Old 30-06-2007, 09:23 PM   #1 (permalink)
UbuntuUser
cynosure's Avatar
Default k3b not burning.
Hi guys,
I have k3b installed on my PC. I have around 128MB RAM and use kde3.5.7.(I know )
The problem is that when I try to burn a 4.x GB DVD, the k3b window just keeps on showing "preparing files". It just wont burn DVDs. I have removed Windows so I cant use that too.
Can anybody tell me whats the problem? Is that something to do with the amount of space left in root directory cause I only have around 1GB of space left on '/'. My temp folder (partition) is different and has around 6GB of free space.
cynosure is offline
Old 30-06-2007, 09:50 PM   #2 (permalink)
18 Till I Die............
Default Re: k3b not burning.
burn it on the fly? Try cdrecord?
mehulved is offline
Old 30-06-2007, 09:55 PM   #3 (permalink)
left this forum longback
praka123's Avatar
with k3b,(ur in kde?) a terminal(konsole?) trace is difficult.if u got xterm terminal,run k3b from xterm and post here the terminal trace when the app hangs.
praka123 is offline
Old 01-07-2007, 06:23 AM   #4 (permalink)
1337 |)00|) \m/
kaustav_geek's Avatar
Couldn't this be the problem ? AFAIK, whenever you try to burn files and directories 'on the fly', without creating an image, any burning suite creates a temporary image and then burns it. So, in case the space is less, I think it won't burn...
Note: I don't know whether /temp is used or not. Maybe the .k3b folder under /home/[user] is used ?
cynosure, try creating an image before you burn and then try the burn. See if that works.
And, k3b/gnomebaker basically use a hacked/modded version of cdrecord. So, I don't think there would be much difference while using k3b or cdrecord. The former is safer IMHO.
My Blog : www.vatsuak.blogspot.com
My DA page : www.burningsilver.deviantart.com
OK..ok..... Ads are bad.. ;)
kaustav_geek is offline
Old 01-07-2007, 10:50 AM   #5 (permalink)
praka123's Avatar
cdrecord was out,wodim(fork) is inn(as with debian)
praka123 is offline
Old 01-07-2007, 11:00 AM   #6 (permalink)
UbuntuUser
cynosure's Avatar
I am so sorry guys. I got the solution.
Actually k3b was not saving image @ /home but at a different partition. And only root had access to that partition. I changed the permission to 777 and k3b is working all right!!!
cynosure is offline
Old 01-07-2007, 08:38 PM   #7 (permalink)
1337 |)00|) \m/
Yeah.... Seemed like it... k3b can't create it (or save) either because it just can't do so ( insufficient privileges ) or due to insufficient disk space.
Are you sure ? Well, in FC6 , cdrecord still works and gnomebaker uses a hacked version of cdrecord.... I'm sure.
Old 02-07-2007, 01:59 AM   #8 (permalink)
praka123's Avatar
yes.Debian made wodim first,ubuntu followed,fedora too.
wodim-1.1.6-1.fc7.i386.rpm ?reason is the author of cdrecord(Joerg schilling) changed its later version to cddl.
In the past, we, the Debian maintainers of cdrtools, had a good and
mutually cooperative relationship with J=F6rg Schilling. He even
commented on Debian bug reports, which is one of the best things an
upstream maintainer can do. Naturally, there were occasionally
disagreements, but this is normal.
Unfortunately Sun then developed the CDDL[1] and J=F6rg Schilling
released parts of recent versions of cdrtools under this license.
The CDDL is incompatible with the GPL. The FSF itself says that this
is the case as do people who helped draft the CDDL. One current and
one former Sun employee visited the annual Debian conference in Mexico
in 2006. Danese Cooper clearly stated there that the CDDL was
intentionally modelled on the MPL in order to make it GPL-
incompatible. For everyone who wants to hear this first-hand, we have
video from that talk available at [2].
http://lxer.com/module/newswire/view/68828/index.html
praka123 is offline
Burning a 800 MB CD smshinde QnA (read only) 11 27-07-2007 01:28 PM
Burning DVD on CD ComputerUser QnA (read only) 11 26-05-2007 01:07 PM
- Burning DVD to another DVD !! Dipen01 QnA (read only) 8 05-10-2006 04:34 PM
CD/DVD Burning SW src2206 Software Q&A 21 28-06-2006 09:35 AM
800 mb cd burning???? sirivishnu QnA (read only) 2 20-09-2005 09:56 AM
- by tv6952
- by soumya
