As u know in Unix-like systems,normal users are void of permission to mess with areas where they are not allowed.so we use "sudo" or "su" to gain permission hoping ur the admin of ur system.
isnt the feisty installer asks where to mount ur partns.it may be mounted there at /media/sda* directories.
anyways,
for mounting ntfs as read only is what u can do without ntfs-3g support.
I suppose u want read-write support with ntfs.so make sure u have a good /etc/apt/sources.list
# # If you get GPG errors with this sources.list, locate the GPG key in this file
# # and run these commands (where KEY is replaced with that key)
# # gpg --keyserver hkp://subkeys.pgp.net --recv-keys KEY
# # gpg --export --armor KEY | sudo apt-key add -
#Ubuntu Security
deb http://archive.ubuntu.com/ubuntu/ feisty-security main restricted
deb-src http://archive.ubuntu.com/ubuntu/ feisty-security main restricted
deb http://archive.ubuntu.com/ubuntu/ feisty-security universe
deb-src http://archive.ubuntu.com/ubuntu/ feisty-security universe
deb http://archive.ubuntu.com/ubuntu/ feisty-security multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty-security multiverse
# # Ubuntu supported packages
# # GPG key: 437D05B5
deb http://archive.ubuntu.com/ubuntu/ feisty main restricted
deb-src http://archive.ubuntu.com/ubuntu/ feisty main restricted
deb http://archive.ubuntu.com/ubuntu/ feisty-updates main restricted
deb-src http://archive.ubuntu.com/ubuntu/ feisty-updates main restricted
# # Ubuntu community supported packages
deb http://archive.ubuntu.com/ubuntu/ feisty universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty universe multiverse
deb http://archive.ubuntu.com/ubuntu/ feisty-updates universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty-updates universe multiverse
# # Ubuntu backports project
deb http://archive.ubuntu.com/ubuntu/ feisty-backports main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty-backports main restricted universe multiverse
#### Proposed Multiverse ####
deb http://archive.ubuntu.com/ubuntu/ feisty-proposed main restricted universe multiverse
deb-src http://archive.ubuntu.com/ubuntu/ feisty-proposed main restricted universe multiverse
#### Canonical Commercial ####
deb http://archive.canonical.com/ubuntu feisty-commercial main
deb http://medibuntu.sos-sts.com/repo/ feisty free non-free
^^ make sure u have enabled repositories.my feisty sources.list that is.
for more info on adding repositories:
http://ubuntuguide.org/wiki/Ubuntu:F...a_repositories
if u want to edit that file(/etc/apt/sources.list) use below command if u dont know the cli editor's way:
press ALT+F2 to get run dialog.enter below commands and press enter to get the file edited:
gksudo gedit /etc/apt/sources.list
do an "
" or use menu System>administration>synaptic manager-press reload.
then do :
~$ sudo apt-get install ntfs-3g
install it or use synaptic package manager to install it.
then edit ur /etc/fstab (hoping it is not mounted earlier)
from RUN dialog as earlier:
gksudo gedit /etc/fstab
if u find any entries with /dev/sda1 or /dev/sda6 before itself,just put a hash"#" infront of the line and save.then add below entries and save,exit:
/dev/sda1 /media/sda1 ntfs-3g silent,umask=0,locale=en_US.UTF-8 0 0
/dev/sda6 /media/sda6 ntfs-3g silent,umask=0,locale=en_US.UTF-8 0 0
make sure to make directories in /media if already not there :
:~$ sudo mkdir /media/sda1
:~$ sudo mkdir /media/sda6
mount again:
neglect the UUID entry system.dont worry
