Old 03-08-2007, 06:08 PM   #1 (permalink)
Maverick340's Avatar
Default [Ubuntu Fiesty 7.04] Sound Problems
Hi ,
I have an Asus A8n-VM motherboard and 5.1 speakers. The proeblem i am facing is i get output only from 2 front speakers. If i set channel mode to 6ch , sound goes completely. I tried some ofthe workarounds suggested on ubunutofrums.org but they didnt work.
Aaman@aman-port:~$ aplay --list-devices
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 0: AD198x Analog [AD198x Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 1: AD198x Digital [AD198x Digital]
  Subdevices: 1/1
This is one the outputs asked for , so you can have a look
Also , i have a ATi Radeon x300 graphics card. After installing the ATi drivers , video played in VLC is shakey - however it not the case in mPlayer.
I really like VLC so i want to use that ..
You and Me forever be ...
PSpwned
Maverick340 is offline
Old 03-08-2007, 06:55 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: [Ubuntu Fiesty 7.04] Sound Problems
I hope ati driver issues arebest told in http://ubuntuguide.org.
regarding audio,did you try opening the volume control on top panel and go to edit>preferences> options like surround etc unmuted.
praka123 is offline
Old 03-08-2007, 07:04 PM   #3 (permalink)
Wire muncher!
infra_red_dude's Avatar
for the multi channel jus check which device is used, the analog or the digital and configure that accordingly by searching for relevant guides (i'm sorry i dun use multi channel so dunno abt the exact config, but search on the net). i think u are giving analog 5.1 connection while enabling the digital multichannel output. check that.
infra_red_dude is offline
Old 03-08-2007, 11:54 PM   #4 (permalink)
hi infra , dude i am sorry but i am not getting what you exactly mean ..
i dont know how does alsa handle sound .. plus m a newbie
just explain a bit more
PSpwned
Old 04-08-2007, 06:19 AM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
Under Settings->Preferences, with Advanced Options checked, try choosing an option similar to what MPlayer uses in the division below:
Mostly MPlayer uses XV by default, so you could start your trial and error with that one.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 04-08-2007, 09:35 AM   #6 (permalink)
UbuntuUser
cynosure's Avatar
This happens with me sometimes when only one of my speakers work (out of two). I just pop in the virtual terminal <Ctrl>+<Alt>+F2 and log in as root.
Then use alsaconf. This will detect your sound card and will save the profile. Then go back to X using Ctrl+Alt+F7 and my sound comes back
This problem is not solved if I restore any saved sound profile.
I use Zenwalk.
cynosure is offline
Old 04-08-2007, 12:18 PM   #7 (permalink)
Wire muncher!
fiddle around wid volume control. file>devices... then edit>pref.. enable all switches.. check if the multichannel output is being directed to the digital out. check for any digital outs enable if u haf analog speakers.
@cynosure
i don't think ubuntu has alsaconf.
Old 04-08-2007, 12:23 PM   #8 (permalink)
UbuntuUser
cynosure's Avatar
Thats why I said "I use zenwalk".
If you guys can suggest the equivalent of alsaconf in ubuntu, then I think this problem can be tackled.
cynosure is offline
Old 04-08-2007, 12:44 PM   #9 (permalink)
praka123's Avatar
^alsaconf was omitted by ubuntu devels saying it is obsolete.
praka123 is offline
Old 04-08-2007, 01:12 PM   #10 (permalink)
String Phreak
mediator's Avatar
@Maverick :
http://ubuntuguide.org/wiki/Ubuntu:F...s.29_with_ALSA
You need to insert the following (code) lines in your sound config file i.e asoundrc in your home directory! i.e $HOME/.asoundrc
pcm.!default {
    type plug
    slave.pcm "surround51"
    slave.channels 6
    route_policy duplicate
So
1. gedit /.asoundrc
2. Append the code lines to it!
3. Logout and login again!
4. That shud work!!
In FEDORA, u do it in "/etc/asound.conf"!!
mediator is offline
Old 04-08-2007, 06:30 PM   #11 (permalink)
^ i tried the duplicating thing.. dosent work. either that or som other setting is astray . after trying to duplicate sound output , should i set channel mode to 2 ch or 6 ch ?
I get this error when i use a command in terminal
ALSA lib pcm.c:2145:(snd_pcm_open_noupdate) Unknown PCM “surround51″
set it to X11 , worked
PSpwned
Old 04-08-2007, 07:51 PM   #12 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Maverick340, try going through this thread if it helps!
http://ubuntuforums.org/showthread.php?t=205449
kalpik is offline
Old 04-08-2007, 11:19 PM   #13 (permalink)
String Phreak
mediator's Avatar
I have set it up as 6 channel!
mediator is offline
Old 05-08-2007, 03:42 PM   #14 (permalink)
https://help.ubuntu.com/community/HdaIntelSoundHowto
This helped. I am getting sound from all right channels + center ( right front , right surround and center )
The left channels give almost 0 output . I have checked for muted channels also , the are all unmuted .
The guide you suggested kalpik dosent help in this regard
PSpwned
Ubuntu 7.4 (Fiesty Fawn) Problem Third Eye Open Source 19 07-07-2007 03:34 AM
Ubuntu 7.04 'Fiesty Fawn' Released [xubz] Open Source 128 07-05-2007 08:27 PM
Enabling surround sound with Ubuntu 6.06 baccilus Open Source 4 26-11-2006 11:34 PM
Ubuntu 5.10 creative vibra128 sound card -no sound smurthygr Open Source 8 25-01-2006 11:59 PM
Sound problems !! hittheswitch Open Source 1 10-05-2005 02:56 PM
- by soumya
