Old 15-03-2005, 08:16 PM   #1 (permalink)
Default shell scripts
hello everyone, i recently installed PCQlinux..........but the thing that i dont like is to mount the ntfs filesystem each n every time(to listen to songs)......... i want to know how can i make a shell script which automatically runs when i start my linux (i.e. mount -t ntfs /dev/hda5 /root/abc command automatically runs).
i mean i want to put this script in startup.......any ideas???
Ashootosh is offline
Old 15-03-2005, 08:19 PM   #2 (permalink)
There is no need to make a shell script for this just make an entry in the /etc/fstab and it will be done automatically. For details check the forum this has been explained in great detail 'n' times.
**** happens
pradeep_chauhan is offline
Old 16-03-2005, 12:35 AM   #3 (permalink)
hafees's Avatar
(u should be root)
edit ur fstab using
vi /etc/fstab
then add the line (press i)
mount -t ntfs /dev/hda /root/abc
now save the file(wq)
U r done!
hafees is offline
Old 16-03-2005, 08:55 PM   #4 (permalink)
FooBar Guy
GNUrag's Avatar
Okay, so this was fstab , and it got solved. If you have anything other problem that needs to be executed everytime you reboot, then place it in a file, chmod it to +x and put it inside /etc/rcS.d
like this..
# echo "mount /mnt/whatever" > /etc/rcS.d/S90mnt
# chmod a+x /etc/rcS.d/S90mnt
http://www.MovieAB.com - A tiny movie mashup!
GNUrag is offline
Old 18-03-2005, 10:29 AM   #5 (permalink)
follow the steps
 # vi  /etc/fstab
add the following line
 /dev/hda5    ntfs    /root/abc    users,owner,ro  0  0
save ur work and issue the command
[code[
# mount -a
[/code]
or u can restart ur system , next time ur partition will mount automatically
live life linux size
grub is offline
