Old 22-06-2007, 10:16 AM   #1 (permalink)
Dark Star's Avatar
Default Panel panorama..
Hey all
How o change the Main Menu button .. Like some theme provide .png icon for main menu I did not download as I don 't know where to paste them :9
Help me plz
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
Dark Star is offline
Old 22-06-2007, 01:39 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Wink Re: Panel panorama..
do u mean gnome menu button?ah..that u shud try at http://ubuntuforums.org
u can search /usr/share/applications/
wait! i found u need to change the icon "distributor-logo.svg" for ur theme to the icon u r gonna use,u need to put the icon named as distributor-logo.svg and put somewhere in /usr/share/icons/<theme name>
afaik .svg icon that needs 2 be!
praka123 is offline
Old 22-06-2007, 02:06 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Panel panorama..
A little correction to praka123's answer:
The 2 possible places your image (after being renamed to distributor-logo.png or .svg) needs to go to are:
/usr/share/icons/<themename>/24x24/places/
And/Or ..
/home/<name>/.icons/<themename>/24x24/places/
The 24x24 is the default icons size on Ubuntu, if you've changed it to 32x32 or 48x48 and so on, go to those respective folders.
And yeah, use this for easy moving:
gksudo nautilus
Harsh J
www.harshj.com
QwertyManiac is offline
Old 22-06-2007, 02:46 PM   #4 (permalink)
Burning Bright
anantkhaitan's Avatar
Umm.. my Main Menu icon :
/home/<username>/.icons/nuoveXT-1.6/24x24/apps/gnome-main-menu.png
..::Fedora ::.. Freedom + Infinity + Speech
Registered Linux User #447318
GNUger was here.... Grrr....
Maah! Blog
http://brightedges.blogspot.com/
anantkhaitan is offline
Old 22-06-2007, 03:26 PM   #5 (permalink)
Commander in Chief
It isn't the same with all Icon themes actually. For example, the Human theme doesn't have a /apps/gnome-main-menu.png. I guess it takes some browsing around to find out which looks like one.
Harsh J
www.harshj.com
Panel Help + More... Dark Star Open Source 1 19-06-2007 12:01 AM
front panel sound.. please help krishnenduk Hardware Q&A 2 17-02-2006 09:54 AM
Front Panel sound krishnenduk QnA (read only) 7 18-09-2005 05:57 PM
No front panel diagram mkpaul QnA (read only) 9 04-06-2005 12:45 PM
- by soumya
