Old 24-06-2007, 08:17 PM   #1 (permalink)
GaurishSharma.com
gary4gar's Avatar
Unhappy My system Tempratures in ubuntu, are they normal??
gaurish@gaurish-desktop:~$ sensors
k8temp-pci-00c3
Adapter: PCI adapter
Core0 Temp:
+38°C
w83627thf-isa-0290
Adapter: ISA adapter
VCore: +1.15 V (min = +0.70 V, max = +1.87 V)
+12V: +11.98 V (min = +2.37 V, max = +5.23 V) ALARM
+3.3V: +3.33 V (min = +1.25 V, max = +1.07 V) ALARM
+5V: +5.07 V (min = +3.44 V, max = +0.77 V) ALARM
-12V: -11.78 V (min = -3.40 V, max = -14.91 V) ALARM
V5SB: +5.03 V (min = +1.16 V, max = +4.68 V) ALARM
VBat: +3.58 V (min = +3.38 V, max = +1.02 V) ALARM
fan1: 0 RPM (min = 4655 RPM, div = 2) ALARM
CPU Fan: 5357 RPM (min = 675000 RPM, div = 2) ALARM
fan3: 0 RPM (min = 6553 RPM, div = 2) ALARM
M/B Temp: +45°C (high = +16°C, hyst = +0°C) sensor = thermistor ALARM
CPU Temp: +39.0°C (high = +60°C, hyst = +55°C) sensor = thermistor
temp3: +66.0°C (high = +60°C, hyst = +55°C) sensor = thermistor ALARM
vid: +0.000 V (VRM Version 2.4)
alarms:
beep_enable:
Sound alarm enabled
there is ALARM in many of the indicators, is this info it correct?
gary4gar is offline
Old 24-06-2007, 08:32 PM   #2 (permalink)
El mooooo
eddie's Avatar
Default Re: My system Tempratures in ubuntu, are they normal??
Your system is running at 38°C. Is that too much or too less for you? Why are you worried?
Windows users shouldn't get to use the real computers. They know just enough to be dangerous.
eddie is offline
Old 24-06-2007, 11:35 PM   #3 (permalink)
GaurishSharma.com
gary4gar's Avatar
i am worried because seeing the word "ALARM " many times
and if any one point to a page where i can know what are these indicators like VCore,V5SB,VBat
gary4gar is offline
Old 25-06-2007, 01:07 AM   #4 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
The alarms are set wrong
kalpik is offline
Old 25-06-2007, 10:55 AM   #5 (permalink)
Anindya's Avatar
Plz tell me what r the temp range for all the parts inside the cpu? Also do give a software link which is reliable for all these. Thanks.
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 25-06-2007, 12:19 PM   #6 (permalink)
El mooooo
eddie's Avatar
Your ranges are set wrong. You can configure them in sensors.conf file.
eddie is offline
Old 25-06-2007, 02:01 PM   #7 (permalink)
GaurishSharma.com
gary4gar's Avatar
what will be the correct ranges???
a complete reference page is helpful
gary4gar is offline
Old 25-06-2007, 02:19 PM   #8 (permalink)
Commander in Chief
QwertyManiac's Avatar
I don't know of correct ranges, I guess thats mostly hardware dependent as long as they're fans.
But look at this:
That's a good example of your incorrect values.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 25-06-2007, 02:26 PM   #9 (permalink)
GaurishSharma.com
gary4gar's Avatar
But look at this:
yup i think the default values are wrong itself, i need to change them
anybody has a idea what paramaters i should use?
config
amd athlon 64 3000+
msi-k8mm-v(via k8m800 chipset)
gary4gar is offline
Old 25-06-2007, 02:33 PM   #10 (permalink)
left this forum longback
praka123's Avatar
did u apt-get install sensors-applet or hardware-monitor? I think they offers adjust alarm level etc.
praka123 is offline
Ubuntu System Requirements teen Open Source 11 27-07-2007 12:24 AM
Debian as a desktop system-A good alternative to Ubuntu praka123 Open Source 2 22-06-2007 01:15 PM
is this Normal? Raaza QnA (read only) 2 17-05-2007 05:54 PM
Are these temps normal??? varkey Hardware Q&A 6 11-11-2006 11:26 AM
Is this normal speed? vasulic QnA (read only) 15 11-08-2006 10:36 PM
- by soumya
