Old 19-03-2005, 02:54 PM   #1 (permalink)
Stabbing my shoe
Default UBUNTU Live CD problem..
Hey Guys, I just wanted a solution of a simple problem in the UBUNTU LIVE CD.
My graphics card (NVIDIA RIVA TNT2 Model 64/Model 64 Pro) supports resolutions up to 1024x768. So, when I boot my computer with the UBUNTU Live CD, there is a menu below for setting resolutions whose default is 1280x1024. Now, I set it to 800x600 or 1024x768, the screen always goes blank. i.e. after hitting ENTER, the file settings are set up normally but when the Desktop finally loads, my monitor LED colour changes from green to orange indicating higher resolution than possible.
So, can any one help me set up the resolution in the LIVE CD (and not INSTALL CD) and tell me what's wrong and how can it be corrected ??
>> Siddhartha <<
> http://sidroy.wordpress.com <
> Beauty lies in the eyes of the Beer Holder <
//siddhartha// is offline
Old 10-04-2005, 09:40 PM   #2 (permalink)
vignesh's Avatar
type these two commands xmodule=nv and hsync or vsync based on your resolution.
vignesh is offline
Old 11-04-2005, 06:03 AM   #3 (permalink)
Stabbing my shoe
Yes, it works but after I installed the UBUNTU on my hard drive (E: ) the GRUB Loader starts. After that, it says it was unable to load X(perhaps, my desktop manager).. Now, feel like in UBUNTU live CD, I need 2 change my horizontal and vertical frequency.. How do I do that?
>> Siddhartha <<
Old 11-04-2005, 10:07 AM   #4 (permalink)
vignesh's Avatar
Actually I installed ubuntu and it automatically took me th the gui.Though last time I had the problem you had.You have to edit the config file
Type this
# xf86config
-> go through its configuration and set up your resolution.
# /etc/init.d/gdm restart
-> restart GDM login manager..
vignesh is offline
Old 20-04-2005, 03:39 PM   #5 (permalink)
vignesh's Avatar
Did it work or not.I seem to have the same trouble
vignesh is offline
Old 21-04-2005, 06:08 AM   #6 (permalink)
Stabbing my shoe
Well, I had worked it out long ago.. I just typed "x hsync=a vsync=b" where a is my horizontal freq. and b is vertical freuqeny.. THANX for the help, @vignesh
>> Siddhartha <<
Old 21-04-2005, 06:28 PM   #7 (permalink)
vignesh's Avatar
What I meant was the installing of ubuntu and using xf86config .Did that work not the live cd
vignesh is offline
- by soumya
