Old 20-06-2007, 12:29 PM   #1 (permalink)
!FREEWARES!
Akshay's Avatar
Default Multimedia issues in Ubuntu 7.04
Problem wit playing media files in Ubuntu 7.04
I recently installed Ubuntu 7.04. I copied quicktime4linux.tar.bz2 from one of d Digit CD/DVD. I want to install it but I m not getting ne rite solution. Diff. sites have diff. things to say n somehow none of d media files r wrkg. Ubuntu always wants something new... libdvd package or gcc or something or d odr.
Isnt thr an easier way out like a setup file in windows? I basically want to play mp3, vob, avi, mpeg, etc. files...
I tried d repository thing, downloaded kaffeine as well but again I cant "untar" n install it. Again if I m not mistaken, for running kaffeine some odr package needs to b downloaded... So how do I go abt it..
PS: Tried searching but didnt find a solution at thinkdigit.
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 20-06-2007, 12:35 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Multimedia issues in Ubuntu 7.04
Hmmm,
Run this following in the terminal and you wont get another chance to complain on lack of multimedia on Ubuntu ever:
sudo apt-get install ubuntu-restricted-extras libxine-extracodecs gstreamer0.10-plugins-base gstreamer0.10-plugins-good gstreamer0.10-plugins-bad gstreamer0.10-pitfdll
After this, Totem will play most formats, and so will Rhythmbox.
Alternatively, run:
sudo apt-get install vlc vlc-plugin-*
This will install VLC player and you won't have any worries playing any kind of media.
And finally, remember to use Applications > Add/Remove Programs to get all your required apps the easy way.
Note: Methods above require a full internet access.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 20-06-2007, 02:06 PM   #3 (permalink)
!FREEWARES!
Akshay's Avatar
Thnx Qwerty... Tryin it out...
MBP 13.3";
Akshay is offline
Old 20-06-2007, 03:12 PM   #4 (permalink)
Resident Fanatic
Manshahia's Avatar
Is there any media player by which we can organise our songs easily...
Manshahia is offline
Old 20-06-2007, 03:24 PM   #5 (permalink)
GaurishSharma.com
gary4gar's Avatar
Amorok
gary4gar is offline
Old 20-06-2007, 03:38 PM   #6 (permalink)
Burning Bright
anantkhaitan's Avatar
Amarok is too good but Rhythmbox is also not bad for organizing song files
..::Fedora ::.. Freedom + Infinity + Speech
Registered Linux User #447318
GNUger was here.... Grrr....
Maah! Blog
http://brightedges.blogspot.com/
anantkhaitan is offline
Old 20-06-2007, 04:05 PM   #7 (permalink)
Commander in Chief
Amarok's library system is the best right now out there, but you might find its playlist system and interface a bit complicated, unless you have media buttons on your keyboard or a remote perhaps.
Harsh J
www.harshj.com
Old 20-06-2007, 05:21 PM   #8 (permalink)
!FREEWARES!
Akshay's Avatar
@qwerty
Whn I enter -
I get dis error -
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Couldn't find package ubuntu-restricted-extras
MBP 13.3";
Akshay is offline
Old 20-06-2007, 08:00 PM   #9 (permalink)
left this forum longback
praka123's Avatar
Smile Re: Multimedia issues in Ubuntu 7.04
you need to set ur /etc/apt/sources.list a good one.try http://ubuntuguide.org
btwn dont try source packages from DIGIT CD/DVD,they are doing this for "name" sake.unlike in windows,Linux got available packages list listed nicely in SYnaptic manager(in menu>System>administration).dont get fooled by the source packages(.gz,.tar.gz,.bz2 etc).instead use apt-get or synaptic to do for u install softwares.
It seems so many people are fooled by DIGIT CD sources.
U can read why this is wrong way for Linux starters @ http://www.thinkdigit.com/forum/show...72&postcount=4
Dont try those source given from digit.its just illogical for eg;how it'll be if u get those .dll files,diffrnt config things etc wholesale to ur hand instead of installshield setup or simply "setup.exe"-the same thing in linux/unix are those gzipped(.gz) or bzipped(.bz2) source files;for eg:ur xmms source!.
So the thing is there are very good package managers which can fetch you and install software without searching internet like in windows.for eg: Debian or Ubuntu have apt and dpkg doing a wonderful job.for redhat/fedora .rpm is there,yum is there etc.
So never try those outdated source and if possible any source packages,get ur package manager works for you!
for eg:in GNOME menu after Applications and Places,there is another menu called System which contains administration menu>in which there is synaptic manager.give ur local user password when prompted.
Do read below article very informative for Windows Users too:
http://linux.oneandoneis2.org/LNW.htm
U can edit /etc/apt/sources.list as follows once in GNOME:
first get run dialog:
press ALT+F2.
inside enter below commands and press enter:
gksudo gedit /etc/apt/sources.list
just get ur entries looks similar to the one below or from http://ubuntuguide.org
do not remove the ubuntu cd entry.
# # If you get GPG errors with this sources.list, locate the GPG key in this file
# # and run these commands (where KEY is replaced with that key)
# # gpg --keyserver hkp://subkeys.pgp.net --recv-keys KEY
# # gpg --export --armor KEY | sudo apt-key add -
#Ubuntu Security
deb http://archive.ubuntu.com/ubuntu/ feisty-security main restricted
deb-src http://archive.ubuntu.com/ubuntu/ feisty-security main restricted
deb http://archive.ubuntu.com/ubuntu/ feisty-security universe
deb-src http://archive.ubuntu.com/ubuntu/ feisty-security universe
deb http://archive.ubuntu.com/ubuntu/ feisty-security multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty-security multiverse
# # Ubuntu supported packages
# # GPG key: 437D05B5
deb http://archive.ubuntu.com/ubuntu/ feisty main restricted
deb-src http://archive.ubuntu.com/ubuntu/ feisty main restricted
deb http://archive.ubuntu.com/ubuntu/ feisty-updates main restricted
deb-src http://archive.ubuntu.com/ubuntu/ feisty-updates main restricted
# # Ubuntu community supported packages
deb http://archive.ubuntu.com/ubuntu/ feisty universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty universe multiverse
deb http://archive.ubuntu.com/ubuntu/ feisty-updates universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty-updates universe multiverse
# # Ubuntu backports project
deb http://archive.ubuntu.com/ubuntu/ feisty-backports main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty-backports main restricted universe multiverse
#### Proposed Multiverse ####
deb http://archive.ubuntu.com/ubuntu/ feisty-proposed main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty-proposed main restricted universe multiverse
#### Canonical Commercial ####
deb http://archive.canonical.com/ubuntu feisty-commercial main
deb http://medibuntu.sos-sts.com/repo/ feisty free non-free
praka123 is offline
Old 20-06-2007, 10:00 PM   #10 (permalink)
!FREEWARES!
Akshay's Avatar
@praka
Thnx 4 ur help. I tried d steps mentioned by u but I m getting this error now -
gstreamer0.10-plugins-base is already the newest version.
gstreamer0.10-plugins-good is already the newest version.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
gstreamer0.10-plugins-bad: Depends: libgsm1 (>= 1.0.10) but it is not installable
Depends: libmpcdec3 but it is not installable
Depends: libswfdec0.3 (>= 0.3.6) but it is not going to be installed
libxine-extracodecs: Depends: libxine1-ffmpeg but it is not going to be installed
ubuntu-restricted-extras: Depends: gstreamer0.10-plugins-ugly but it is not going to be installed
Depends: sun-java6-plugin but it is not going to be installed
E: Broken packages
I tried foll. commands as well -
sudo apt-get install libdvdread3
sudo /usr/share/doc/libdvdread3/install-css.sh
sudo apt-get install totem-xine
sudo apt-get install libdvdcss2
But now Totem player says "Internal data flow error" for evry file I try to open
MBP 13.3";
Akshay is offline
Old 20-06-2007, 10:29 PM   #11 (permalink)
praka123's Avatar
hmm.after editing ur sources.list,u need to do "apt-get update".did u done this
else
it shud be with ur /etc/apt/sources.list.can u attach ur /etc/apt/sources.list somewhere.
libdvdread3,sun-java6-plugin all are installed via apt in my Ubuntu Feisty.though some packages are may be.
praka123 is offline
Old 21-06-2007, 10:34 AM   #12 (permalink)
vignesh's Avatar
Do any of you get sound while playing quicktime files in vlc ?
vignesh is offline
Old 21-06-2007, 11:11 AM   #13 (permalink)
Commander in Chief
I do sometimes and sometimes not.
Harsh J
www.harshj.com
Old 21-06-2007, 11:21 AM   #14 (permalink)
vignesh's Avatar
Yeah.. especially the trailers on the magazine dvd`s.. I don`t get sound at all..
vignesh is offline
Old 21-06-2007, 05:31 PM   #15 (permalink)
Burning Bright
I never had any issues with quicktime files in Totem.. What I do is
$ sudo yum install gstreamer*
Maah! Blog
Old 21-06-2007, 10:54 PM   #16 (permalink)
!FREEWARES!
Akshay's Avatar
My sources.list -
#Ubuntu Security
# deb http://in.archive.ubuntu.com/ubuntu/ feisty-backports main restricted universe multiverse
# deb-src http://in.archive.ubuntu.com/ubuntu/ feisty-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu feisty-security main restricted
deb http://security.ubuntu.com/ubuntu feisty-security universe
deb http://security.ubuntu.com/ubuntu feisty-security multiverse
I entered d command -
sudo apt-get update
n den thru totem player downloaded GStreamer thing. Now everythng is wrkg fine.... Thnx all.
PS: I m planning to format my comp. So can I take a backup of these codecs so dat I dont hav to download dem again???
MBP 13.3";
Akshay is offline
Old 21-06-2007, 11:07 PM   #17 (permalink)
praka123's Avatar
u can try "aptoncd" google for that!
praka123 is offline
Old 21-06-2007, 11:10 PM   #18 (permalink)
Commander in Chief
You can take a backup of the /var/cache/apt/ folder
Harsh J
www.harshj.com
Old 22-06-2007, 01:46 AM   #19 (permalink)
18 Till I Die............
apt-on-cd will be a much better idea. It will create an ISO file of your /var/cache/apt/archive folder. When you insert the disk, you will be asked to add it to your repositories and can install packages from it.
mehulved is offline
Old 22-06-2007, 11:42 AM   #20 (permalink)
!FREEWARES!
Akshay's Avatar
@mehul, praka
Tried Apton CD - I cud easily take backup of all d packages. It is easy to use n convinient... Thnx 4 ur help.
MBP 13.3";
Akshay is offline
Enabling Multimedia in Ubuntu catchjaga Open Source 1 22-12-2006 12:29 AM
Multimedia codecs for Ubuntu.Offline. ray|raven Open Source 21 17-12-2006 08:01 PM
Mouse issues on Ubuntu teen Open Source 11 09-06-2006 04:12 PM
Multimedia shivi4 QnA (read only) 1 01-05-2006 11:31 AM
want to do something in multimedia? dhawald QnA (read only) 3 14-11-2004 11:57 AM
- by soumya
