| Forum |
#1 (permalink) |
UbuntuUser
I am using two distros. 1) Zenwalk 2) Vector. Both of the distros use LILO as the default boot loader. But when I install any one of them over the other one, LILO boot menu does not appear. I am using different '/' partitions but same /home partitions and of course same /swap partition. I tried installing Vector over Zen, Zen over Vector. In both the cases, the latter distro is not booted, i.e. LILO menu does not appear. I then tried installing Zen w/o installing LILO and then I installed vector over it + LILO. In this case, LILO cannot detect Zen. I ran /sbin/lilo and I get Linux Linux GUI Linux CUI Linux hda2 if I use the first two methods of installation, but with the third method, the last option does not appear. Any guesses whats wrong??? Or should I uninstall LILO and install GRUB? Come on guys, 16 views and no replies. Where the hell is the Digit spirit of youll?? OK tell me how to uninstall LILO and install GRUB. This should be simple!!
Core 2 Quad Q6600 G0, XFX 650i ultra, XFX 8600GT 512MB, Seagate 320GB, Altec Lansing ATP3, 2x1GB 800MHz, 19" Viewsonic VA1912WB, LiteOn DVD burner, Logitech K/B, mouse, Amigo 500W PSU, Local Cabby. Last edited by cynosure; 11-07-2007 at 08:31 PM. Reason: Automerged Doublepost |
#2 (permalink) |
left this forum longback
I am no expert in LILO.but as what i can understand,u got vector's LILO installed.
You need to edit /etc/lilo.conf(not sure) and add the other distro's(Zenwalk?) entry. One thing to remember is u must be correct in showing the root "/" of each distro.already u got the entries for Vector both CUI(command ui) and GUI. Now go to Zenwalk's /etc/lilo.conf or Zenwalk's /boot/ directory to know the name of kernel and (ifany) initrd.then add the entries to vector linux LILO and save. Ur entry Linux hda2 seems to be of Zenwalk. A good guide is : http://home.att.net/~lilo-boot/lilohome.htm http://www.control-escape.com/linux/lilo-cfg.html
left this forum long back.Admin Can Delete this Account and posts Permanantly.Thank You Get GNU/Linux - http://getgnulinux.org |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to make Grub recognise Lilo or vice versa? | vaithy | Open Source | 2 | 19-02-2007 07:57 AM |
| ZenWalk Linux LILO COnfig. | ray|raven | Open Source | 5 | 21-09-2006 05:51 PM |
| boot order in lilo for mandrake | arijitraja | Software Q&A | 1 | 27-04-2006 01:05 PM |
| Animated LILO Boot screen | jitun | Open Source | 3 | 30-12-2005 05:21 PM |
| Help me to change from lilo to grub | mayneu | Tutorials | 2 | 12-03-2005 09:59 PM |
