Old 24-10-2007, 05:41 PM   #1 (permalink)
Dreamweaver
Gigacore's Avatar
Default I wanna edit my GRUB. . help me.
Hi guys, i've Windows XP and Linux Mint installed on my machine. By default Linux Mint is in the first line of the GRUB boot loader as usually. . and windows xp is at the last. . .
How to place XP in the First Line?
How can i edit this boot list. . . just like we do in BootConfig in Windows is there any way to re-arrange this list.?
Gigacore is offline
Old 24-10-2007, 05:44 PM   #2 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
Default Re: I wanna edit my GRUB. . help me.
Post your menu.lst here (preferably in [code] tag), Its just a matter of changing the order of the Entries in the file.
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 24-10-2007, 05:50 PM   #3 (permalink)
Dreamweaver
Gigacore's Avatar
Well,
* Linux Mint, Kernel 2.6.20-15-generic
* Linux Mint, kernel 2.6.20-20-15-generic(recovery mode)
* Linux Mint, memtest86+
* Other Operating Systems:
* Microsoft Windows XP pro
note: each * represents one line
Gigacore is offline
Old 24-10-2007, 06:05 PM   #4 (permalink)
[xubz]'s Avatar
Well, Um.. I meant /boot/grub/menu.lst
If you open that as root, you'll see that Windows XP is at the Dead bottom of the file. Just Put it on top of the Linux Mint Entries. That should probably do.
[xubz] is offline
Old 24-10-2007, 06:12 PM   #5 (permalink)
Dreamweaver
Gigacore's Avatar
^ bro, the file is read only, what shall i do now?
Gigacore is offline
Old 24-10-2007, 06:19 PM   #6 (permalink)
18 Till I Die............
You need to edit it as root.
sudo nano -w /boot/grub/menu.lst
Just change the line
default 0
to
default 4
http://www.bash.org/?258908
mehulved is offline
Old 24-10-2007, 06:22 PM   #7 (permalink)
Dreamweaver
Gigacore's Avatar
oh thanks for that bro. . . i'll check it later . . . we have a power cut here
Gigacore is offline
Old 24-10-2007, 06:42 PM   #8 (permalink)
left this forum longback
praka123's Avatar
@mehulved's solution makes ur grub waits n seconds if not selected boot windows.
so dont change default 0 in menu.lst instead in linux gksudo gedit /boot/grub/menu.lst and "cut" the entries for windows above the first entry.it will solve ur problem.that is windows will be shown as first entry also default will be windows too.
praka123 is offline
Old 24-10-2007, 07:03 PM   #9 (permalink)
Dreamweaver
Gigacore's Avatar
thankx xubz . . .
and Mehul bro thanks bro
Praka. . . i did it . . . its working thanks
THANKS to all once again
* * RESOLVED * *
Gigacore is offline
Old 24-10-2007, 07:10 PM   #10 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
^^dude you installed Mint from digit DVD?
I dunno why but mint doesn't install correctly on my PC.After installation when I booted up My PC showed...no Boot device....please check cables.Then I had to format my full hard disk and install XP MCE again.Now I am waiting for my gutsy CD to arrive.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 24-10-2007, 07:12 PM   #11 (permalink)
Commander in Chief
QwertyManiac's Avatar
Use a GUI tool instead.
Go for SUM (Start-Up Manager)
http://web.telia.com/~u88005282/sum/index.html
Works with almost all debian based distributions, and specially Ubuntu. Linux Mint is just that
P.s. Since you already did it, just beware before you get an kernel upgrade applied, it sometimes wipes out your Windows entry. Backup the grub/menu.lst somewhere for reference on how to add Windows again.
QwertyManiac is offline
Old 24-10-2007, 07:15 PM   #12 (permalink)
Dreamweaver
Gigacore's Avatar
@ qwerty thanks for that
@ devil, yes i installed from digit's dvd
Gigacore is offline
what to edit? shashanktyagi1 Software Q&A 1 24-03-2007 06:18 AM
Edit swf file possible Techmastro QnA (read only) 6 18-12-2006 01:33 AM
How to Edit GRand Unified Bootloader.conf [GRUB.conf] whistler Software Q&A 5 11-10-2004 02:31 AM
- by soumya
