Old 04-09-2007, 09:32 PM   #1 (permalink)
clmlbx's Avatar
Smile Forgot Password OF Fedora 7? Pls Help
My Friend Just Installed Fedora 7 . After Installation He Is Asked For The Username And Password . And He Says He Had Not Entered Any Password .
So He Has Messed It Up , So Is There Any Way We Can Get Password Or Disable It .
clmlbx is online now
Old 05-09-2007, 10:27 AM   #2 (permalink)
saurabh.sauron's Avatar
Default Re: Forgot Password OF Fedora 7? Pls Help
which user??? Root or normal...?
did ur friend enter root password during installation (it is asked in the initial setup). did he create a normal user during the initial setup?
(the normal user has to be a sudoer)
login as normal user.
sudo passwd root
enter new password
saurabh.sauron is offline
Old 05-09-2007, 09:06 PM   #3 (permalink)
clmlbx's Avatar
what is root and normal ?
even he is new to it ..
Old 05-09-2007, 09:14 PM   #4 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: Forgot Password OF Fedora 7? Pls Help
read the 4th post in the thread.
Tips n tricks for Linux
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 05-09-2007, 09:35 PM   #5 (permalink)
clmlbx's Avatar
Unhappy Re: Forgot Password OF Fedora 7? Pls Help
confused
can u plz give me direct answer to reset fedora 7 password
Old 06-09-2007, 01:43 AM   #6 (permalink)
left this forum longback
praka123's Avatar
there is users and their home dirs are there in Linux&UNIXens.a normal user like "yourname" must be created for as a local user with restricted permissions that fedora asks u to create during the end of installation.but while in earlier installation steps fedora/most linux asks what shud be ur root passwd to be.enter this passwd and remember it(or write it somewhere).
root is the administrator of the computer.it is not adviced to login as root.always use ur yourname account.
if u forgot root passwd & local user passwd.u can reset it Via GRUB(the boot menu).that is posted many places just google username forgot.
praka123 is offline
Old 06-09-2007, 08:06 AM   #7 (permalink)
clmlbx's Avatar
^^ thanks for the reply
now I understood this thread :- Tips n tricks for Linux
so..
root :- administrator
normal :- limited account user
all of you thanks for ur help
Old 06-09-2007, 02:41 PM   #8 (permalink)
praka123's Avatar
^now dont ur friend needs to reset his passwords for root or localuser?as he says he forgot them?but dont format-reinstall technique as in windows.In Linux everything doesnot need a reboot or reformat if something errs out
I may not be good in explaining step-by-step.so gives u a link:
http://www.fedorafaq.org/basics/#resetroot
^btwn GRUB is that boot menu showing fedora,windows etc when u boot up ur PC.
^anyways i'll explain:
when u see the Grub menu Fedora 7 entry-use the up key to select that entry.then press keyboard "e".then u'll see something similar as below:
title Fedora (2.6.22.1-41.fc7)
root (hd0,0)
kernel /boot/vmlinuz-2.6.22.1-41.fc7 ro root=LABEL=/ rhgb quiet
initrd /boot/initrd-2.6.22.1-41.fc7.img
title Fedora (2.6.20-2925.13.fc7xen)
^now select the line with keyboard up or down arrow to the line starting with "kernel /boot/vmlinuz...".then press "e" in keyboard.now u can edit that line to boot into single runlevel.do as below.
remove the "ro " from the kernel line we are editing by pressing backspace key and type "rw".remove "rhgb" too.then append a "1" at the end of the line.it may look as below:
kernel /boot/vmlinuz-2.6.22.1-41.fc7 rw root=LABEL=/  1
after doing as above.press enter.press "b" in keyboard(kbd) to boot into runlevel 1 with a "#" prompt.there u shud do as follows:
passwd root
^now enter a passwd u can remember(or write down that passwd somewhere).press enter.enter twice.
if u remember which one is ur friends username?
then do the same as below
passwd usernameofurfriend
and the same steps as for root passwd.
press CTRL+D to exit.
now if fedora boots it will show u a screen where u need to enter ur local username(dont login as root it is dangerous) and passwd to login.that screen is called gdm(gnome desktop manager).remember many a things are different from windows and dont expect windows like behaviour in Linux and not to forgwet windows programs or files cannot be run(for eg winamp,players) in Linux or UNIX natively because they are a completely different superiror operating systems.(although u can emulate windows programs to run via wine)
http://fedorafaq.org
^@^ is a good site for referring.
praka123 is offline
Forgot password of XP pritish_kul2 Software Q&A 9 07-06-2007 05:35 PM
Forgot Password??? paradise_guy Software Q&A 2 13-05-2007 02:45 PM
Forgot Password of XP nitesh872004 Software Q&A 3 21-08-2006 12:50 PM
forgot win password. supersaiyan Software Q&A 24 17-01-2006 01:14 AM
Forgot Your Password On XP? readermaniax Tutorials 6 12-12-2005 02:22 AM
- by soumya
