Old 25-09-2007, 10:53 PM   #1 (permalink)
ninad_mhatre85's Avatar
Default fedora 7 installation problem ..
hi all
i have fedora 7 DVD with me( received with one magazine) i used it to install it on my old PC with intel 2.4 Ghz pro , 845 MOBO 256 MB ram & 40 GB hdd setup went well but it was bit slow so i removed it now i have upgraded my PC with AMD Athlon X2 64-bit pro, jetway mobo, 2GB ram the problem is that i am not able to install it setup stops in between i dont know what the problem is ? is it because 64 bit processor ?? or is there any other problem ?
setup stops at this line
NET : Registered family protocol 2
i am using 64 bit UBUNTU now but i want to install fedora plz help ..
Life is not measured by moments u breath but by the moments that take ur breath away
ninad_mhatre85 is offline
Old 25-09-2007, 11:42 PM   #2 (permalink)
"The Cake is a Lie!!"
[xubz]'s Avatar
Default Re: fedora 7 installation problem ..
Seems like its some problem with Dual Core CPUs, I did some Google Searching.
This is what I found.
So Try adding maxcpus=0 to Boot Options (in the CD Boot Menu) and see if it works.
[xubz] ● http://xubz.com/
[steam_id] ● http://steamcommunity.com/id/xubz
[xubz] is offline
Old 27-09-2007, 10:31 AM   #3 (permalink)
hey hi thanx for help but where to make that change for maxcpus=0 i have DVD provided with digit only i couldnt find any file to make changes if you have any idea about file name in which i have to make changes then that would be helpful.
any ways thanx for ur help.
Old 27-09-2007, 10:32 AM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
He meant that enter the "maxcpus=0" at the boot command line which appears when you boot the DVD. The place where it asks you to Press Enter to start or enter linux and press enter to begin etc. The first boot screen
QwertyManiac is offline
Fedora 7 installation problem sureshkumar Open Source 10 22-09-2007 09:26 PM
Fedora installation problem sureshkumar Software Q&A 1 09-09-2007 02:17 PM
Tutorial Req : Installation Of Fedora 7 BBThumbHealer Open Source 11 11-07-2007 01:23 PM
Fedora Core 5 installation through CDs giving problem Dink2cool Open Source 19 25-06-2006 12:07 AM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
