Old 04-08-2007, 08:50 PM   #1 (permalink)
D i s t i n c t l y Ahead
saurabh kakkar's Avatar
Unhappy help me on wine problem
hi
I had to remove wine due to its improper working on my ubuntu 7.04 it was not showing help option
uninstaller was not working properly now i want to install wine again correctly whats the process ?
also in windows .exe is the executable file responsible for running whats in linux ? plz help this noob
saurabh kakkar is offline
Old 04-08-2007, 09:09 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: help me on wine problem
In Linux, executable files work on the attribute basis rather than extensions. 'x' is the attribute which means executable. If a file has +x attribute attached or assigned to it, it is treated as an executable. Some applications come as .bin, though. Extensions don't matter in Linux, the file permissions (+r, +w, +x, etc) do. Right click on a file > Properties > Permissions to know more.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 04-08-2007, 11:59 PM   #3 (permalink)
^^ how to download wine ? which version should i go for ?
Old 05-08-2007, 12:33 AM   #4 (permalink)
left this forum longback
praka123's Avatar
install wine using apt or synaptic gui.for latest wine there is a repository.add below repo to ur /etc/apt/sources.list and save exit;apt-get update(in synaptic press reload)-these all when internet is connected.
 # Bleeding edge wine packages
deb http://wine.budgetdedicated.com/apt feisty main
adding repo is explained in below thread(though dont use if it is for edgy)
http://ubuntusoftware.info/repos.html
praka123 is offline
Old 05-08-2007, 11:10 PM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
i'd rather recommend wine from the official ubuntu repos than the "bleeding edge wine packages". they always tend to crash for me.
for installing the stable version. simply goto the terminal and type "sudo apt-get install wine"
infra_red_dude is offline
Old 06-08-2007, 02:02 AM   #6 (permalink)
Smile Re: help me on wine problem
buddy i have done the same but it cause a hell lot of problem like installer
was not working properly ,there was no help option also conif was giving
problem thats Y i have asked for a proper nd stable method
Old 06-08-2007, 11:04 PM   #7 (permalink)
Wire muncher!
what command did u use to uninstall wine? and what errors did it give?
Wine and nfs iMav Open Source 4 29-04-2007 01:54 AM
Wine not working phreak0ut Open Source 4 09-09-2006 06:03 PM
problem while installing Wine in Red hat 9.0 m.parthiban Open Source 5 27-11-2005 01:47 PM
Problem using Wine Packages in Linux? prashu Open Source 3 02-11-2004 07:24 PM
- by soumya
