Old 30-09-2007, 05:45 PM   #1 (permalink)
Proud to be Linux
abhinandh's Avatar
Default create a desktop shortcut for a script
how do i create a shortcut for a script, for example i have cube game installed under "/usr/local/games/cube". i need to run the script "cube_unix" from that directory.(after doing a "cd")
whats the command i need to give in the create shortcutbox.
http://abhinandh.com
abhinandh is offline
Old 30-09-2007, 05:55 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: create a desktop shortcut for a script
Check this image guide below for doing it in GNOME
You need to give the entire path to the script, that is, "/usr/local/games/cube/cube_unix".
QwertyManiac is offline
Old 30-09-2007, 06:06 PM   #3 (permalink)
Proud to be Linux
abhinandh's Avatar
woooo a quick reply.but already tried that.i have to run the script from that particular folder.in terminal it gives error
exec: 42: ./bin_unix/linux_client: not found
thet folder bin_unix/linux_client is in the directory of the game
btw what window decorator r u using.is it emerald??
Old 30-09-2007, 07:31 PM   #4 (permalink)
Commander in Chief
Yes it is Emerald with the default green theme and Window Reflections turned on.
Sorry that the above didn't work .. But I think you need to make a bash script file for running this.
Add this to a file named cube.sh on your desktop:
#!/bin/bash
cd /usr/bin/local/games/cube
./cube_unix
Make it executable (chmod +x cube.sh or simply do it via Properties > Permissions) and tell me if it executes well?
Old 30-09-2007, 09:24 PM   #5 (permalink)
Proud to be Linux
abhinandh's Avatar
thank u.script running good.
Old 01-10-2007, 02:11 AM   #6 (permalink)
Commander in Chief
I should have taken that 'cd' more seriously at first itself, apologies
How to create a Filp3D Shortcut on your desktop. anandk Tutorials 12 17-02-2008 08:01 PM
Create a list of MS Word Shortcut keys pillainp Tutorials 4 31-07-2007 09:09 AM
create a shutdown/restart shortcut on your desktop ! anandk Tutorials 14 03-04-2006 05:37 PM
cant create shortcut on desktop... kamikaze Software Q&A 6 29-01-2006 07:36 AM
Help with desktop shortcut command.... h_kunte QnA (read only) 1 09-01-2006 09:59 PM
