Old 26-09-2007, 10:28 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Beware of the innocent
ilugd's Avatar
Default How to install wifi card Dlink - Centos 5
Hi, I have a Dlink card on my computer and i am not quite sure of its make. How do I find out what model the card is and how do i get and install the drivers?
I am running centos 5.
I just a few days ago installed vlc, mplayer and enabled ntfs support, so i am quite new to linux. I don't know much of the commands. How do we find out hardware details?
Life is too short. Have fun.
ilugd is offline
Old 26-09-2007, 10:41 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: How to install wifi card Dlink - Centos 5
wireless support is still lacking in Linux .afaik u can try using windows drivers in Linux using "ndiswrapper".just google for it.afaik intel things are only supported.
command for displaying available pci devices is:
lspci or hwinfo(if installed)
praka123 is offline
Old 26-09-2007, 10:43 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Offtopic but why use CentOS when you're starting off with Linux? Ubuntu is very very cool and offers excellent Wi-Fi support with its other easy features. That's the way you should go for learning the quick and easy way!
And check the output of lspci and also under System > Preferences > Hardware Information
QwertyManiac is offline
Old 26-09-2007, 11:35 PM   #4 (permalink)
ilugd's Avatar
ok, lspci output
Network controller: Texas Instruments ACX 111 54Mbps Wireless Interface
So I need a driver for this right?
went to the yum gui and go some drivers. There were actually two of them. They are from rpmforge i guess. I have installed those. I still don't get the texas wifi card list in the network configuration. What am i doing wrong.
@qwertymaniac, Ubuntu would have been fine. One of my friends is a rhel admin and he recommended this. I guess I just installed this to get him off my back. Hope he doesn't read this though.
I understand centos already has the required drivers for this. I don't really want to go the ndiswrapper line.
ilugd is offline
Old 27-09-2007, 12:04 AM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
i'm sorry i'm not well versed wid centos (not used this os and its been a long time since i've used fedore/redhat). however, one sure thing is that ubuntu has the best wireless support out of the box. the gnome network manager (also in centos gnome) will configure it out of the box. i can give you instructions in configuring wireless in ubuntu (even i haf a dlink card but wid the less common ralink chipset).
just type the command "iwconfig". it will list all the networking interfaces. you'll get to know the wireless status. try these steps out:
$: iwconfig
it should list the card without connecting to any SSID.
so type:
$: iwconfig ra0 essid -network name-
$: iwconfig
to check it.
$: ifconfig - it won't be listed > ra0
$: ifconfig ra0 up - activate ra0 (leds will blink - youll be connected to AP, OPEN AP, NO KEY and Encription, I used MAC address filtering for my Wireless, So I dont use encryption)
$: ifconfig - check for ra0 again (there wont be ip address i think... i didnt get it at first)...
$: dhclient ra0 - to activate DHCP client to get an IP from the router... (router needs to have DHCP server activated)....
$: ifconfig - to check again...
$: ping www.google.com - you should get reply...
infra_red_dude is offline
Old 27-09-2007, 12:15 AM   #6 (permalink)
ilugd's Avatar
shouldn't atleast the drivers be installed before this will work? where is iwconfig by the way? it is not in sbin atleast.
Please don't remind me about ubuntu again. I don't like it as it looks like a lot of eyecandy. I like centos as it is and I don't want to change. I just want to get my wifi card to work.
I figure that i needn't use ndiswrapper at all since the driver in yum had the comment that it was for texas 111 series wifi cards. Now i just need to figure out how it works.
on a sidenote, why does yum run only in one instance. I want to find what the name of that driver was an yum is locked up in downloading wine. Another instance says something about a yum.pid file being locked. Is there a way to bypass that?
ilugd is offline
Old 27-09-2007, 12:19 AM   #7 (permalink)
Wire muncher!
oh i thot you'd installed all wifi related wifi package. in debian based systems the pack which contains iwconfig is 'wireless-tools'
Old 27-09-2007, 12:38 AM   #8 (permalink)
18 Till I Die............
I believe it's rather sabayon that has best wireless support out of the box.
http://www.bash.org/?258908
mehulved is offline
Old 27-09-2007, 12:42 AM   #9 (permalink)
Wire muncher!
dunno about sabayon but i've never faced any problems wid ubuntu - almost any kinda wireless card has worked in there.
Old 27-09-2007, 12:43 AM   #10 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
Well, AFAIK, Sabayon is OpenSource, but does not follow purely just GPL like other Distros. GPL states that many binary/proprietary drivers should not be bundled/available automatically with its Distros..
So you know, Its usually disabled until you manually Install it.
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 27-09-2007, 01:03 AM   #11 (permalink)
ilugd's Avatar
wireless services seem to be installed as i am able to find the wireless tab in network preferences. But the driver is not available. Anywhere i can find out about configuring this stuff? any websites? I am tired of googling. the lan here sucks.
ilugd is offline
Old 27-09-2007, 02:13 AM   #12 (permalink)
Wire muncher!
driver not available? but you said its installed. why break ur head searching stuff? use ndiswrapper.
Old 27-09-2007, 03:04 AM   #13 (permalink)
GaurishSharma.com
gary4gar's Avatar
His card is supported natively
drivers can be found at:http://acx100.sourceforge.net/
i
@ilugd
s this your card type?
http://www.dlink.co.uk/pages/products/dwlg650plus.asp
gary4gar is offline
Old 27-09-2007, 12:09 PM   #14 (permalink)
ilugd's Avatar
wow, looks complicated. Let me try this tonight.
ilugd is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/open-source/69216-how-install-wifi-card-dlink-centos-5-a.html
how to find out what wifi card you have in centos - Google Search This thread Refback 08-07-2011 12:30 AM
Wifi Card Not Getting Detected?? caje143 Software Q&A 4 11-04-2007 09:35 PM
Beryl on centOS, how? amitava82 Open Source 1 22-01-2007 04:05 PM
how to use a wifi card in desktop? (confused pls look inside) ~It_is_Andrew~ Hardware Q&A 9 22-12-2006 02:49 PM
CentOS firewall Open Source 2 17-11-2004 07:57 PM
