I got an Asus M2nPV-VM mobo with AMD 64 x2 5600+ proccy. The motherboard drivers cd contains Linux drivers for Chipset, audio and VGA. I installed Fedora 7 in my pc and the problems for me are...
1) The mouse cursor wasnt showing up. Everything else of the mouse functions are working well. When I log in through text mode, and then go to GUI mode, the mouse cursor shows up. I installed Suse 10.2 and it is working well. But, sometimes, when I logout, it shows the same prob.
2) Desktop effects doesnt enable in both of them.
I figured out that the drivers werent installed correctly. I ran the drivers supplied with the mobo. The file runs and shows up that there are no precompiled kernel files and need to recompile. The bar goes to 100% and tells me that the kernel file wasnt installed. This happens with Chipset and audio drivers.
For VGA, it tells me that 'You are running X Server. Close the X Server and try again.'.
I dont have internet for my pc. Please help me how to install the drivers. My mobo has an nVidia 6150 GFX (onboard) and nForce 430 Chipset. Is there a way to update my comp without internet? I have downloaded the latest drivers from nVidia site.(If possible, please also suggest what drivers to use and provide the links so that I can check I have downloaded the latest drivers or not.) Both the os's are 32bit only. Please help me ASAP.
