compiz from CLI and see if it says some unique error?
Harsh J
www.harshj.com
Old 19-11-2007, 06:29 PM   #16 (permalink)
left this forum longback
praka123's Avatar
DRI is enabled.then it is,a problem with compiz i suppose.also ur video ram set value in BIOS is good.
also,do u have "sudo apt-get update && sudo apt-get upgrade" done?
and hope u got all entries in ur /etc/apt/sources.list.for reference,i am posting mine for gutsy 7.10 below:
deb cdrom:[Ubuntu 7.10 _Gutsy Gibbon_ - Release i386 (20071017)]/ gutsy main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
#Repository List based on standard gutsy with many extra packages
# If you get errors about missing keys, lookup the key in this file
# and run these commands (replace KEY with the key number):
#  gpg --keyserver subkeys.pgp.net --recv KEY
#  gpg --export --armor KEY | sudo apt-key add -
# If you have a gpg key URL use (replace URL with the key address):
#  wget -q URL -O- | sudo apt-key add -
# If you have a gpg key file use (replace FILE with the key file):
#  sudo apt-key add FILE
deb http://archive.ubuntu.com/ubuntu/ gutsy main restricted
deb-src http://archive.ubuntu.com/ubuntu/ gutsy main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://archive.ubuntu.com/ubuntu/ gutsy-updates main restricted
deb-src http://archive.ubuntu.com/ubuntu/ gutsy-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
deb http://archive.ubuntu.com/ubuntu/ gutsy universe
deb-src http://archive.ubuntu.com/ubuntu/ gutsy universe
deb http://archive.ubuntu.com/ubuntu/ gutsy-updates universe
deb-src http://archive.ubuntu.com/ubuntu/ gutsy-updates universe
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://archive.ubuntu.com/ubuntu/ gutsy multiverse
deb-src http://archive.ubuntu.com/ubuntu/ gutsy multiverse
deb http://archive.ubuntu.com/ubuntu/ gutsy-updates multiverse
deb-src http://archive.ubuntu.com/ubuntu/ gutsy-updates multiverse
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://archive.ubuntu.com/ubuntu/ gutsy-backports main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ gutsy-backports main restricted universe multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository. This software is not part of Ubuntu, but is
## offered by Canonical and the respective vendors as a service to Ubuntu
## users.
deb http://archive.canonical.com/ubuntu gutsy partner
deb-src http://archive.canonical.com/ubuntu gutsy partner
deb http://security.ubuntu.com/ubuntu gutsy-security main restricted
deb-src http://security.ubuntu.com/ubuntu gutsy-security main restricted
deb http://security.ubuntu.com/ubuntu gutsy-security universe
deb-src http://security.ubuntu.com/ubuntu gutsy-security universe
deb http://security.ubuntu.com/ubuntu gutsy-security multiverse
deb-src http://security.ubuntu.com/ubuntu gutsy-security multiverse
# Seveas’ packages (GPG key: 1135D466)
# GPG key-file: http://mirror.ubuntulinux.nl/1135D466.gpg
deb http://mirror.ubuntulinux.nl gutsy-seveas all
deb-src http://mirror.ubuntulinux.nl gutsy-seveas all
# Medibuntu - Ubuntu 7.10 "gutsy gibbon"
# GPG key-file: http://packages.medibuntu.org/medibuntu-key.gpg
deb http://packages.medibuntu.org/ gutsy free non-free
#deb-src http://packages.medibuntu.org/ gutsy free non-free
# Debuntu Ubuntu gutsy packages
# GPG Key: http://repository.debuntu.org/GPG-Key-chantra.txt
deb  http://repository.debuntu.org/ gutsy multiverse
#deb-src http://repository.debuntu.org/ gutsy multiverse
praka123 is offline
Old 19-11-2007, 08:03 PM   #17 (permalink)
err....its gma3000 not x3000.I will buy a dedicated graphic card in december end(after the end term exams).
@praka123:yes I have all the updates installed.And there is no option for video ram in my bios...I guess its fixed or something.
here is my sourcelist file
# deb cdrom:[Ubuntu 7.10 _Gutsy Gibbon_ - Release i386 Binary-1 (20071016)]/ gutsy main restricted
deb http://in.archive.ubuntu.com/ubuntu/ gutsy main restricted
## distribution.
deb http://in.archive.ubuntu.com/ubuntu/ gutsy-updates main restricted
## team.
deb http://in.archive.ubuntu.com/ubuntu/ gutsy universe
deb http://in.archive.ubuntu.com/ubuntu/ gutsy-updates universe
## security team.
deb http://in.archive.ubuntu.com/ubuntu/ gutsy multiverse
deb http://in.archive.ubuntu.com/ubuntu/ gutsy-updates multiverse
## repository.
# deb http://in.archive.ubuntu.com/ubuntu/ gutsy-backports main restricted universe multiverse
# deb-src http://in.archive.ubuntu.com/ubuntu/ gutsy-backports main restricted universe multiverse
## users.
# deb http://archive.canonical.com/ubuntu gutsy partner
# deb-src http://archive.canonical.com/ubuntu gutsy partner
Old 19-11-2007, 08:50 PM   #18 (permalink)
Proud to be Linux
abhinandh's Avatar
hey,
in terminal give the command
compiz --replace
and post the output.
http://abhinandh.com
abhinandh is offline
Old 19-11-2007, 08:51 PM   #19 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
Yes there are many problems with Intel's onboard chipset (involving compiz) it seems. here take a look at these links. Hope it helps
http://wiki.compiz-fusion.org/Hardware/Blacklist
http://ubuntuforums.org/showthread.php?t=48849
https://bugs.launchpad.net/ubuntu/+s...iz/+bug/152226
FilledVoid is offline
Old 19-11-2007, 09:02 PM   #20 (permalink)
Originally Posted by abhinandh
hey,
compiz --replace
here is the output
Checking for Xgl: not present.
Blacklisted PCIID '8086:2972' found
aborting and using fallback: /usr/bin/metacity
thanks mate.The very first link is useful I tried
SKIP_CHECKS=yes compiz
it forced compiz but it is pretty buggy(on my system of course).Even the berly effects in linux mint were better than this.
root@edubuntu:/home/ravi# SKIP_CHECKS=yes compiz
SKIP_CHECKS is yes, so continuing despite problems.
Checking for texture_from_pixmap: not present.
Trying again with indirect rendering:
Checking for texture_from_pixmap: present.
Checking for non power of two support: present.
Checking for Composite extension: present.
Comparing resolution (1152x864) to maximum 3D texture size (2048): Passed.
Checking for nVidia: not present.
Checking for FBConfig: present.
Starting gtk-window-decorator
/usr/bin/compiz.real (core) - Warn: SmcOpenConnection failed: Authentication Rejected, reason : None of the authentication protocols specified are supported and host-based authentication failed
/usr/bin/compiz.real (video) - Warn: No 8 bit GLX pixmap format, disabling YV12 image format
now as soon as I close this terminal window my system almost halts(all messy).Looks like I'll have to live without compiz.
Last edited by The_Devil_Himself; 19-11-2007 at 09:06 PM. Reason: Automerged Doublepost
Old 19-11-2007, 09:02 PM   #21 (permalink)
Proud to be Linux
abhinandh's Avatar
Thumbs up Re: Compiz problems
your card has been blacklisted due to lack of drivers.[Intel 965 (X3000, X3100)]
to remove the blacklist give the following in terminal
mkdir -p ~/.config/compiz/ && echo SKIP_CHECKS=yes >> ~/.config/compiz/compiz-manager
now give the following
 compiz --replace
NOTE: YOU MAY HAVE VIDEO INSTABILITY.TRY IT AND SEE.THERE'S NO HARM.
Old 19-11-2007, 09:08 PM   #22 (permalink)
^âlready done.Check my last post.
Old 19-11-2007, 09:09 PM   #23 (permalink)
praka123's Avatar
@devilerhaps getting latest intel driver and building kernel module helps! i mean for 965 onboard.remember that i havent tried
http://intellinuxgraphics.org/documentation.html
bookmark this page for "new features and driver support" on latest kernels.
http://kernelnewbies.org/LinuxChanges
praka123 is offline
Old 19-11-2007, 09:15 PM   #24 (permalink)
Proud to be Linux
abhinandh's Avatar
guess you have to wait for driver support
Old 19-11-2007, 09:15 PM   #25 (permalink)
i don't have 946\x3000 guys I have 946\gma3000.
Thanks for the links praka bookmarked!!!.Anyways I am getting 8600gt next month then there won't be any problem.Damn these intel onboards.
Old 19-11-2007, 09:19 PM   #26 (permalink)
praka123's Avatar
intel onboard gfx is one of the best supported in Linux.drivers are opensource too.I think compiz is playing foul here,not ur kernel drivers. as DRI too is enabled.
praka123 is offline
Old 19-11-2007, 09:20 PM   #27 (permalink)
Proud to be Linux
abhinandh's Avatar
i just read that beryl works.
one more thing..... try setting your video driver to "intel" in xorg.conf.
its the new driver.
Old 19-11-2007, 09:21 PM   #28 (permalink)
^a nearly complete noob here abhinandh so please give full steps on how to do it.
Old 19-11-2007, 10:05 PM   #29 (permalink)
Commander in Chief
Find the block called Devices under /etc/X11/xorg.conf file which goes like, for example:
Section "Device"
        Identifier      "Generic Video Card"
        Driver          "nvidia"
        Busid           "PCI:1:0:0"
        Option          "AddARGBVisuals"        "True"
        Option          "AddARGBGLXVisuals"     "True"
        Option          "NoLogo"        "True"
EndSection
Set whatever that driver string holds, as intel.
Harsh J
www.harshj.com
Old 19-11-2007, 10:13 PM   #30 (permalink)
Section "Device"
	Identifier	"Intel Corporation 82946GZ/GL Integrated Graphics Controller"
	Driver		"intel"
	BusID		"PCI:0:2:0"
EndSection
Section "Monitor"
	Identifier	"Z19W"
	Option		"DPMS"
EndSection
Section "Screen"
	Identifier	"Default Screen"
	Device		"Intel Corporation 82946GZ/GL Integrated Graphics Controller"
	Monitor		"Z19W"
	DefaultDepth	24
	SubSection "Display"
		Modes		"1440x1440" "1440x900" "1280x1024" "1280x800" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
	EndSubSection
Seems ok to me.
Compiz on Suse 10.3? Dark Star Open Source 12 30-10-2007 08:22 PM
Compiz Fusion 0.6.2 Dark Star Open Source 2 19-10-2007 10:27 PM
Compiz-Beryl merger:compiz-fusion-arrives praka123 Open Source 16 22-06-2007 12:20 AM
Compiz Fusion, The new name for Berly/Compiz creation!. Dark Star Open Source 2 21-06-2007 11:15 AM
What is Compiz with COW? hailgautam Open Source 4 08-03-2007 10:27 AM
- by soumya
