Old 09-08-2007, 08:37 PM   #1 (permalink)
a_k_s_h_a_y's Avatar
Question help: hw 2 install GCC in DSL ??
i want to install GCC in Damn Small Linux
i hv installed dsl thru virtual box !!
i could not install VLC player in DSL as it says no good or compatible compiler available
now how do i install GCC and then finally install any program that i want ??
i tried to google but i did not understand much
was there a sticky to install progs in linux ? where did it go ??
few months back i had same probs in ubuntu...but gave up instead !!
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
Old 10-08-2007, 08:04 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: help: hw 2 install GCC in DSL ??
You can try to set up APT on DSL via:
http://www.damnsmalllinux.org/dsl-n/...topic.php?t=98
And then apt-get install gcc from the MyDSL repositories which setting up the APT will give you access to.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 10-08-2007, 10:10 PM   #3 (permalink)
^^ thanks i will try as soon as !!
how to install ubuntu direct from install menu rather than first run it thru live cd arunks Open Source 10 31-08-2006 10:41 PM
ISO install RH9 sknowonweb Open Source 7 21-12-2005 12:00 AM
How to install windows 2000(pro)After install of xp? rajas700 Software Q&A 4 23-10-2005 01:32 PM
How to install. rajas700 Open Source 14 29-08-2005 07:30 AM
- by soumya
