Old 01-09-2007, 09:33 AM   #1 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Question Kernel upgrade similar to old method?
I will be upgrading my kernel of my FC5 64-bit which has the old kernel version of 2.6.15 to 2.6.22.6. I checked out few resources which tell the details of upgrading from 2.4.x to 2.6. Can I follow the same steps for the upgrade of my kernel or have they been any major changes of the method of upgrading? Anything to look out for before making the changes? I will be installing GRUB as the bootloader. I don't have a broadband connection. Will this hamper the upgrade as I don't know which version of gcc and other applications are there. Upgrading that would be nearly impossible because of the dependencies. Please guide me.
EDIT: I will be upgrading the kernel after a fresh install.
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 01-09-2007, 09:49 AM   #2 (permalink)
18 Till I Die............
Default Re: Kernel upgrade similar to old method?
1. Download the new kernel
2. Configure it
3. Compile it
4. Make it into an rpm
5. Use rpm -ivh <kernel.rpm> to install it
See http://www.howtoforge.com/kernel_compilation_fedora for some help
mehulved is offline
Howto upgrade kernel(2.6.22-9-generic) in Feisty Fawn infra_red_dude Open Source 7 28-08-2007 10:55 AM
Which method of Defragmentation to use in O&O Defragmenter8? serendipiti QnA (read only) 4 23-08-2005 04:49 PM
Is there a Correct method /way of using an ups? john_the_ultimate QnA (read only) 8 21-06-2005 10:29 PM
How to upgrade to linux kernel 2.6 from kernel 2.4? kjayasurya Open Source 7 18-12-2004 02:23 PM
- by soumya
