Old 04-07-2007, 09:23 PM   #1 (permalink)
Dark Star's Avatar
Arrow Burning question? Urgent
Hey all
Just wanna ask is the Inbuilt Cd Dvd creator enuf for minimal burning ? Will the Optical disk be burnt correctly? Or should I use a software ? If so then tell installation meathod? and application too..
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 04-07-2007, 09:37 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: Burning question? Urgent
all the apps works perfectly in Gnome.for eg: I am happy with gnomebaker,brasero,graveman,nautilus cd burner(it lacks expert options) etc even someone more wise will be using k3b.but u need to download all kde/qt stuff if u want that in Ubuntu.
praka123 is offline
Old 04-07-2007, 09:43 PM   #3 (permalink)
Dark Star's Avatar
^^ Buddy is the default GNOME burning program sufficient
Old 04-07-2007, 09:45 PM   #4 (permalink)
praka123's Avatar
No.Nautilus CD burner only burns data cd's/dvd's afaik.
praka123 is offline
Old 04-07-2007, 09:52 PM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
Yes it burns your data just fine like XP's inbuilt does, or like Vista's for that matter. No issues, just try a re-writable disc and see the truth for yourself.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 04-07-2007, 10:58 PM   #6 (permalink)
Dark Star's Avatar
^^ A que.. which software to install then ? Also the Cd burnt thru Default can be used again if space is left or not
Old 05-07-2007, 07:13 AM   #7 (permalink)
Commander in Chief
There are 2 good ones you can try.
1. GnomeBaker
2. K3B
And yes, I guess the default supports multi-session but I don't see an option to enable/disable it. If the disc's nearly full, it locks it up, else it behaves like a multi-session disc. Pretty similar to XP at that.
Harsh J
www.harshj.com
Old 05-07-2007, 09:54 AM   #8 (permalink)
praka123's Avatar
even there are many writing softwares like gnometoaster,xcdroast etc.one app which is developed properly after gnomebaker is brasero.nice ui it got.
praka123 is offline
Burning DVD on CD ComputerUser QnA (read only) 11 26-05-2007 01:07 PM
Dvd burning speed question chesss QnA (read only) 5 21-03-2007 10:31 PM
burning DVD.....urgent help required din4204u QnA (read only) 2 01-10-2005 03:28 AM
burning of 9gb dvd myms QnA (read only) 6 23-09-2005 12:06 AM
