Old 20-07-2007, 03:02 PM   #1 (permalink)
Default Problem installing Ubuntu 7.04/Mandriva 2007!!
Hi,
My system configuration is:
MoBo: MSI K8N-SLI Platinum
Proc: AMD Athlon64 4800+
GFX Card: XFX 6600GT PCIe
Monitor: Samsung SyncMaster 997DF (19" CRT)
The problem is that when I try to install Ubuntu 7.04 all I see is garbled screen during the installation. Hence I cannot install Ubuntu as I can't see anything on the monitor. I thought that this might be due to some hardware driver problem (incompatibility) and hence decided to install Mandriva 2007 Spring edition instead. Here, while I was able to install Mandriva correctly and during installation though I could choose my monitor and GFX card (shown as GF-GF7 series) I still ended up with garbled screen. I decided to boot through init level 3 (non-GUI) and install the latest NVIDIA drivers but here the driver was not able to find the kernel source package installed on the system. Mandrake doesn't even give choice, to keep the source packages, during installation (like SUSE).
What should I do to keep either of the Linux OS working?
monkey is offline
Old 23-07-2007, 08:16 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Smile Re: Problem installing Ubuntu 7.04/Mandriva 2007!!
try ubuntu.use http://ubuntuguide.org for nvidia display driver installation.for 2D,u can use "nv" driver for nvidia.procedure includes when u see those X fails(garbled...),press CTRL+ALT+F1 or F2..F6 to get a console terminal.there,try below command and choose "nv" or if that fails "vesa" as driver.
sudo dpkg-reconfigure xserver-xorg
another idea is if u can use a console editor nano,then go to /etc/X11/xorg.conf and edit Section "Device" driver as:
Section "Device"
        Identifier      "nVidia Corporation  [GeForce 6600 GT]"
        Driver          "nv"
        BusID           "PCI:1:0:0"
save and exit;try starting gdm.also use http://ubuntuguide.org reg nvidia proprietory(3D) driver installation later.(after u get a gui gnome)
praka123 is offline
Dataone on Mandriva Linux 2007 cyber_ral Open Source 1 06-07-2007 01:59 PM
Mandriva 2007 Questions Of A Novice caleb Open Source 8 10-12-2006 03:16 PM
MANDRIVA LINUX 2007 Instalation PROBLEM caleb Open Source 8 29-11-2006 06:22 AM
mandriva 2007 digitizen Open Source 4 20-09-2006 09:35 AM
problem installing ubuntu help!!! techmax Open Source 1 15-07-2006 01:17 PM
- by soumya
