^^Here you go, but please replace
8) and
with : p, 8 ) and : D respectively. There are smilies in the txt below due to digit forum!!!
dmesg gives::
Linux version 2.6.18.5 (root@vector.linux.net) (gcc version 3.4.6) #2 SMP PREEMP T Sat Dec 9 19:01:25 MST 2006
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000e8000 - 00000000000ec000 (ACPI NVS)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 0000000007f00000 (usable)
BIOS-e820: 00000000fffc0000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
127MB LOWMEM available.
On node 0 totalpages: 32512
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 28416 pages, LIFO batch:7
DMI 2.3 present.
ACPI: RSDP (v000 COMPAQ ) @ 0x000e8010
ACPI: RSDT (v001 COMPAQ CARS6C31 0x00000001 0x00000000) @ 0x000e8080
ACPI: FADT (v001 COMPAQ CARS6C31 0x00000001 0x00000000) @ 0x000e80cc
ACPI: SSDT (v001 COMPAQ CARS6C3 0x00000001 MSFT 0x01000007) @ 0x000e8187
ACPI: DSDT (v001 COMPAQ DSDTTBL 0x00000001 MSFT 0x01000007) @ 0x00000000
ACPI: PM-Timer IO Port: 0xee08
Allocating PCI resources starting at 10000000 (gap: 07f00000:f80c0000)
Detected 996.798 MHz processor.
Built 1 zonelists. Total pages: 32512
Kernel command line: auto BOOT_IMAGE=linux ro root=305 hdc=ide-scsi
ide_setup: hdc=ide-scsi
Local APIC disabled by BIOS -- you can enable it with "lapic"
mapped APIC to ffffd000 (01109000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 512 (order: 9, 2048 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 123316k/130048k available (3139k kernel code, 6236k reserved, 1229k data , 296k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 1994.42 BogoMIPS (lpj=997210)
Security Framework v1.0.0 initialized
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0387f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: After vendor identify, caps: 0387f9ff 00000000 00000000 00000000 00000000 0 0000000 00000000
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 256K
CPU serial number disabled.
CPU: After all inits, caps: 0383f9ff 00000000 00000000 00000040 00000000 0000000 0 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Compat vDSO mapped to ffffe000.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
Freeing SMP alternatives: 16k freed
ACPI: Core revision 20060707
ACPI: setting ELCR to 0200 (from 0828)
CPU0: Intel Pentium III (Coppermine) stepping 06
SMP motherboard not detected.
Local APIC not detected. Using dummy APIC emulation.
Brought up 1 CPUs
migration_cost=0
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xfa134, last bus=1
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Interrupt Link [LNKA] (IRQs *3 4 5 6 7 10 11 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 10 11 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 10 11 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 10 *11 15)
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
ACPI: Assume root bridge [\_SB_.PCI0] bus is 0
Boot video device is 0000:00:01.0
PCI quirk: region ee00-ee7f claimed by ICH4 ACPI/GPIO/TCO
PCI quirk: region ee80-eebf claimed by ICH4 GPIO
PCI: Transparent bridge - 0000:00:1e.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
Linux Plug and Play Support v0.97 (c) Adam Belay
intel_rng: FWH not detected
SCSI subsystem initialized
usbcore: registered new driver usbfs
usbcore: registered new driver hub
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
PCI: Ignore bogus resource 6 [0:0] of 0000:00:01.0
PCI: Bridge: 0000:00:1e.0
IO window: 1000-1fff
MEM window: 40000000-401fffff
PREFETCH window: 10000000-100fffff
PCI: Setting latency timer of device 0000:00:1e.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 49152 bytes)
TCP bind hash table entries: 2048 (order: 2, 24576 bytes)
TCP: Hash tables configured (established 4096 bind 2048)
TCP reno registered
apm: BIOS not found.
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
SGI XFS with ACLs, security attributes, large block numbers, no debug enabled
SGI XFS Quota Management subsystem
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
ACPI: Invalid PBLK length [5]
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Real Time Clock Driver v1.12ac
Linux agpgart interface v0.101 (c) Dave Jones
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
loop: loaded (max 8 devices)
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ICH: IDE controller at PCI slot 0000:00:1f.1
ICH: chipset revision 2
ICH: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0x2020-0x2027, BIOS settings: hda
MA, hdb
io
ide1: BM-DMA at 0x2028-0x202f, BIOS settings: hdc
MA, hdd
MA
Probing IDE interface ide0...
hda: QUANTUM FIREBALLlct20 20, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdc: LITE-ON DVDRW LH-20A1P, ATAPI CD/DVD-ROM drive
hdd: SONY CD-RW CRX230EE, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
Probing IDE interface ide2...
Probing IDE interface ide3...
Probing IDE interface ide4...
Probing IDE interface ide5...
hda: max request size: 128KiB
hda: 39876480 sectors (20416 MB) w/418KiB Cache, CHS=39560/16/63, UDMA(66)
hda: cache flushes not supported
hda: hda1 hda2 < hda5 hda6 >
hdd: ATAPI 40X CD-ROM CD-R/RW drive, 1536kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
ide-floppy driver 0.99.newide
Loading Adaptec I2O RAID: Version 2.4 Build 5go
Detecting Adaptec I2O RAID controllers...
Adaptec aacraid driver (1.1-5[2409]-mh2)
scsi: <fdomain> Detection failed (no card)
NCR53c406a: no available ports found
sym53c416.c: Version 1.0.0-ac
qlogicfas: no cards were found, please specify I/O address and IRQ using iobase= and irq= optionsFailed initialization of WD-7000 SCSI card!
megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006)
megaraid: 2.20.4.9 (Release Date: Sun Jul 16 12:27:22 EST 2006)
megasas: 00.00.03.01 Sun May 14 22:49:52 PDT 2006
GDT-HA: Storage RAID Controller Driver. Version: 3.05
GDT-HA: Found 0 PCI Storage RAID Controllers
3ware Storage Controller device driver for Linux v1.26.02.001.
3ware 9000 Storage Controller device driver for Linux v2.26.02.007.
nsp32: loading...
ipr: IBM Power RAID SCSI Device Driver version: 2.1.3 (March 29, 2006)
libata version 2.00 loaded.
RocketRAID 3xxx SATA Controller driver v1.0 (060426)
st: Version 20050830, fixed bufsize 32768, s/g segs 256
usbmon: debugfs is not available
ohci_hcd: 2005 April 22 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11
PCI: setting IRQ 11 as level-triggered
ACPI: PCI Interrupt 0000:00:1f.2[D] -> Link [LNKD] -> GSI 11 (level, low) -> IRQ 11
PCI: Setting latency timer of device 0000:00:1f.2 to 64
uhci_hcd 0000:00:1f.2: UHCI Host Controller
uhci_hcd 0000:00:1f.2: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:1f.2: irq 11, io base 0x0000eec0
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
sl811: driver sl811-hcd, 19 May 2005
usb 1-1: new full speed USB device using uhci_hcd and address 2
usb 1-1: configuration #1 chosen from 1 choice
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 4 ports detected
usb 1-1.1: new full speed USB device using uhci_hcd and address 3
usb 1-1.1: configuration #2 chosen from 2 choices
usb 1-1.4: new low speed USB device using uhci_hcd and address 4
usb 1-1.4: configuration #1 chosen from 1 choice
usbcore: registered new driver hiddev
input: Chicony Compaq Internet Keyboard as /class/input/input0
input: USB HID v1.10 Keyboard [Chicony Compaq Internet Keyboard] on usb-0000:00: 1f.2-1.4
input: Chicony Compaq Internet Keyboard as /class/input/input1
input,hiddev96: USB HID v1.10 Device [Chicony Compaq Internet Keyboard] on usb-0 000:00:1f.2-1.4
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
PNP: No PS/2 controller found. Probing ports directly.
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
TCP bic registered
Initializing IPsec netlink socket
NET: Registered protocol family 17
Using IPI Shortcut mode
Time: tsc clocksource has been installed.
VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 296k freed
input: ImPS/2 Generic Wheel Mouse as /class/input/input2
Adding 624920k swap on /dev/hda6. Priority:-1 extents:1 across:624920k
i810_smbus 0000:00:01.0: i810/i815 i2c device found.
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 5
PCI: setting IRQ 5 as level-triggered
ACPI: PCI Interrupt 0000:00:1f.3[b] -> Link [LNKB] -> GSI 5 (level, low) -> IRQ 5
input: PC Speaker as /class/input/input3
eth0: register 'cdc_ether' at usb-0000:00:1f.2-1.1, CDC Ethernet Device, 00:08:5 c:58:e1:43
usbcore: registered new driver cdc_ether
ACPI: PCI Interrupt 0000:01:05.0[A] -> Link [LNKB] -> GSI 5 (level, low) -> IRQ 5
agpgart: Detected an Intel i810 E Chipset.
agpgart: AGP aperture is 64M @ 0x44000000
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
fuse init (API version 7.8)
fuse distribution version: 2.6.1
ide-scsi is deprecated for cd burning! Use ide-cd and give dev=/dev/hdX as devic e
scsi2 : SCSI host adapter emulation for IDE ATAPI devices
Vendor: LITE-ON Model: DVDRW LH-20A1P Rev: KL0A
Type: CD-ROM ANSI SCSI revision: 00
sr0: scsi-1 drive
sr 2:0:0:0: Attached scsi CD-ROM sr0
sr 2:0:0:0: Attached scsi generic sg0 type 5
powernow: This module only works with AMD K7 CPUs
ip_tables: (C) 2000-2006 Netfilter Core Team
ip_conntrack version 2.4 (1016 buckets, 8128 max) - 224 bytes per conntrack
cat /etc/fstab::
# /etc/fstab: static file system information.
# The following is an example. Please see fstab(5) for further details.
# Please refer to mount(1) for a complete description of mount options.
# Format:
# <file system> <mount point> <type> <options> <dump> <pass>
# dump(8) uses the <dump> field to determine which file systems need
# to be dumped. fsck(8) uses the <pass> column to determine which file
# systems need to be checked--the root file system should have a 1 in
# this field, other file systems a 2, and any file systems that should
# not be checked (such as MS-initrd/mnt or NFS file systems) a 0.
# The Linux partitions
/dev/hda5 / ext2 defaults 0 1
# Shared Windows/Linux partition
#/dev/hda1 /mnt/dos msdos umask=0 0 0
#/dev/hda1 /mnt/win vfat fmask=111,dmask=0,quiet,shortname=mixed,user 0 0
#/dev/hda1 /mnt/win ntfs umask=0 0 0
# Floppy disks
# The 'noauto' option indicates that the file system should not be mounted
# with 'mount -a' 'user' indicates that normal users are allowed to mount
# the file system.
/dev/fd0 /mnt/floppy auto defaults,noauto,user 0 0
#/dev/fd1 /mnt/floppy auto defaults,noauto,user 0 0
# If you have a ls-120 floppy drive, it could be on /dev/hda b c d etc.
# CDROM, CDWRITER, DVD
/dev/cdrom1 /mnt/cdrom1 iso9660 users,noauto,ro
/dev/cdrom /mnt/cdrom iso9660 users,noauto,ro
/dev/hdc /mnt/dvdram iso9660 users,noauto,ro
# NFS file systems:
#linux01.gwdg.de:/suse/6.3/i386.de /mnt/nfs nfs defaults 0 0
# proc file system:
proc /proc proc defaults 0 0
# Unix98 devpts filesystem:
none /dev/pts devpts gid=5,mode=666 0 0
# Shared memory filesystem:
tmpfs /dev/shm tmpfs defaults 0 0
# Basic USB filesystem
sysfs /sys sysfs defaults 0 0
# example of a VFAT USB pendrive
#/dev/sda1 /mnt/pendrive vfat fmask=111,dmask=0,noauto,user,quiet,shortname=mixe d 0 0
# Swap partitions
# The 'sw' option means auto activating with 'swapon -a'.
/dev/hda6 none swap sw 0 0
cat /etc/mtab::
/dev/hda5 / ext2 rw 0 0
usbfs /proc/bus/usb usbfs rw,devgid=10,devmode=0666 0 0
tmpfs /dev/shm tmpfs rw 0 0
lsmod::
Module Size Used by
xt_limit 3200 0
xt_pkttype 2688 0
ipt_REJECT 4864 1
xt_tcpudp 3968 4
ipt_LOG 6144 0
xt_state 2816 7
iptable_mangle 3200 0
iptable_nat 6660 0
iptable_filter 3328 1
ip_conntrack_irc 6128 0
ip_nat_ftp 3584 0
ip_nat 13868 2 iptable_nat,ip_nat_ftp
ip_conntrack_ftp 6640 1 ip_nat_ftp
ip_conntrack 37600 6 xt_state,iptable_nat,ip_conntrack_irc,ip_nat_ftp,i p_nat,ip_conntrack_ftp
ip_tables 12020 3 iptable_mangle,iptable_nat,iptable_filter
x_tables 11140 8 xt_limit,xt_pkttype,ipt_REJECT,xt_tcpudp,ipt_LOG,x t_state,iptable_nat,ip_tables
cpufreq_conservative 6536 0
cpufreq_ondemand 5900 0
cpufreq_performance 2816 0
cpufreq_powersave 2560 0
speedstep_lib 4740 0
freq_table 4512 0
sg 25500 0
ide_scsi 13572 0
fuse 37780 0
snd_seq_dummy 3716 0
snd_seq_oss 27392 0
snd_seq_midi_event 6528 1 snd_seq_oss
snd_seq 42320 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi_event
snd_seq_device 6924 3 snd_seq_dummy,snd_seq_oss,snd_seq
snd_pcm_oss 37280 0
snd_mixer_oss 14080 3 snd_pcm_oss
shpchp 29604 0
evdev 8320 0
intel_agp 19100 1
snd_maestro3 20900 2
snd_ac97_codec 80160 1 snd_maestro3
snd_ac97_bus 3072 1 snd_ac97_codec
snd_pcm 61828 3 snd_pcm_oss,snd_maestro3,snd_ac97_codec
snd_timer 18692 2 snd_seq,snd_pcm
snd_page_alloc 8072 1 snd_pcm
snd 39780 9 snd_seq_oss,snd_seq,snd_seq_device,snd_pcm_oss,snd _mixer_oss,snd_maestro3,snd_ac97_codec,snd_pcm,snd _timer
pcspkr 3456 0
cdc_ether 5632 0
i2c_i801 7436 0
usbnet 12424 1 cdc_ether
serio_raw 6148 0
i2c_i810 5764 0
i2c_algo_bit 8328 1 i2c_i810
i2c_core 16256 2 i2c_i801,i2c_algo_bit
soundcore 8032 3 snd
I tried something. When I typed::
mount /dev/cdrom1 or
mount/dev/cdrom at the terminal, both the time, my LiteOn DVD burner was mounted i.e Sony CD burner was not mounted any time. And when I typed
mount /dev/dvdram, it shew ::
mount: can't find /dev/dvdram in /etc/fstab or /etc/mtab.
Just for help
Come on guys, 39 views and 2 replies, what is this??? I need help here!!!!
