Old 15-07-2007, 11:41 PM   #1 (permalink)
Default linux audio driver instal help
hi friends,
i installed fedora core 4 in my system. but when ever i login a msg comes no volume elements or devices detected. i think it s because i din install sound card driver. im using realtek high definition audio with codec alc883.. i cant run any media files in my fedora. kindly pls help me. i searched much in the net but i cudn't find any drivers and im new to linux. i dont know much about linux and its commands.. kindly pls help
Manu Mahendran is offline
Old 16-07-2007, 08:17 AM   #2 (permalink)
I WANT MORE FPS!!
adithyagenius's Avatar
Default Re: linux audio driver instal help
Is your linux showing your soundcard to be ALC883 or you know for sure that its ALC883.
Realtek has drivers for Fedora Core 4 & 5. But don't use that. Instead update your OS. To update open terminal and type the commands.
su -
(enter root password)
yum update
Now restart your computer and see if audio is working. If not , change audio provider to ALSA instead of ALC883
E8500+Asus P5Q Pro, GTX280 OC, 4GB RAM+RAID0 2*WD 500GB, CM690+Corsair 650TX, Razer Diamondback+Goliathus Control Edition Omega, Microsoft Natural Ergonomic 4000, Dell E228WFP, X-Fi Titanium+T6060
adithyagenius is offline
Old 16-07-2007, 11:29 PM   #3 (permalink)
im already using alsa...
Manu Mahendran
Old 17-07-2007, 06:24 AM   #4 (permalink)
I WANT MORE FPS!!
How many sound providers do you have in the list? Is ALC883 there on the list? I had problem with ALC888 in fedora 6. It used to work only work as ALC883. But after updating it started working with ALC888 and ALSA too with 5.1
Did you try installing official drivers for fedora 4?? they provide source code and you need to ./configure and make. I found problems with fedora 5 and earlier versions. Why dont you upgrade?
Vista Audio Driver for DELL Gx 620 gunda_26 Software Q&A 2 02-05-2008 12:50 PM
audio hda bus driver???? roxisayshi Software Q&A 1 12-09-2007 08:39 PM
not able to instal linux!!!! Root2 Open Source 3 12-10-2006 02:09 PM
Audio Driver Required navneeth_snr QnA (read only) 4 01-03-2005 02:36 PM
- by soumya
