I have already installed Wolfenstein:Enemy territory, but whenever I try to intall it's mod called True Combat: Elite, It gives me the following error:
Searching Return to Castle Wolfenstein: Enemy Territory....
dirname: missing operand
Try `dirname --help' for more information.
md5sum: /et.x86: No such file or directory
Return to Castle Wolfenstein: Enemy Territory found in /
[: 65: e612c922bec7d8f4d7a8dfbbea3dade3: unexpected operator
Installing in /
Seems like Return to Castle Wolfenstein: Enemy Territory was installed by another user.
You have to install True Combat: Elite as the same user who did install Return to Castle Wolfenstein: Enemy Territory.
I have installed both as the same user. Even if you don't have the solution for this, atleast tell me ho can I uninstall enemy territory completely from my system, so that i am able to do a fresh install.
Waiting for your replies guys. Please try and help.
