Old 03-08-2007, 02:38 PM   #1 (permalink)
Kalyan's Avatar
Default Suse 10.2 shows lesser speed of processor.
Hi all..
I have an AMD 5600+ proccy on an ASUS M2NPV-VM mobo. I have Suse 10.2 on my pc. In My Computer, it shows that the processor correctly(5600+) but the speed is shown only as 1000MHz while the speed should 2.8GHz or 2800MHz
Kalyan is offline
Old 03-08-2007, 03:05 PM   #2 (permalink)
You gave been GXified
gxsaurav's Avatar
Default Re: Suse 10.2 shows lesser speed of processor.
AMD Athlon 64 CPU uses Cool&Quite technology which decreses the CPU speed when it is not used much. This is whats happening in your case I suppose. Try running some CPU intensive task like video encoding & see the clock speed then, it will be 2.8 GHz
about.me/gxsaurav
gxsaurav is offline
Old 04-08-2007, 04:26 PM   #3 (permalink)
thats partially true, athlon cpu's allow for cpu stepping but what suse uses is cpufreqd or a similar package that allows for the cpu stepping.
generally in suse thats set to on-demand i.e the cpu speeds up only when its needed and slows down when its not.
Offtopic- hows the amd x2 5600+ performance tho? was thinking about upgrading to it.
fiddler is offline
Old 07-08-2007, 02:17 PM   #4 (permalink)
Kalyan's Avatar
Its working fine. I had no trouble till now or heating issues.
Kalyan is offline
processor speed ismart CPU / Motherboards 6 19-02-2007 01:17 AM
Intel shows off 80-core processor anandk Technology News 9 13-02-2007 06:05 PM
About processor speed pushkar1986 Hardware Q&A 7 12-07-2006 10:22 PM
BIOS shows wrong Memory speed guhanath Hardware Q&A 2 12-03-2006 12:23 PM
processor speed vraja4u QnA (read only) 7 29-08-2005 06:39 PM
- by soumya
