Old 18-10-2007, 10:20 PM   #1 (permalink)
antoniobc's Avatar
Question Open Suse 10.2 problem
My installation of Open Suse 10.2 seems to be working fine other than a problem, that is, it doesnt mount my USB pendrive....
How can I get it to do that?
Am using a ZION 512MB Pendrive
-- The Phoenix
antoniobc is offline
Old 18-10-2007, 11:10 PM   #2 (permalink)
18 Till I Die............
Default Re: Open Suse 10.2 problem
Check the output of
dmesg | tail
when you insert the USB drive.
http://www.bash.org/?258908
mehulved is offline
Old 19-10-2007, 08:34 PM   #3 (permalink)
antoniobc's Avatar
Originally Posted by mehulved
Check the output of
dmesg | tail
On trying the above command I get the following error
SFW2-INext-DROP-DEFLT IN=eth0 OUT= MAC= SRC=192.168.0.18 DST=224.0.0.251 LEN=111 TOS=0x00 PREC=0x00 TTL=255 ID=0 DF PROTO=UDP SPT=5353 DPT=5353 LEN=91
usb 5-6: device descriptor read/64, error -110
usb 5-6: new high speed USB device using ehci_hcd and address 5
usb 5-6: new high speed USB device using ehci_hcd and address 6
usb 5-6: device not accepting address 6, error -110
usb 5-6: new high speed USB device using ehci_hcd and address 7
usb 5-6: device not accepting address 7, error -110
-- The Phoenix
Old 19-10-2007, 09:03 PM   #4 (permalink)
Does it work anywhere else. Either your USB drive or your USB port has some problem.
mehulved is offline
Old 20-10-2007, 10:08 AM   #5 (permalink)
antoniobc's Avatar
The ports are fine, as they were working with Windows installed. Dont want to install that back....
The drive is fine also since I managed to read it off my parents Windows machine.
-- The Phoenix
Old 20-10-2007, 02:22 PM   #6 (permalink)
left this forum longback
praka123's Avatar
it is tedious to try.but u need to look in /dev/ directory for device like sdb sdc etc and u can mount them.
cd /dev/;ls -l |grep sd*
^will show up when drive is inserted.
also 'd like to see the output of
lsusb
and
lspci
praka123 is offline
need Open SuSE 10.2 DVD Garbage Open Source 9 15-07-2007 08:08 PM
Open Suse 10.2 Query dissel Open Source 13 10-03-2007 10:30 PM
Softwares for Open SuSE nishant_nms Open Source 2 07-02-2006 11:17 PM
- by soumya
