28-07-2007, 10:10 PM
dig_boy_dig,dig !
Net Connection in Ubunto 5.10
I am an novice in LINUX. Recently I installed Ubuntu 5.10 after failure to llogin in Fedora 7 after successful installation. Now I wish to make a net connection through BSNL's DataOne BB. I tried the DIGIT Fast Track/Ubuntu's inbuilt help as well as online help. But I am unable to make the net connection. I shall be glad if I get step by step guide how to make the connection.
ubuntu novice.
28-07-2007, 10:34 PM
Re: Net Connection in Ubunto 5.10
ubuntu novice.
Find the network administration app. Select the options in ur LAN card such that it will be activated on boot, ip will be obtained via DHCP. I am FC user so i hv no screenshots for u.
KDE on ArchLinux
28-07-2007, 10:43 PM
dig_boy_dig,dig !
I obtained the IP via DHCP. I exactly dont remind, but In one window i have seen network status is active. it received/sents packets and bytes. In windows os we have to make a new internet connection to access the net,
on which we have to provide out user ID/PW created by the ISP. After providing the correct ID/PW we can login the net. But in Ubuntu what is the
procedure.
28-07-2007, 10:45 PM
procedure.
Your ISP authentication system is different kya? You don't login to ur con using the web-browser??
KDE on ArchLinux
28-07-2007, 10:54 PM
dig_boy_dig,dig !
I cannt got your point. I mean when we wish to connect to the net, ist we have to put the ID/pw provided by the BSNL, after sucessful loging the status shows that " Now you are connected to the net". After that we can brows any web site. But is the procedure in Ubunto to connect to the net.
28-07-2007, 11:01 PM
left this forum longback
ubuntu novice.
In Ubuntu,you have to use terminal with "sudo" prefixed for temp root/admin privilage to configure internet.first make it clear-do u have onboard lancard.secondly is ur connection configured from the modem/router,so that dataone is already available when in the system?
thirdly,is ur computer directly connects to the modem?
I use the rp-pppoe dialer in ubuntu/linux.the configuration steps are already mentioned in another thread of mine.
http://www.thinkdigit.com/forum/show...8&postcount=11
people using Broadband in Feisty Fawn....
and ubuntu india community site explains things as well.
http://www.ubuntu-in.org/wiki/Broadband_Howto
^ above one solves ur problem-I hope.
and eg for root access from terminal is like "sudo gedit /etc/X11/xorg.conf"
will open that file as root/admin who only can have the permission to edit that file and to save changes.
28-07-2007, 11:08 PM
dig_boy_dig,dig !
I have two lan card one is on board and other on PCI slot. My connection in Win Xp is in PCI lan port. Yes my connection is configure from the modem in
Win Xp from which I am writing this thread. Yes my computer is directly connect to the modem.
28-07-2007, 11:22 PM
so you got two lan cards?its worth knowing that you are not sharing anything with windows os!Ubuntu Linux just uses ur pc h/w resources the same way window$ does.
so what u want to do will be posted below as ur yet to try the links which i gave  ?.
I'll try explaining how to set up dataone on Debian/Ubuntu Linux if u got LAN card(mostly inbuilt) in ppp mode rather than using router's inbuilt dialer.it is risky using router's configuration via dialer as someone can administer ur router if u didnt reset ur router passwd.leave it apart,
First make sure ur LAN card is enable and is up. all below commands are to be ran in terminal(in menu Applications>Accessories>Terminal)
give ur user passwd when prompted and press enter.
also paste the output from terminal here, if i asks.
the output shud show ethx,where x is ur lan card(s) number.for eg:eth0,eth1 etc
for reference below is my output.
eth0 Link encap:Ethernet HWaddr 00:17:88:99:GE:AV
inet addr:192.168.1.2 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::214:85ff:fe98:bea2/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:16343 errors:0 dropped:0 overruns:0 frame:0
TX packets:13328 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:17254486 (16.4 MiB) TX bytes:2304662 (2.1 MiB)
Interrupt:20 Base address:0xa000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:34 errors:0 dropped:0 overruns:0 frame:0
TX packets:34 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1700 (1.6 KiB) TX bytes:1700 (1.6 KiB)
if u got "lo" and "ethx" there in the output
Lets see:
first open a terminal.type and enter below commands.
^^ this will go step by step setting ur internet.a blue screen based user interface is shown.u can select options OK,NO etc by using keyboard combinations ALT+TAB,enter etc.
at somewhere in last section,it will ask for always on connection-if u want only say yes.else say no.now after everything is over.go to ur terminal or ALT+F2 run dialog and enter :
will switch on dataone
and:
^ switches off.
U can make shortcuts for this in ur desktop or top panel that will be used to on or off.
that means u can connect using above commands.
29-07-2007, 10:07 AM
dig_boy_dig,dig !
[quote] praka123[quote]
Thanks prakash,
Today I tried as per your guidelines and also go through the link provided by you. after configuring the connection I can connect the net and now writing by this connection. But i cannot make the sort cut for
"on" and "off" for dataone. Also please please tell me that is it automatically start whenever i start my pc in ubunto? If it is what is the proceure for not starting the dataone automatically? Also we can see the connection status in Win Xp by clicking icon in Task Bar, In case ubuntu what is the procedure to see the status of connection?
Again thanks, At last I can connect the net with the help of the member specially parka123.
29-07-2007, 03:02 PM
I dont like broadband started at boot.so @ghosh if u ran pppoeconf,u'll be noticing that the blue ui asked u whether u wanted to start at bootup and u must say no.u can make two shortcuts on desktop or gnome-panel(taskbars).I''ll explain it.regarding icon on panel.yes it shows.u need to open synaptic and install gnome-netstatus-applet,also gnome got applets for showing thermal sensors o/ps for ur processor,mobo,hdd etc.that means a lot.
For adding shortcuts,download the two attached icons on this post and move them to directory /usr/share/pixmaps.u need to open nautilus file manager(same as win explorer) as admin privilage to move as ur local user is not permitted to write to the above directory.u can invoke nautilus fm as admin by below commands:
press alt+f2 to get a run dialog.in the run dialog paste the below commands with spaces intact and run.
^then copy the icons from ur /home/user/Desktop(most prolly) or wherever u downloaded them and move to dir /usr/share/pixmaps.
now to make shortcut on desktop or panel,right click on panel or dekstop and add new shortcut.their u have to give the name of the shortcut dsl-on and in command space give pon dsl-provider and similarly for dsl-poff and in command space give command poff.select the icons accordingly from dir /usr/share/pixmaps(the one i attached).
Now net-status applet can be added by right clik panel top or bottom and add "network monitor"-do this while ur internet connection is active.
there are lot of other tips like using opendns for faster name resolution etc etc.best of Luck and Linux will be tough for hardcore windows users as they expect linux to be the same as windows.but unix is different and u have to learn few new things and unlearn some windows specific.u need atleast 3 weeks to stand on ubuntu as a windows user.also read many a resources available on net and know the difference of unix style versus linux.for eg:no viruses,malwares,*.wares in UNIX-like systems and Linux.also dont search for software in internet unlike in windows.all available softwares(most!) are from synaptic manager in menu System>admin>synaptic.also make sure ur /etc/apt/sources.list seems as mine atleast as below.edit appropriately by gedit editor as sudo.make sure the first line for ur ubuntu cd remains there dont remove that line.u can edit as earlier by using run dialog as
gksudo gedit /etc/apt/sources.list
# # If you get GPG errors with this sources.list, locate the GPG key in this file
# # and run these commands (where KEY is replaced with that key)
# # gpg --keyserver hkp://subkeys.pgp.net --recv-keys KEY
# # gpg --export --armor KEY | sudo apt-key add -
#Ubuntu Security
deb http://archive.ubuntu.com/ubuntu/ feisty-security main restricted
deb-src http://archive.ubuntu.com/ubuntu/ feisty-security restricted main multiverse universe #Added by software-properties
deb http://archive.ubuntu.com/ubuntu/ feisty-security universe
deb http://archive.ubuntu.com/ubuntu/ feisty-security multiverse
# # Ubuntu supported packages
# # GPG key: 437D05B5
deb http://archive.ubuntu.com/ubuntu/ feisty main restricted
deb-src http://archive.ubuntu.com/ubuntu/ feisty restricted main multiverse universe #Added by software-properties
deb http://archive.ubuntu.com/ubuntu/ feisty-updates main restricted
deb-src http://archive.ubuntu.com/ubuntu/ feisty-updates restricted main multiverse universe #Added by software-properties
# # Ubuntu community supported packages
deb http://archive.ubuntu.com/ubuntu/ feisty universe multiverse
deb http://archive.ubuntu.com/ubuntu/ feisty-updates universe multiverse
# # Ubuntu backports project
deb http://archive.ubuntu.com/ubuntu/ feisty-backports main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty-backports main restricted universe multiverse #Added by software-properties
#### Proposed Multiverse ####
deb http://archive.ubuntu.com/ubuntu/ feisty-proposed main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty-proposed main restricted universe multiverse #Added by software-properties
#### Canonical Commercial ####
deb http://archive.canonical.com/ubuntu feisty-commercial main
deb http://medibuntu.sos-sts.com/repo/ feisty free non-free
#compiz-fusion
deb http://debs.vorian.org/ feisty extras
deb-src http://debs.vorian.org/ feisty extras
29-07-2007, 09:48 PM
dig_boy_dig,dig !
praka123
I gone through your reply. Now I will switch to ubunto and have to try the job. See you after experiment. Till then bye.
29-07-2007, 10:19 PM
it is Ubuntu not ubunto,  also Ubuntu means humanity to others in African.
do read the ethical benefits of FOSS(open source)  for eg:
http://gnu.org
http://fsf.org
and the Gnome panel with dsl-on and dsl-off shortcuts will look like this:
^note the network monitor showing bb active.
30-07-2007, 12:10 AM
dig_boy_dig,dig !
Sorry for spelling mistake. I have successfully added the sortcut as per your advice.But I find slightly different as described by you. Now I have another problem. Some pages are not open. i.e "indiatimes.com," fist page open very quickly, but whenever I try to other link of the page the page automatically closed. what is the problem. Another problem when i typed in user prompt
"gksudo gedit/etc/apt/sources.list" in the terminal it appears as
(gedit:11824): GnomeUI-WARNING **: While connecting to session manager:
Authentication Rejected, reason : None of the authentication protocols specified are supported and host-based authentication failed.
When I types in root this msg come outs.
(gksudo:11882): Gtk-WARNING **: cannot open display:
What's worng whith this . please explain.
30-07-2007, 12:14 AM
1.post the output of command "ifconfig" when internet is ON be posted here.
2.are u able to open the editor gedit with gksudo .. cmd?try running from "run" dialog-by pressing ALT+F2 and run again.
30-07-2007, 12:18 AM
dig_boy_dig,dig !
I made the two sortcut in the pannel successfully. But there is another problem. Some page I cannot open. i.e indiatimes.com, Ist page open nicely, whenever I try to open other link of that page the browser automatically closed. what is the wrong.
Also the code belw is not working :
gksudo gedit /etc/apt/sources.list (user prompt)
(gedit:12069): GnomeUI-WARNING **: While connecting to session manager:
gksudo gedit /etc/apt/sources.list ( root)
(gksudo:12108): Gtk-WARNING **: cannot open display:
Please explain.
Another how you make the screen shot and post it in the thread ?
30-07-2007, 01:18 AM
GaurishSharma.com
Now you connect to WWW then consider upgrading to 7.04
5.10 is way too old to use, its like using windows 98 in era of windows vista
30-07-2007, 03:36 AM
Yes.what @gary said is cent % correct.move to Ubuntu Feisty if bandwidth allows. so dont edit with my sources.list posted above.only remove the "#" before the entries except first two lines for ur CDrom sourced for ur Hoary Hedgehog(ubuntu version) which is very old
(gksudo:12108 ): Gtk-WARNING **: cannot open display:
Please explain.
for the last doubt research menus in Gnome for take screenshot.also by pressing printscreen key will take the screenshot.or u can use gimp too.
reg,ur query,it seems the terminal ur using cannot export the X credentials for root session.I'd like to see a screenshot of error.Also do u have X(Display) or did u tried from some tty's?those commands are meant to be tried from gnome-terminal inside gnome.
OK.if X(Display) is there.then do as following.open a terminal.then run below command :
^^ ^ then try the command gksudo...
if that fails,just post the output of :
also reg internet connxn problem-u have to select the o/p of ifconfig command from terminal and paste here.do copy and paste the output from terminal.
_______________________
btwn guys?c'mon ppl help too.Why do i feel am a single man army in OSS section  where do others gone?
30-07-2007, 09:18 AM
dig_boy_dig,dig !
I am is puzzle. What to do. I will try to solve the problem one by one. My 1st problem is web page problem. I paste here output of "ifconfig" :
$ ifconfig
eth0 Link encap:Ethernet HWaddr 00:08:A1:74:99:6F
inet6 addr: fe80::208:a1ff:fe74:996f/64 Scope:Link
RX packets:5444 errors:0 dropped:0 overruns:0 frame:0
TX packets:1938 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1534362 (1.4 MiB) TX bytes:233717 (228.2 KiB)
Interrupt:18 Base address:0xc000
RX packets:34924 errors:0 dropped:0 overruns:0 frame:0
TX packets:34924 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2621993 (2.5 MiB) TX bytes:2621993 (2.5 MiB)
ppp0 Link encap  oint-to-Point Protocol
inet addr:59.94.9.49 P-t-P:59.94.8.1 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1492 Metric:1
RX packets:98 errors:0 dropped:0 overruns:0 frame:0
TX packets:89 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:14437 (14.0 KiB) TX bytes:8055 (7.8 KiB)
after solving this problem. I post you the other problem.
30-07-2007, 01:08 PM
#19 (permalink)
ur ifconfig o/p looks OK.are ur router/modem is configured as dialer earlier.is the router firewall enabled?i am no expert with router configs.but as per the howto i have shown-there are pictures like below which shows that ur router needs to be configured as "bridged" mode in router.what is ur router model/name?
now post the output of :
^it will take some time.
30-07-2007, 08:30 PM
#20 (permalink)
dig_boy_dig,dig !
I dont know whether my router is configured as dialer or not. But the same
adsl modem is configured in Win Xp in the same PC where duel booting system as win xp and ubuntu. There is no model name in the router/modem
Only I got there DataOne written on the modem with Model No -WA3002-g1 and H/W Ver : A1. Also how I will invok the picture as shown by you.
30-07-2007, 09:53 PM
#21 (permalink)
u got a utstarcom modem.just login from 192.168.1.1 from browser with admin as user and passwd.check for the option bridged mode is enabled.I am no expert in configuring modem.btwn ur Ubuntu is tooo old.try upgrading to Ubuntu feisty
30-07-2007, 10:42 PM
#22 (permalink)
dig_boy_dig,dig !
Yes bridged mode is enable as per the screen appears..
I am unable paset the screen shot here. because I dont know how to do it. Also can you provide me the New Ubuntu version in CD format the cost and shipping charge I will bear. Because my bb is home plan 250. If I download ubuntu my condition will be alarming.
30-07-2007, 10:46 PM
#23 (permalink)
Just read through the whole thread once again.check ur browser settings set correctly(some proxy).printscreen press will give u the screenshot that u have to save.else look for an app in menu called "gimp">acquire>___
30-07-2007, 10:55 PM
#24 (permalink)
dig_boy_dig,dig !
Like Windows is there any antivirus programme to install in Ubuntu.
31-07-2007, 12:08 AM
#25 (permalink)
Linux got practically NO Viruses.only prototype viruses(or worms) does exists.but dont care them for the time.
http://linuxmafia.com/faq/Security/m...-scanning.html
AVs are there for Linux-for the use of scanning windows viruses.so no AV is needed.do read the links i gave.it helps.
One of the most common questions I hear new Linux users ask is "What program should I use for virus protection?" Many of them lose faith in me as a source of security information when I reply, "None." But you really don't need to fear malware on your new platform, thanks to the way Linux is built.
Savvy Windows users have to watch their virus checkers as closely as the head nurse in the ICU keeps an eye on patient monitors. Often, the buzz in the Windows security world is about which protection-for-profit firm was the first to discover and offer protection for the malware du jour -- or should I say malware de l'heure? The only thing better than having backed the winning Super Bowl team come Monday morning at the office coffeepot is having the virus checker you use be the one winning the malware sweepstakes that weekend.
If a rogue program finds a crack in your Windows armor, paying $200 per infection to have your machine scrubbed and sanitized by the local goon^H^H^H^H geek squad not only helps to reinforce the notion that you have to have malware protection, but that it has to be the right protection, too. The malware firms are aware of this, and all of their advertising plays upon the insecurity fears of Windows users and the paranoia that results. Chronic exposure and vulnerability to malware has conditioned Windows users to accept this security tax.
It's no wonder, then, that when Windows users are finally able to break their chains and experience freedom on a Linux desktop, they stare at me in disbelief when I tell them to lay that burden down. They are reluctant to stop totin' that load. They have come to expect to pay a toll for a modicum of security.
I try to explain that permissions on Linux make such tribute unnecessary. Without quibbling over the definitions of viruses and trojans, I tell them that neither can execute on your machine unless you explicitly give them permission to do so.
Permissions on Linux are universal. They cover three things you can do with files: read, write, and execute. Not only that, they come in three levels: for the root user, for the individual user who is signed in, and for the rest of the world. Typically, software that can impact the system as a whole requires root privileges to run.
Microsoft designed Windows to enable outsiders to execute software on your system. The company justifies that design by saying it enriches the user experience if a Web site can do "cool" things on your desktop. It should be clear by now that the only people being enriched by that design decision are those who make a buck providing additional security or repairing the damage to systems caused by it.
http://www.linux.com/articles/60208
thats why reading some articles helps ease the use and helps accustomed to the new OS:
http://linux.oneandoneis2.org/LNW.htm
31-07-2007, 08:16 AM
#27 (permalink)
dig_boy_dig,dig !
Prakash,
As per your advice I leaving the Antivirus topic aside. I will learn it later.
Another problem I found today while booting into ubuntu, I see somewhere in the screen somthing like "Temporary fail in name resolution."
About the command "gksudo","gedit" in the terminal or in run command.
it always give warning msg. "Cannot open display". Please give me solution.
Also I registered my name with Ubunto.org for supply of free CD of Ubuntu 7.04. Will they supply me the same as per the time frame they mentioned. Whether it will shiped from India or abort.
31-07-2007, 02:34 PM
#28 (permalink)
GaurishSharma.com
Prakash,
Also for supply of free CD of Ubuntu 7.04. Will they supply me the same as per the time frame they mentioned. Whether it will shiped from India or abort.
you just Wasted a disc
nearly all members here have ubuntu you could have asked us, even ubuntu was given in digit july dvd, it would been faster now the shipit service will take around one month.
Its ubuntu or ubunt o
31-07-2007, 04:01 PM
#29 (permalink)
I think most of his problem-solutions are described in this thread.for eg:terminal.
just read the thread and be ready with Linux OS.then try the soltns i gave.you need to read and use a little terminal to be proficient.
now regarding temp failure in name resoultion is because of ur DNS servers not working/(not efficient).just make sure ur /etc/resolv.conf entry exists.
OR else use opendns. http://opendns.com for furthur info.(i am using opendns in btwn)
31-07-2007, 10:55 PM
#30 (permalink)
dig_boy_dig,dig !
If I take screen shot and save it, but I dont know how to paste it here. hence I reduce the size of the file and attached herewith.
I did not find the o/p of ifconfig. please explain.
