Old 14-10-2007, 04:32 PM   #1 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Default How to upgrade Kubuntu 7.04 to 7.10 ??
I wish to upgrade my OS from Kubuntu 7.04 to Kubuntu 7.10. But I am in confusion which one I have to download Kubuntu 7.10 RC or Kubuntu 7.10 beta.
Is it possible to upgrade my exhisting Kubuntu 7.04 with Kubuntu 7.10 without uninstall/format the existing one or I have to do fresh installation ?
Please clear my doubt.
________________________________________________
I like signature after 10 P.M.
skghosh44 is offline
Old 14-10-2007, 08:12 PM   #2 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default Re: How to upgrade Kubuntu 7.04 to 7.10 ??
try upgrade -d
not sure if it will work:s
gary4gar is offline
Old 14-10-2007, 09:11 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Follow this:
http://kubuntu.org/~jriddell/kubuntu-upgrade/
Step-wise in text:
1. Launch Adept Manager: KMenu -> System -> Adept Manager
2. In Adept -> Manage Repositories enable "Recommended updates" and "Pre-release", close and reload
3. Click Fetch Updates
4. Click Full Upgrade
5. Click Apply Changes and wait for the updates to install
6. Close Adept Manager
7. Press Alt+F2, or select KMenu -> Run Command to run a command.
8. Run the following command (the quotes are important):
kdesu "adept_manager --version-upgrade"
9. Click Version Upgrade
10. Follow the on-screen instructions
Steps sourced from: https://help.ubuntu.com/community/GutsyUpgrades
Harsh J
www.harshj.com
QwertyManiac is offline
Old 14-10-2007, 10:09 PM   #4 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Originally Posted by QwertyManiac
While i tried this steps it starts downloading about 695 mb for upgrade. Hence I discontinue the download. The Full Distro is I think 678 MB. I think there is another step to upgrade i.e "upgrade through alternate CD". Now how to make this alternate CD. Becaue alternate CD will be better for future use also.
Old 14-10-2007, 11:05 PM   #5 (permalink)
Commander in Chief
You have to download the Alternate CD via the Repositories of Gutsy.
But when Gutsy Kubuntu is just 3 more days away, why take the pain of downloading a Release Canditate Alternate CD ?
Harsh J
www.harshj.com
Old 15-10-2007, 08:03 AM   #6 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Yestarday I thought so and cancelled downloading. After final release on 18/10/2007 I will download the stable version. But is there will be any option to upgrade or I have to reinstall again.
Old 15-10-2007, 08:14 AM   #7 (permalink)
Commander in Chief
Yes you do get an option to Upgrade using the Alternate Install CD and it works fine too but the recommended way (To be safe) is to re-install.
Harsh J
www.harshj.com
Old 15-10-2007, 08:21 AM   #8 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Is there any windows OS like upgrade ?
Old 15-10-2007, 08:28 AM   #9 (permalink)
Commander in Chief
Yes there is! You need to get the Alternate CD, add it to the repositories and select Upgrade. That's what I've been telling all along now. There is an Upgrade option available definitely!
Harsh J
www.harshj.com
Old 15-10-2007, 08:40 AM   #10 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Than I have to download two file one for alternate CD (695MB) creation and other for normal distro (678 MB) CD. Which one u suggest ? both are not possible to download as I have 250 home plan. If I reinstall then I have to do a lots of job again. If I upgrade the job is less.
Old 15-10-2007, 08:45 AM   #11 (permalink)
Commander in Chief
Oh man, Alternate CD is same as Distro CD. Distro CD has Live while Alternate CD doesn't have Live features. That's the only difference!
Harsh J
www.harshj.com
Old 15-10-2007, 08:48 AM   #12 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
Thanks a lot, Now I am clear.
Kubuntu help shaunak Open Source 6 09-11-2006 03:54 AM
Kubuntu Queries The Outsider Open Source 7 13-10-2006 12:45 AM
Now kubuntu free-cds!! chesss Technology News 1 19-05-2006 05:50 PM
WE WANT KUBUNTU DVD!!!!!!!!!! coolblue Open Source 2 16-10-2005 05:42 PM
- by soumya
