Old 18-07-2007, 09:58 PM   #1 (permalink)
Default Display problem with linux
I recently installed fedora 7 given from DIGIT July 07.I have an AMD 3800+,1GB RAM,NVIDIA GeForce 6100 nForce 430 with Samsung syncmaster 740N TFT/LCD.There was no problem with the installation but after the reboot which is right after installation when I tried to boot into fedora it showed some errors and screen went completely white and the PC hung.I tried to log into single user mode and gave the command system-config-display, and saw the settings --- it recognised the syncmaster.I gave 800x600 and tried to reboot again ,this time the screen got garbled and hung.
I think the problem is no support for video driver.I tried the Ubuntu LiveCD - which also had a similar problem.
Is there no solution ? I do have internet, but I cant connect to the net in single user mode
Suhas is offline
Old 18-07-2007, 10:16 PM   #2 (permalink)
The Unknown's Avatar
Default Re: Display problem with linux
Suhas, i have posted this on Fedora Forums. I will tell u the soln. as soon as reply is recd.
KDE on ArchLinux
The Unknown is offline
Old 18-07-2007, 11:41 PM   #3 (permalink)
Cool and Calm
abhi_10_20's Avatar
not sure, but cud it b a problem with swap space allocated?....
how much space did u allocate for swap?
similar problem happnd wit me earlier with Fedora 3......
now i hav fedora 7 with 500MB swap....everything's well.......
When Roger's at play, opponents pray..!!!!! :twisted:
abhi_10_20 is offline
Old 20-07-2007, 01:01 AM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
check if ur nvidia 6100 chipset requires some restricted drivers to be installed. other than this one more cause can be selecting wrong resolution and refresh rate.
infra_red_dude is offline
Old 20-07-2007, 01:49 PM   #5 (permalink)
left this forum longback
praka123's Avatar
@OP:browse only as local user,NOT root.2ndly,U need to user "nv" driver or proprietory "nvidia" driver for getting Display.if fedora doesnot bundles both these drivers,u can edit /etc/X11/xorg.conf device section driver as "vesa".also afaik fedora got a display config utility called "system-config-display" which may work in TUI also.keep posting here.
praka123 is offline
Old 21-07-2007, 12:49 PM   #6 (permalink)
the swap I allocated is 1.8 GB, since I have 1GB RAM
Suhas is offline
Old 21-07-2007, 01:22 PM   #7 (permalink)
Burning Bright
anantkhaitan's Avatar
1.8 GB for Swap.. well its not too much but more than too much
..::Fedora ::.. Freedom + Infinity + Speech
Registered Linux User #447318
GNUger was here.... Grrr....
Maah! Blog
http://brightedges.blogspot.com/
anantkhaitan is offline
Old 21-07-2007, 05:33 PM   #8 (permalink)
Wire muncher!
of corz that is too much and wastage of space.... but surely thats not the cause of his problem.
Old 21-07-2007, 09:18 PM   #9 (permalink)
Swap need not be more than 3 times the computers RAM. i.e. if RAM=384 mb, then SWAP= 768 Mb
KDE on ArchLinux
Old 22-07-2007, 12:09 AM   #10 (permalink)
GaurishSharma.com
gary4gar's Avatar
Not necessary, i gave one 1 gb ram no swap, and there isn't any problem
gary4gar is offline
Old 22-07-2007, 12:22 PM   #11 (permalink)
praka123's Avatar
swap of 500MB is more than enough,dont go by those rules made for 2.4 series kernels and old.
praka123 is offline
Old 22-07-2007, 04:04 PM   #12 (permalink)
Swap is not recommended for high ram pcs. I find my swap usage to be 0% always!!!! I have 384 Mb RAM, i have allocated 768 Mb for Swap.
KDE on ArchLinux
Old 23-07-2007, 07:14 AM   #13 (permalink)
praka123's Avatar
@OP and all fedora users.use below guide.it is highly recommended.it explains @Original Post's Nvidia driver(Display) problem too.best of Lux
http://www.fedorafaq.org/
http://www.fedorafaq.org/#nvidia
Also GIYF ,
http://www.patheticcockroach.com/mpam4/index.php?p=36
http://www.google.co.in/search?q=fed...e+Search&meta=
praka123 is offline
Old 31-07-2007, 06:08 PM   #14 (permalink)
I found a solution...installed it on a virtual machine using VirtualBox.It is working fine and I can share with the host OS also very easily.Since I have enough RAM, it isn't even a bit slow.
Anyways, Thank you all for your suggestions.
Suhas is offline
Linux Mint Questions - reg video display... prasad_den Open Source 5 15-07-2007 01:15 PM
N72 - display problem ! nav33n Buying Advice 5 21-04-2007 05:39 PM
ubuntu linux - no display adit_sen Open Source 19 02-10-2005 02:21 PM
Restoring Display: SUSE Linux 9.1 mohanty1942 Open Source 8 25-08-2005 07:43 PM
Display Restore : SUSE Linux 9.1 mohanty1942 Open Source 1 19-08-2005 11:39 PM
- by soumya
