18-08-2007, 07:35 PM
OMG help Screenlets
OMG Berly run on my comp :yahoo: Now the problem .. idon't know much shortycuts plz help me  and the screen are above all windows so how can make them behind all windows ) Thanks berly is cool
Also how to change the top and bottom image of cube i.e Berly atm
Also plz tell me how to add objects in Kiba dock  Drggaing and adding did not work
See the blac border are appearing how can I remove them in screen shot
Bump plz help
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Reason: Automerged Doublepost
18-08-2007, 07:38 PM
"The Gentleman"
Re: OMG help Screenlets
goto " beryl settings manager ", u will get everything their, shortcut/all commands, and many extra stuff. similarize with beryl its easy to manage.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
18-08-2007, 07:44 PM
and abt Kiba some of the features are not enable like water effect .. Now if I enable it . with shift + F9 it did not start
18-08-2007, 07:49 PM
"The Gentleman"
goto beryl settings manager-->Extras--> check on water effects.
shortcuts for making shortcuts of watter effect where cursor is pointing == ctrl + superkey/window key.
shift +f9 == multiple water effect
shift + f8 == erasing water effect.
if u want even windows water effect then
beryl settings manager-->Extras--> water effects-->window wave, check all.
- Dijkstra
18-08-2007, 08:45 PM
How to make a transparent cube ? and how to change the top and down wallpaper of Cube
18-08-2007, 10:11 PM
Wire muncher!
settings manager > cube. for the background set a skydome. also, i suggest using avant window navigator instead of kiba dock. thats more stable.
19-08-2007, 12:47 AM
left this forum longback
why?no compiz-fusion for u @shaswath?
19-08-2007, 01:56 AM
Rubik's Uncle!!
^^ Yep I was wondering about the same. I used Beryl and someone suggested Compiz.. and I was not disappointed. Compiz-Fusion is much stable than breyl and the effects are also very smooth compared to beryl. Also most of the settings are very similar if not the same.
19-08-2007, 09:02 AM
^^ am on 256 MB ram how can I think to run CF
19-08-2007, 09:33 AM
In Pursuit of "Happyness"
^^ So what! It does not matter! Just give it a try!
19-08-2007, 01:18 PM
19-08-2007, 02:15 PM
Rubik's Uncle!!
^^  those screen shots are 2 MB and 1.4 MB respectively  ...
Shashwant cant you use jpeg insted of PNG???
19-08-2007, 05:23 PM
I need that wallpaper
19-08-2007, 07:28 PM
God of Mistakes...
Offtopic :
I have ubuntu installed on my comp. Specs are...
Intel Pentium D 3.06
Intel Original 101Ggc Mobo
1 GB DDR
NO GRAPHICS CARD !!!! But have ATI RADEON XPRESS 200 SERIES onboard graphics!
Can I run Beryl or Compiz on my computer ???
19-08-2007, 07:40 PM
Rubik's Uncle!!
^^ Best of luck with ATi ..
19-08-2007, 07:51 PM
18 Till I Die............
Originally Posted by shirish_nagar
Offtopic :
1 GB DDR
I believe AIGLX works fine with radeon driver.
And XGL should work with fglrx driver, but I am not sure if fglrx is well supported by this card.
Just google around a bit, you should find which driver will be better.
Beryl and compiz are outdated, go for compiz-fusion.
19-08-2007, 08:58 PM
"The Gentleman"
guys just now installed compiz-fusion, its very stable when compared to beryl, compiz in workin, it smoother, sexy and hot.  .
those who r installing beryl or compiz, dont go for either of them, instead install compiz-fusion.
- Dijkstra
19-08-2007, 10:48 PM
God of Mistakes...
ohh thanks...
Let's give a try for compiz-fusion.
19-08-2007, 10:59 PM
#19 (permalink)
You'r Born Free
What can I install on my old rig with 2Ghz Celeron with 512 DDR on 845.
Water effect shows me error.
# Money, Beauty and Configration has no ends.
# Life is like game sometimes. Play it or loose it. But keep the spirit of game.
http://en.wikipedia.org/wiki/Right_to_Information_Act
19-08-2007, 11:15 PM
#20 (permalink)
Wire muncher!
shirish, ur onboard video is not fully supported by the opensourc radeon driver (no 3d, only 2d accel). you'll need to use fglrx and xgl to run compiz/beryl.
read here: http://ubuntu-se.org/smf/index.php?topic=8913.msg67326
stay away from water effect. it won't run anyways. my emperical conclusion says beryl is better for older hardware.
19-08-2007, 11:29 PM
#21 (permalink)
You'r Born Free
What are effects and eye candy I can use on my rig.
19-08-2007, 11:53 PM
#22 (permalink)
Wire muncher!
@int86
the normal, window effects (minimize/shadow/wobble), the desktop cube, a bit of transperencies is all that will run smoothly. u may try other effects too and post about ur experience here so that it benefits others. these are the effects which i've seen run smoothly on a config like urs.
@kenshin
goto compiz settings and set the horizontal desks to 4. also enable the cube and rotate cube option.
20-08-2007, 06:54 AM
#23 (permalink)
God of Mistakes...
Thanks infra!
But now the problem is that I don't have a broadband connection. So can't update the Ubuntu. I'm sure that updates are hundreads of MBs.
what to do now? I have Ubuntu 7.04 DVD
20-08-2007, 12:02 PM
#24 (permalink)
Wire muncher!
@shirish
what version of ubuntu do you run? hey jus follow that guide. the only big download is the ati driver. download that article. ur gfx card can be setup offline. goto some cyber cafe and download all the resources. i hope you haf at least one of the composite managers installed. even if not its not a very big download (~8mb or so) which is one time download.
@shashwat
we are still waiting for that wallpaper!
20-08-2007, 02:00 PM
#25 (permalink)
Sry was a bit late busy with studies
20-08-2007, 03:18 PM
#26 (permalink)
God of Mistakes...
I'm using Ubuntu 7.04. Even if I have the ATI Drivers for Linux, I can't install it. After running that shell script, it shows a window titled message with a button nothing on it. After clicking on that button window closes.
What to do now ??
Can anyone provide step by step procedure ??? Please..... I'm gonna crazy for those Desktop effects....
20-08-2007, 03:34 PM
#27 (permalink)
Wire muncher!
@shashwat
thanks
@shirish
offiline installation become a bit tedious. follow this step by step guide
http://wiki.cchtml.com/index.php/Ubu...allation_Guide
20-08-2007, 09:56 PM
#28 (permalink)
God of Mistakes...
Thanks for the link.
But ond thing I want to tell u that i have ATI Radeon Xpress 200 series. And *NOT* ATI Radeon Xpress 200M series.
