Old 16-10-2007, 08:20 PM   #1 (permalink)
Dark Star's Avatar
Default Help restoring Grub.
Ok Installed Mandriva 08 .. It took away my Ubuntu Grub .. Well now Mandriva even not working It nly works just after I install it and after 2 bot I end up in GDM hangs. Sucks.. Well thats not the point how can I restore my past fiesty grub so that I can use till my Cd arrives..
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 16-10-2007, 08:25 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Help restoring Grub.
You should have known that, or should have searched it at least, being so good at Linux here. There've been so many threads on this ...
Anyway, the procedure is:
Easy and Dumb:
1. Boot your computer up with Ubuntu CD
2. Go through all the process until you reach "[!!!] Disk Partition"
3. Select Manual Partition
4. Mount your appropriate Linux partitions
/boot
swap
5. DO NOT FORMAT THEM.
6. Finish the manual partition
7. Say "Yes" when it asks you to save the changes
8. It will give you errors saying that "the system couldn't install ....." after that
9. Ignore them, keep select "continue" until you get back to the Ubuntu installation menu
10. Jump to "Install Grub ...."
11. Once it is finished, just restart your computer
Smart:
1. Pop in the Live CD, boot from it until you reach the desktop.
2. Open a terminal window or switch to a tty.
3. Type "grub"
4. Type "root (hd0,6)", or whatever your harddisk + boot partition numbers are (my /boot is at /dev/sda7, which translates to hd0,6 for grub).
5. Type "setup (hd0)", ot whatever your harddisk nr is.
6. Quit grub by typing "quit".
7. Reboot.
Evergreen topic - http://ubuntuforums.org/archive/index.php/t-24113.html
Harsh J
www.harshj.com
QwertyManiac is offline
Old 16-10-2007, 08:31 PM   #3 (permalink)
Dark Star's Avatar
^^ My bad But still help is always appreciated and now I'll not forget it
Old 16-10-2007, 08:35 PM   #4 (permalink)
Commander in Chief
Just be careful if you got multiple hard-drives
Harsh J
www.harshj.com
Old 16-10-2007, 10:04 PM   #5 (permalink)
"The Gentleman"
vish786's Avatar
always bakup ur old menu.lst file.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 16-10-2007, 10:31 PM   #6 (permalink)
Wire muncher!
infra_red_dude's Avatar
Shashwat, I think you had the same problem a few months ago rite? At least you should've been more careful this time.
Were you able to solve this problem?
infra_red_dude is offline
Old 16-10-2007, 10:41 PM   #7 (permalink)
Dark Star's Avatar
Ya did solved and I had same prob months ago Well how to merge 2 grub menus.. I mean when open SUSe mandriva sk me to install grub should I install it in the same HDD of Ubuntu 1
Old 16-10-2007, 10:45 PM   #8 (permalink)
Commander in Chief
You're installing it onto the MBR right? If so yeah, you have to let it overwrite and hope that it detects the Ubuntu too.
Else, after you get inside SUSE/Mandriva/Whatever open the Ubuntu partition and see the menu.lst there and paste the required entries to the acting distro's Grub's menu.lst as required.
Harsh J
www.harshj.com
Old 16-10-2007, 11:17 PM   #9 (permalink)
Wire muncher!
The best thing would be NOT to let mandriva install GRUB onto MBR. Instead let it reside on the boot partition. Then you can manually edit the grub menu list in you ubuntu and add the mandriva entry.
Old 20-10-2007, 11:23 AM   #10 (permalink)
Google Bot
Pathik's Avatar
^^ Another option wd be not to install Mandriva's GRUB at all..
So that u dont have to pass thru two bootloaders to get to Mandriva...
Or keep the Mandriva bootloaders default OS as Mandriva and keep the waiting time 0 secs..
Pathik is offline
Old 20-10-2007, 05:30 PM   #11 (permalink)
Wire muncher!
^^^ I think I said the same thing about not installing Mandriva Grub!
restoring Limewire? Manshahia QnA (read only) 1 25-07-2007 04:35 PM
Restoring torrents? Manshahia QnA (read only) 27 24-05-2007 01:36 AM
Grub restoring problem The Outsider Open Source 4 23-12-2006 09:50 PM
Taking a backup of your db and restoring it bharathbala2003 Tutorials 4 08-12-2006 02:33 PM
restoring a drive shikhar_kapoor143 Software Q&A 4 02-07-2006 09:16 PM
- by soumya
