Old 04-08-2007, 06:55 PM   #1 (permalink)
AJJU
azzu's Avatar
Default FEDORA problems
today i was tryin to install fedora 7 came with digit
while the setup was runnin it is suddenly freezing the mouse pointer is movin but
the setup is not continuing .
HELP ME
my rig 4 2.4 ghz 512 rm
80 gb hd....xp.......intel Xgfx
bmp
w8ing
I love and Live to Design
azzu is offline
Old 05-08-2007, 01:07 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Smile Re: FEDORA problems
select the least install with Gnome or kde and X.try it.it is difficult with fedora if some scratch or dvd error cannot complete installation.sometimes waiting for some time(1/2 hours or so ) may complete the installation.
if it errs out,
the only option is to select Gnome and some necessary things.once u complete the installation,u can install later other packages inside fedora system with its package manager(system-config-packages).but i'll say if u want to try use a fedora livecd(700MB) either Gnome or kde.
even there are other distros like Ubuntu or Debian if u wanna try.
praka123 is offline
Old 05-08-2007, 03:35 PM   #3 (permalink)
Google Bot
Pathik's Avatar
Default Re: FEDORA problems
did u do a media check b4 u started the install?? also select minimal packages wen installing... install what u want afterwards..
Pathik is offline
Old 05-08-2007, 04:30 PM   #4 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: FEDORA problems
i would suggest to do " Minimun installation " in " Text Mode " and then after isntalling the base of fedora.... u can later install other softwares.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Beryl problems on fedora 6 cranky Open Source 8 07-03-2007 12:26 AM
Fedora 6 post installation problems cranky Open Source 5 05-03-2007 07:11 PM
SB live! 24 bit problems in fedora core 4 borg Open Source 1 21-02-2006 02:10 PM
RedHat/Fedora problems Aijaz Akhtar Open Source 3 20-06-2005 10:50 AM
Fedora Core 3 problems.... [lokesh] Open Source 18 17-03-2005 01:30 AM
- by soumya
