I have just installed Ubuntu 6.10 on my pc having Viewsonic 20 inch lcd and Nvidia 7300 GS graphics Card. I downloaded Nvidia Linux Display Driver version 100.14.19. Then i booted throgh recovery consol and issued following command
"sudo sh NVIDIA-Linux-x86-100.14.19-pkg1.run"
i followed the instructions then at last it say "No precompiled kernel interface was found to match your kernel"
Here is the error log
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Sun Oct 14 16:09:47 2007
option status:
license pre-accepted : false
update : false
force update : false
expert : false
uninstall : false
driver info : false
precompiled interfaces : true
no ncurses color : false
query latest version : false
OpenGL header files : true
no questions : false
silent : false
no recursion : false
no backup : false
kernel module only : false
sanity : false
add this kernel : false
no runlevel check : false
no network : false
no ABI note : false
no RPMs : false
no kernel module : false
force SELinux : default
no X server check : false
force tls : (not specified)
X install prefix : (not specified)
X library install path : (not specified)
X module install path : (not specified)
OpenGL install prefix : (not specified)
OpenGL install libdir : (not specified)
utility install prefix : (not specified)
utility install libdir : (not specified)
doc install prefix : (not specified)
kernel name : (not specified)
kernel include path : (not specified)
kernel source path : (not specified)
kernel output path : (not specified)
kernel install path : (not specified)
proc mount point : /proc
ui : (not specified)
tmpdir : /tmp
ftp mirror : ftp://download.nvidia.com
RPM file list : (not specified)
Using: nvidia-installer ncurses user interface
-> License accepted.
-> No precompiled kernel interface was found to match your kernel; would you li
ke the installer to attempt to download a kernel interface for your kernel f
rom the NVIDIA ftp site (ftp://download.nvidia.com)? (Answer: No)
-> No precompiled kernel interface was found to match your kernel; this means
that the installer will need to compile a new kernel interface.
ERROR: You do not appear to have libc header files installed on your system.
Please install your distribution's libc development package.
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find suggestions
on fixing installation problems in the README available on the Linux
driver download page at www.nvidia.com.
Please help me install it. I do not want to install it online. Please suggest offline instructions.
