21-06-2007, 08:12 AM
User Power help!Urgent
Hi all
I was about to installl aMSN skin but while comping it into /usr/share.... I got a message that i do not have powers to access the folder.. Even some folder that were made in windows are un deletable it say you do not have root poswer... How can I get that poswer help me pl z
Thanks
Me Myself and My Tux Blog :- http://tuxenclave.wordpress.com/
21-06-2007, 08:18 AM
Commander in Chief
Re: User Power help!Urgent
Um, what you need here is temporary root access.
Via terminal:
affix sudo to any command you wish to run, even cp or mv
Or for a root-session Nautilus [GUI]:
And then you can browse your folders as root.
Harsh J
www.harshj.com
21-06-2007, 09:37 AM
Is this teemporary root.. powers to my acounts  How to give permanent  Btw from where did you get alll that commands
Plz be a bit clear I downloaded that package and I can't copy it help me
Reason: Automerged Doublepost
21-06-2007, 10:24 AM
Commander in Chief
You wanna move a folder to /usr/share ?
sudo mv <extracted file/folder> /usr/share/amsn/skins
You don't need permanent root for all this, a simple sudo will do good
And if you dont want hassles, just hit Ctrl + H in Home directory, and copy the file/folder into .amsn/skins/ folder. No root or any other method required here.
Harsh J
www.harshj.com
21-06-2007, 10:27 AM
left this forum longback
In UNIX/Linux users do not login as root as root user.the only way is via "su" or "sudo"
though for files u can fix permissions as SUID.
if u r at doubt with any commands try the manpage from terminal as:
or for sudo
21-06-2007, 10:28 AM
Commander in Chief
And about commands, you learn them on the way.
Harsh J
www.harshj.com
21-06-2007, 10:32 AM
You can also use the switch user command.
su -c "type the command here'
and enter the root password and the command will be executed.
21-06-2007, 10:41 AM
Kinda confusing can any . Though I got that can't log in as Root but how to copy It I am not downloading I had already downloaded the package as .zip and now unzipped I need to copy the folder 2 place 1 in /usr that I can't and other in /home that I did.
Now how to copy the .
21-06-2007, 11:08 AM
Commander in Chief
Arg,
Here's an example: I wanna move a folder called ABC to /usr/ Ok?
qwerty@qwerty-desktop:~$ sudo mv ABC /usr/
Password:
And hit enter, you are done. [No output means the job went successful]
Harsh J
www.harshj.com
21-06-2007, 11:12 AM
Hey thanks  This worked thanks for example now I can move any file .. so to delete we should write del
21-06-2007, 11:17 AM
rmdir to delete an empty directory
rm to remove files and
rm -r to remove directory with contents
and read a few guides at www.tldp.org. You can learn the basic commands there
21-06-2007, 11:19 AM
Err. these are DOS Commands so it means I can get those from the command I learnt in 11
21-06-2007, 11:28 AM
Commander in Chief
No, shell commands all don't match DOS ones, its way far advanced than that
For a quick reference, you can try:
http://www.ss64.com/bash/
And for removal, if I wish to remove my ABC folder, then
rm (or sudo rm, if you need permissions) -R ABC
Or if ABC was a file,
Harsh J
www.harshj.com
21-06-2007, 05:27 PM
Burning Bright
Ok Its possible but strongly recommended NOT TO LOGIN AS ROOT
1> Open Terminal. Then provide root password by issuing following command ( AFAIK root password is not there by default in Ubuntu like system)
2> Then System > Administration > Login Window > Security. There Enable "Allow local system administrator login"
3> Do not login as root
..::Fedora ::.. Freedom + Infinity + Speech
Registered Linux User #447318
GNUger was here.... Grrr....
Maah! Blog
http://brightedges.blogspot.com/
21-06-2007, 07:40 PM
El mooooo
Shouldn't we recommend gksudo to newbies? I mean he just needed to copy a folder to the location and he could have done that by using `gksudo nautilus`? What do you guys say? Or am I thinking on wrong lines?
Windows users shouldn't get to use the real computers. They know just enough to be dangerous.
21-06-2007, 07:46 PM
Burning Bright
Yeah thats what I do..
Maah! Blog
21-06-2007, 07:53 PM
Commander in Chief
I suggested him that one, he didn't take it, so I told the harder way and he liked it I guess  Terminal ftw!
Harsh J
www.harshj.com
21-06-2007, 07:58 PM
#19 (permalink)
El mooooo
Ah, I see now
21-06-2007, 08:09 PM
#20 (permalink)
Haha I did both and working fine L  Thanks to all of you  Btw 1 'st 1 was way better .. Lets try this 1 too
21-06-2007, 10:58 PM
#21 (permalink)
the thing u just understood was called file permission system in UNIX-like Operating systems.this is the reason why u simply cant access some directories,files.
and that itself prevents Viruses,spywares to be able to run on Linux.so no need for anti-virus,anti-spyware,anti-anything<add tag>
Differences between operating systems
Unix-like and otherwise POSIX-compliant systems, including Linux-based systems and Mac OS X (through version 10.3), have a simple system for managing individual file permissions. POSIX also specifies a system of access control lists, but it is only implemented by certain file systems and operating systems.
DOS variants (including the Microsoft products MS-DOS, Windows 95, Windows 98, and Windows Me) do not have permissions. There is a "read-only" attribute that can be set or unset on a file by any user or program.
Microsoft Windows NT and its derivatives (including Windows 2000 and Windows XP), as well as VMS and OpenVMS use access control lists (ACLs) to administer a more complex and varied set of permissions.
Classic Mac OSes are similar to DOS variants and DOS based Windows: they do not support permissions, but only a "Protected" file attribute.
Mac OS X, beginning with version 10.4 ("Tiger"), supports both the use of complex access control lists (ACLs) and the traditional POSIX-compliant Unix-like simple system for managing individual file permissions. It also still supports the Mac OS Classic's "Protected" attribute.
http://en.wikipedia.org/wiki/File_sy...rating_systems
read:
http://en.wikipedia.org/wiki/File_system_permissions
http://tldp.org is a nice site for Understanding different Linux and GNU software basics and they got good Howtos.
LINUX NEWBIE ADMINISTRATOR GUIDE
www.linuxnewbieguide.org
www.ubuntuvideo.com/ -video guide
22-06-2007, 06:47 AM
#22 (permalink)
Thanks a ton for the link
22-06-2007, 08:51 AM
#23 (permalink)
I already told him to vist tldp.org.. Its a great place to start
