Old 13-09-2007, 10:19 PM   #1 (permalink)
Default Fedora 7 installation problem
i want to install Fedora 7 from Digit DVD but during installation it is asking for drivers to install and not recognising hard disk drive. My PC Config is Intel C2D 6420, MSI P965-Neo V2, Hitachi 250 GB SATA II, Seagate 20 GB PATA with LiteOn DVD Writer. How can i resolve this problem ?
sureshkumar is offline
Old 13-09-2007, 10:38 PM   #2 (permalink)
The Unknown's Avatar
Default Re: Fedora 7 installation problem
Search Google for appropriate drivers or goto Manufacturers Site and download the drivers. Then when it prompts for drivers, use the disks. I dunno how to install those drivers while installation. Wait for some others.
KDE on ArchLinux
The Unknown is offline
Old 13-09-2007, 11:39 PM   #3 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: Fedora 7 installation problem
its difficult to find drivers, it would be best to go for fedora 8.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 13-09-2007, 11:44 PM   #4 (permalink)
Nav11aug's Avatar
i dnt think ne1 can help u if it doesnt ... if u have the expertise u cud recompile everything after gettin the drivers frm the net . If not, install sm other distro
http://www.last.fm/user/NOLFxceptMe/
http://naveendageek.blogspot.com
Back after a long time. And well, EndSems screwed up as usual :)
Nav11aug is offline
Old 17-09-2007, 05:11 PM   #5 (permalink)
Fedora 8 is not released yet.
KDE on ArchLinux
Old 17-09-2007, 05:19 PM   #6 (permalink)
Commander in Chief
QwertyManiac's Avatar
Its the JMicron controller problem I guess.
See here:
http://forums.fedoraforum.org/forum/...d.php?t=156904
Harsh J
www.harshj.com
QwertyManiac is offline
Old 17-09-2007, 05:52 PM   #7 (permalink)
18 Till I Die............
Or do you use software raid?
http://www.bash.org/?258908
mehulved is offline
Old 17-09-2007, 08:48 PM   #8 (permalink)
"The Gentleman"
vish786's Avatar
torrent for fedora 8 beta
- Dijkstra
vish786 is offline
Old 19-09-2007, 09:37 PM   #9 (permalink)
I refer to a full stable release. I normally do not use beta versions of OSes. So i mean a "stable version" by release.
KDE on ArchLinux
Old 21-09-2007, 09:10 PM   #10 (permalink)
Nav11aug's Avatar
try Ubuntu Live CD .. if wrks install
Nav11aug is offline
Old 22-09-2007, 09:26 PM   #11 (permalink)
"The Gentleman"
vish786's Avatar
even beta version r good enough, it just few bugs which they fix in stable version .... which wont affect tat much.
- Dijkstra
vish786 is offline
Fedora installation problem sureshkumar Software Q&A 1 09-09-2007 02:17 PM
Tutorial Req : Installation Of Fedora 7 BBThumbHealer Open Source 11 11-07-2007 01:23 PM
Fedora Core 5 installation through CDs giving problem Dink2cool Open Source 19 25-06-2006 12:07 AM
Fedora Core 4 installation help............................. iinfi Open Source 14 11-08-2005 06:34 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by Charley
- by tv6952
