Old 20-07-2007, 09:44 PM   #1 (permalink)
Console Junkie
aditya.shevade's Avatar
Default $PATH environment setting... help needed...
Hi
I installed gEDA suite from it's iso image.
All went perfectly well but it said in the end that I need to set my $PATH variable to xyz directory and some LD_LIBRARY_PATH to xyz.
How to do that... ?
Aditya
--- Console Junkie
aditya.shevade is offline
Old 20-07-2007, 09:55 PM   #2 (permalink)
I see right through you.
Sykora's Avatar
Default Re: $PATH environment setting... help needed...
At the command line,
$> PATH=xyz:$PATH
$> LD_LIBRARY_PATH=xyz:$LD_LIBRARY_PATH
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
Sykora is offline
Old 20-07-2007, 10:02 PM   #3 (permalink)
Console Junkie
thanks....
--- Console Junkie
Want help with Path of Neo debsuvra Gamerz 2 31-05-2007 10:36 AM
Help needed wit setting up a lan for a gaming event. fnatic@play Hardware Q&A 2 27-03-2006 09:39 PM
The Matrix: Path of Neo anilthomas26 Gamerz 8 03-10-2005 01:54 AM
The Matrix: Path of Neo tarey_g Gamerz 20 21-03-2005 07:09 PM
- by soumya
