Old 04-07-2007, 06:55 PM   #1 (permalink)
Dark Star's Avatar
Default Splash Screen .. ? Help
Hi all,
Just downloaded a splash screen,., Its not the Boot Screen its the screen that appear after we enter user name and ass word .I downloaded it frm here now hot to do a replacement
http://www.gnome-look.org/content/sh...?content=61605
Peas Ds
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 04-07-2007, 07:26 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Splash Screen .. ? Help
Heh, you love customizing your PC to the core or what? Let it look like Linux for the OS's sake!
Anyway, here's what you ordered for
Install (If not present):
sudo apt-get install gnome-splashscreen-manager
Run (Through Alt+F2 or Terminal):
[Edit: Also found via System > Preferences > Splash Screen]
Click Install, choose the image file (PNG or JPG) and it must appear in the window thus. Click Activate, re-login to see it in effect.
One small tip:
sudo apt-get install gnome-art
System > Preferences > Gnome Art
That's gonna be your favorite tool hence.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 04-07-2007, 11:05 PM   #3 (permalink)
Dark Star's Avatar
Thanks get it .. Btw I like customization and increasing my knowledge for OS
How to change the background colour too? Black Splash with orange background looks bad.. SO plz tell me this 2
Old 04-07-2007, 11:25 PM   #4 (permalink)
Try System>Administration>Login Window.
sashijoseph is offline
GRUB splash screen, 2 of those? aditya.shevade Open Source 14 28-02-2007 10:54 PM
Ubuntu Live Cd Not Opening After Splash Screen ayushman9 Open Source 12 17-11-2006 02:52 PM
Norton Internet Security Splash Screen emailaatif786 Software Q&A 1 20-05-2006 11:28 AM
Splash screen using VB.Net bizzare_blue QnA (read only) 8 11-04-2006 05:24 AM
Change WIN XP's splash screen bbalegere Tutorials 7 12-02-2006 06:34 PM
