Install Compiz & compiz Fusion plugins.
Add repositories to sources.list file
sudo gedit /etc/apt/sources.list
add these lines at the end & save.
after adding entries, update
for gnome.
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install compiz compizconfig-settings-manager
for kde.
sudo apt-get update
sudo apt-get install compiz compizconfig-settings-manager compiz-kde
For Fusion-icon.
sudo apt-get install git-core
Install Emerald themes.
sudo apt-get install emerald-themes
For manually starting Compiz-fusion
Press Alt+F2, then type
compiz --replace
or
fusion-icon
For Autostart during boot up.
For gnome.
compiz --replace
Goto, System-->Admin-->Sessions,Click New.
Under Name: Compiz-fusion
Command: fusion-icon
For Kde.
In terminal type,
cp fusion-icon ~./Autostart/
To launch Compiz Config Settings Manager
Press ALT+F2
If their's an prob with Window border decorations.
In terminal type.
sudo nvidia-xconfig --add-argb-glx-visuals -d 24
Source: Ubuntu forums & Geek.
