Old 27-06-2007, 06:57 PM   #1 (permalink)
D i s t i n c t l y Ahead
saurabh kakkar's Avatar
Angry how to rectify this....................?
hi
my friend just installed ubuntu 7.04 using alternate cd . he is having 98 on c: and xp on d: so we created a 5 gb partion and installed ubuntu we also installed grub now 98 is working fine but xp is giving error msg like :
<windows root>\sytem32\hal.dll
now what should we do so that 98 and xp work with ubuntu plz provide the
steps .
saurabh kakkar is offline
Old 27-06-2007, 08:31 PM   #2 (permalink)
18 Till I Die............
Default Re: how to rectify this....................?
It seems like a windows related problem. hal's dll seems to be corrupt. Try to repair the install or replace with a new hal.dll file.
mehulved is offline
Old 27-06-2007, 08:39 PM   #3 (permalink)
sachin_kothari's Avatar
it is indeed a windows error.
it seems that the 5gb partition lies between c and d drive.
i suppose any MVP will be able to help u out of it.
sachin_kothari is offline
Old 27-06-2007, 10:01 PM   #4 (permalink)
Open boot.ini in the C-drive and change the partition entry(for winXP) to an appropriate value.
for eg. change
multi(0)disk(0)rdisk(0)partition(3)\WINDOWS="Win XP SP2" fastdetect
to
multi(0)disk(0)rdisk(0)partition(4)\WINDOWS="Win XP SP2" fastdetect
sashijoseph is offline
Old 27-06-2007, 11:47 PM   #5 (permalink)
Smile Re: how to rectify this....................?
for eg. change
to
thanks for the help but we have rectified problem ourself by reparing boot file
using
bootcfg/rebuild
fixboot
command from windows cd
plz help me to rectify this prob. saurabh kakkar QnA (read only) 4 19-05-2007 07:45 PM
fedora core 6 error..plz rectify arunks Open Source 3 28-03-2007 09:26 PM
Wats the best way to rectify winrar error ? vinyas Software Q&A 5 03-10-2006 02:45 PM
monitor out of Hz. can't rectify ra_sriniketan QnA (read only) 1 29-07-2005 10:51 PM
- by soumya
