17-07-2007, 09:58 PM
HELP! HELP! HELP! I can't login!!!!!!
My HDD pwr connector was loose. So due to this, FS got a lot of errors. I fixed 'em using fsck. Now only root can login. My personal user account can't operate. The error message says:
GDM can't write to your home directory. This means you are either out of disk space............blah blah blah
What do i do?
KDE on ArchLinux
17-07-2007, 10:01 PM
"The Gentleman"
Re: HELP! HELP! HELP! I can't login!!!!!!
create a new user account and see whether u can loggin or not, though its sounds vague.
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
17-07-2007, 10:06 PM
No doesn't work.
KDE on ArchLinux
17-07-2007, 10:16 PM
Security freak
Location: 01100001 01110100 00100000 01101000 01101111 01101101 01100101 00100001
Is your /home on a seperate partition, or is it located on the root partition?
If it's on a seperate partition, then what is the output of:
"df -h | grep /home"
"ls -lh /home"
"grep /home /etc/fstab"
If it's located on the root partition, then what is the output of the first two commands listed above?
Linux Admin by profession. OpenBSD user by choice.
17-07-2007, 10:24 PM
I don't know it is on which partition coz Linux has united both my HDDs using s/w RAID.
The output of those commands is nothing except the 2nd one which shows the home directory.
KDE on ArchLinux
17-07-2007, 10:28 PM
Security freak
Ok...that means you don't have a seperate /home partition.
What is the output of:
"df -h"
"ls -lh /home"
Post the output, if you can. Thanks.
Edit: The first command's output will look like this:
user@Linux ~ $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/hda5 966M 609M 308M 67% /
udev 312M 23M 289M 8% /dev
/dev/hda6 244M 130M 101M 57% /var
/dev/hda7 3.8G 687M 3.0G 19% /var/tmp
/dev/hda8 3.8G 322M 3.3G 9% /tmp
/dev/hda9 19G 7.8G 11G 44% /usr
/dev/hda10 27G 1.3G 24G 5% /home
shm 312M 0 312M 0% /dev/shm
/dev/hda1 38M 5.0M 32M 14% /boot
And the second will look something like this:
user@Linux ~ $ ls -lh /home
total 24K
drwxr-xr-x 56 user users 4.0K Jul 17 11:47 user
drwx------ 2 root root 16K Dec 15 2006 lost+found
18-07-2007, 07:42 AM
left this forum longback
default remedy if the issue is not with disk space is to delete ~/.gconf/ entries.
18-07-2007, 02:13 PM
I have around 39 GB of total 45 GB free on my system.
@rocket:
[root@localhost ~]# df -h
/dev/mapper/VolGroup00-LogVol00
45G 4.0G 39G 10% /
/dev/hda1 99M 17M 78M 18% /boot
tmpfs 188M 0 188M 0% /dev/shm
The 2nd cmd returns nothing coz i deleted all user accounts and now i have only root.
@praka:
Deleted those.
UPDATE:
@praka if i create a user, i get the same err.... GDM one.
KDE on ArchLinux
18-07-2007, 02:21 PM
@Unknown:try to get the error message exactly.are u able to get upto gdm screen where u can enter ur username and passwd?also does gdm throws error like "ur gdm session existed less than 10seconds etc".provide the error messages what u see on the screen as possible.u can login to ur username with a failsafe session from gdm try options menu in gdm.
post/check ur /var/log/messages and /var/log/gdm/ directory for error messages.for this login as root.also u got a separate /boot dir?
U have given 45GB for / partn  ??
18-07-2007, 02:40 PM
Error MSG:
GDM could not open the home directory for writing. This means either u are out of disk space or.........
And partition was not setup by me. I made FC setup do it automatically. I hv 2 HDDs united using lvm2 and s/w RAID.
KDE on ArchLinux
18-07-2007, 04:34 PM
login as root.browse to gnome menu for user admin-"system-config-users"(remember i dont have fedora).there verify that username exists and /home/nil@@ exists.also verify groups username also exists.if this solves.else u can use usermod command to set groups.and home dir.lets check with gui tool(system-config-users)
also make sure in gdm menu>options>GNOME is set.
18-07-2007, 04:41 PM
it means your linux drive is full fire up this command through termina
fir in login manager window press (F1) it will open terminal now login and than fire up this command
cd var/cache/apt/archives/
now sudo rm -r *.deb
if problem is not related to low disk space than you may have changed your file access permission of any system file on your home directory.
Dhiraj Thakur
thakur.dheeraj(@)gmail.com
18-07-2007, 04:49 PM
no! problem not solved. still the same error.
@Desi-Tek,
i think u did not read my old posts. i have 39 GB free space!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!
KDE on ArchLinux
18-07-2007, 04:51 PM
@The Unknown are you able to login as root?
Dhiraj Thakur
18-07-2007, 04:52 PM
@desitek:he got a rpm system  fedora @unknown did u tried my suggestions?
18-07-2007, 04:54 PM
@Desi-Tek, i am now logged in as root.
@praka, i tried ur suggestions, i hv the same error msg.
KDE on ArchLinux
18-07-2007, 05:01 PM
well than create new user group and and new user in it than transfer your file to new user home directory than drop the previous user and remove its home directory
Dhiraj Thakur
18-07-2007, 05:03 PM
usermod is the command needs to be used.as i cannot see ur system setup,usernames etc,i cant give the exact command.even i dont know ur primary and secondary groups.
but as a guideline,u can look for below syntax(i uses debian so...)
u can refer "man usermod" to see options.
~#usermod -g urname -d /home/urhomedir
~#usermod -G dialout,cdrom,floppy,audio,dip,video,plugdev
^ just verify ur groups.
I think u need to read this before:
http://www.g-loaded.eu/2005/11/06/ma...-command-line/
18-07-2007, 05:28 PM
#19 (permalink)
Dhiraj Thakur
18-07-2007, 06:48 PM
#20 (permalink)
@unknown:make sure u can login using ur local user account in CLI .for that press CTRL+ALT+F1 to get a virtual terminal.try login with ur account(not root!).
check for .dmrc file exists in ur /home/user .
if that works,then ur problem will be a gui matter only.post reply.dont start formatting and reinstalling!
and did u played with permissions of folders inside "/" and may be /home/user as root
then we need to set default permission 755 and may be,edit /etc/gdm/gdm.conf.
also did u checked the messages on /var/log/syslog -referring to gdm
18-07-2007, 09:37 PM
#21 (permalink)
KDE on ArchLinux
18-07-2007, 10:08 PM
#22 (permalink)
Originally Posted by praka123
Kashtam  hmm
Kashtam??????  ???? What do u want to say?
KDE on ArchLinux
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Login Problem
fenil_4400 |
Software Q&A |
2 |
21-09-2006 04:17 PM |
root login
nishant_nms |
Open Source |
7 |
13-11-2005 01:40 PM |
php login script
bukaida |
QnA (read only) |
1 |
09-11-2005 12:33 AM |
Login Shortcut
saROMan |
QnA (read only) |
2 |
24-04-2005 08:54 PM |
Cannot login to rediff
Aseem Nasnodkar |
QnA (read only) |
7 |
23-09-2004 01:17 AM |
