Old 26-07-2007, 04:22 PM   #1 (permalink)
chahal63's Avatar
Smile no cursor help me!
i had installed fc7 and red hat linux 5 on my system which has
mobo - msi k8ngm2
1 gb ram
nvidia chipset
160 gb sata
amd athlon 64
problem is that both os just installed on my system finely but i didn't see my cursor my mouse is working properly but there is no cursor
also i changed my mouse but problem persist please help me
chahal63 is offline
Old 27-07-2007, 12:35 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: no cursor help me!
are u using a usb mouse?try plugging and unplugging for udevd to get mouse detected.another chance is wrong display size/driver set.may be u can show us ur /etc/X11/xorg.conf pasted in http://pastebin.ca or similar sites and link here.also post ur monitor model display resltn etc
if gpm is enabled this may interfer with X too.
you may check the gnome menu preferences>mouse>Pointers for some options.
if everything fails,use swcursor option in Section device in /etc/X11/xorg.conf part.
Option "SWcursor" "yes"
or
Option "HWcursor" "off"
^ may that help after a gdm restart
you may need a display driver for nvidia either open source "nv" or proprietory 3d driver from nvidia!
praka123 is offline
My Cursor is always busy! emailaatif786 QnA (read only) 3 19-04-2007 07:47 PM
Need tut:cursor with waving text tail Chetan1991 Tutorials 19 24-03-2007 05:56 PM
mouse cursor seems to disappear Ramakrishnan Peripherals 2 27-04-2006 12:07 AM
problem with cursor- help pls- urgent santu_29 Software Q&A 12 13-03-2006 11:44 PM
- by soumya
