Old 22-06-2007, 08:01 PM   #1 (permalink)
"The Gentleman"
vish786's Avatar
Question bunch of problems related to grub
1.) i often install different distro's (sometimes upgrade the same distro to latest release)so grub is also installed in MBR... will the MBR be damaged since grub is installed many no. of times ??
2.) i already have few linux distro's installed booting with mandriva's grub... and now i'm formating my ubuntu 6.06 and installing ubuntu 7.04... but i dont want ubuntu(or any other linux OS) to install its own grub, how do i do that ?
3.) which is better, install grub in MBR or in some directory ?
4.) while installing any linux distro... how do i install the grub in /root directory instead of MBR... coz during installation of any linux OS i dont find any such option of installing grub in /root or any other directory ??
5) if i install the grub in some directory then what will MBR contain?...
6) ... and how does it boot from directory coz its MBR which directs the OS to start?
7.)how do i install grub in directory(and which directory is better for installing grub).... and i have 2 sata hdds... first one has windows and in second all linux distro's are installed and my linux partition begins from sdb7 partition.
this one is not related to grub.
8.) whenever i need to delete some directories... i usually use console (as root) for deleting some restricted files, how to do that in graphical mode as root user after logging in as common user in graphical mode(becoz root user cannot be used to enter in graphical mode at loggin screen of distro's)
hope u guys help me out
"The use of COBOL cripples the mind; its teaching should, therefore, be regarded as a criminal offense."
- Dijkstra
vish786 is offline
Old 22-06-2007, 08:47 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: bunch of problems related to grub
1. No its safe
3. MBR
2. Do no install any bootloader during the installation..
8. login as root in console... then start GUI by entering startx or init 5
Pathik is offline
Old 22-06-2007, 08:59 PM   #3 (permalink)
"The Gentleman"
vish786's Avatar
Post Re: bunch of problems related to grub
u did not understand re... distro will automatically install the grub. how do i avoid that.
but how to enter into console first and then GUI.... coz usually i directly get GUI login screen....
u mean to say i should change grub values to " 1 " in kernel line ??
- Dijkstra
vish786 is offline
Old 22-06-2007, 09:12 PM   #4 (permalink)
Burning Bright
anantkhaitan's Avatar
Check : MBR and GRUB
And for your grub problem with different distros :
1> Take a bakup of your /boot/grub/menu.lst
sudo cp /boot/grub/menu.lst <backup media>/menu.lst.bak
2> Then after you have installed a new distro append its grub configuration to your menu.lst.bak
3> Replace the original menu.lst
sudo cp <backup media>/menu.lst.bak /boot/grub/menu.lst
@ Problem no. 8
$ sudo nautilus
..::Fedora ::.. Freedom + Infinity + Speech
Registered Linux User #447318
GNUger was here.... Grrr....
Maah! Blog
http://brightedges.blogspot.com/
anantkhaitan is offline
Old 22-06-2007, 09:28 PM   #5 (permalink)
"The Gentleman"
vish786's Avatar
@anantkhaitan
thanks for that nautilus command
i know how to append entries of diff distros in menu.lst, that is not the problem here.
i'm asking how to avoid distro reinstalling or overwriting grub while installing new distro in my second question.
- Dijkstra
vish786 is offline
Old 22-06-2007, 09:29 PM   #6 (permalink)
left this forum longback
praka123's Avatar
Smile Re: bunch of problems related to grub
for problem no.8:
How to browse files/folders as root user in Nautilus
  • To install File Browser (Root)
gksudo gedit /usr/share/applications/Nautilus-root.desktop
    • Insert the following lines into the new file
[Desktop Entry]
Name=File Browser (Root)
Comment=Browse the filesystem with the file manager
Exec=gksudo "nautilus --browser %U"
Icon=file-manager
Terminal=false
Type=Application
Categories=Application;System;
  • To browse files/folders as root user in Nautilus
    • Applications -> System Tools -> File Browser (Root)
[edit]
How to install a "View in Terminal" Menu for Nautilus
http://ubuntuguide.org/wiki/Ubuntu:F...er_in_Nautilus
praka123 is offline
A bunch of hardware related questions topgear Hardware Q&A 7 22-06-2007 01:48 PM
Super Grub Disk for fixing your boot problems freebird Open Source 4 21-02-2007 08:24 PM
a bunch of n70 queries !!! tweety_bird_bunny Mobiles and Tablets 10 19-11-2006 02:44 PM
GRUB related problem saurabh.sauron Open Source 6 16-07-2006 11:33 PM
New graphic card and computer related problems overdose_14 Graphic cards 3 17-05-2006 12:13 PM
- by soumya
