Old 12-09-2007, 10:01 PM   #1 (permalink)
The Unknown's Avatar
Unhappy HELP: URGENT: mysqld, iptables, many problems!!!!!!!!!!!!!!
httpd was configured long ago. I had changed the location of .pid file from /etc/httpd/run to /var/run
Two days ago, i saw many files in /etc/httpd/run
I deleted all of them and now there is Sound Problem, mysqld won't start, iptables wud give errors, much more..... How do i solve this???????????? This is urgent. Please help!!!!!
The Sound Error is:
The volume control did not find any elements and/or devices to control. This means either that you don't have the right GStreamer plugins installed, or that you don't have a sound card configured.
You can remove the volume control from the panel by right-clicking the speaker icon on the panel and selecting "Remove From Panel" from the menu.
For now my pc is running. But with lot of problems.
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
KDE on ArchLinux
The Unknown is offline
Old 13-09-2007, 03:39 PM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: HELP: URGENT: mysqld, iptables, many problems!!!!!!!!!!!!!!
Try reinstalling apache!
mediator is offline
Old 13-09-2007, 07:20 PM   #3 (permalink)
sabko mujhe chidane mein he majak sujta hai kya? please tell a solution.
KDE on ArchLinux
Old 13-09-2007, 07:52 PM   #4 (permalink)
String Phreak
mediator's Avatar
Ayila!!
Why wud I wanna do a heinous crime like that? Just telling u to reinstall coz u deleted some files from ..../httpd/run...so it means apache directory. U may try it!
mediator is offline
Old 13-09-2007, 09:19 PM   #5 (permalink)
18 Till I Die............
First of all check the logs. And if you don't understand them, post them here.
http://www.bash.org/?258908
mehulved is offline
Old 13-09-2007, 10:15 PM   #6 (permalink)
lol, i'm sayin pid files and you r sayin log files?? What relation they have in common??
KDE on ArchLinux
Old 14-09-2007, 04:08 PM   #7 (permalink)
OK then. Keep on lol'ing
mehulved is offline
Help me! It is very urgent!Logon problems in WinXP kguragain Software Q&A 6 31-07-2006 05:50 PM
vista beta 2 and xp sp3 .-together creating problems. urgent help required ! go_gamez Software Q&A 8 14-07-2006 05:06 PM
Simple iptables tutorial ujjwal Open Source 3 12-06-2005 08:06 PM
- by Charley
- by tv6952
