Old 15-10-2007, 12:10 AM   #1 (permalink)
anilmail17's Avatar
Default how to format a disk using fdisk in linux
i have recently got a acer laptop which shipped with linux shell only now i have deleted that partition using a recovery disk of red hat 4 and now i need to create a FAT32 partion so that i can instal XP on my laptop. when i try to boot using a XP bootable i got a error that no harddisk found. plz provide me a sol.
visit my blog
www.anilsoni.wordpress.com:)
anilmail17 is offline
Old 16-10-2007, 04:37 PM   #2 (permalink)
Mark0's Avatar
Default Re: how to format a disk using fdisk in linux
You souldn't need to format / repartition the HD; the XP setup procedure is fully able to do it for you.
But, if it say "no harddisk found", it mean exactly that; it probably don't recognize the particular HD-controlled your laptop use.
A specific driver is needed, for when the setup procedure say something like "Hit [F6] to supply a driver disk...".
You should be able to get the driver visiting the laptop manufacturer's website.
Bye!
Mark0 is offline
Old 17-10-2007, 03:55 PM   #3 (permalink)
hansraj's Avatar
i am too planning to fdisk my lenovo 3000 y 500 laptop. Any idea , if iam likely to face similar prob??? the 10 gb autorecovery partition is all bakwas and i want to remove it.
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Format hard disk srimaya_rath Software Q&A 4 06-12-2006 01:46 PM
unable to format disk Shasta Hardware Q&A 2 05-01-2006 08:00 PM
how to format HDD using fdisk? zegulas QnA (read only) 10 18-05-2005 12:41 PM
Help me format my hard disk.. //siddhartha// QnA (read only) 11 27-04-2005 09:18 PM
Format Hard Disk sachinc Tutorials 37 15-04-2005 09:04 PM
- by soumya
