Old 23-08-2007, 07:30 AM   #1 (permalink)
Default trouble installin gcc
i tried installin nvidia drivers for my ubuntu fiesty fawn distro... but i was prompted with an error message sayin problem wit cc compiler.... how go i get a c compiler installed in my system..
deepakprabhakaran is offline
Old 23-08-2007, 08:51 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: trouble installin gcc
Ah well, instead of doing it the hard way, just run:
sudo apt-get install nvidia-glx
No CC/GCC troubles. But anyways, to get a compiler etc installed, do:
sudo apt-get install build-essential
Harsh J
www.harshj.com
QwertyManiac is offline
Windows XP not installin!! prankie Software Q&A 9 22-04-2007 05:40 PM
installin soft in ubuntu Arun the Gr8 Open Source 2 13-03-2007 01:53 PM
Error while installin Kubuntu5.10 sudeepg123 Open Source 3 21-08-2006 08:46 PM
help installin php mukul Tutorials 7 07-07-2006 01:58 PM
Fedora Core 4 installed ...... trouble trouble trouble... iinfi Open Source 19 12-10-2005 06:03 PM
- by soumya
