Old 13-06-2007, 12:08 AM   #1 (permalink)
Om Ma Ni Pä Me Hum
phuchungbhutia's Avatar
Exclamation grub missing help!!
i had susi hdc5 on top of xp hdc1 then i installed slax hdc7. first the grub vanished n lilo came which meant no xp at all then on checkin for lilo.conf it was missin. i made conf file from the man help. but now i dont hav lilo also. but i hav my xp back. no susi or slax. please tell me how to get back grub and add all three in its menu list. any sw. help pl
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
phuchungbhutia is offline
Old 13-06-2007, 02:13 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Smile Re: grub missing help!!
explain in good english else no one cares to have a look
if u cant access any Linux on hdd,boot from a livecd,manually mount ur slackware partn.chroot into it.run "grub-install /dev/hdx" where hdx depends on ur hdd being sata or pata,find it with fdisk -l cmd.
I prefer GRUB to LILO and it seems GRUB got the future too.although suse uses lilo(u can install grub in suse too using yast).there is only one boot menu manager be there.
I'll explain in detail:
Warning:I hope u dont have made separate /boot partn in slackware else mount the /boot device(/dev/hdxx) to the mounted slack partns /boot directory.
boot a livecd(knoppix? etc) open a terminal as root and mount ur slack partn in it as rw.
~#mount /dev/hdx  /mnt
now "chroot"(change root) into ur slackware partn(find it from ur linux partns or fdisk -l)
~#chroot /mnt /bin/bash
now if ur grub is available there,
~#grub-install  /dev/hdx
if grub is completely lost,try setting grub manually.post here or refer "info grub" if grub-doc pkg is installed for this.
u can edit in slackware /boot/grub/menu.lst last a new line to add suse to it.for the syntax refer man grub and for suse kernel names etc refer suse lilo.conf
praka123 is offline
Vista and GRUB saurabh.sauron Open Source 2 14-02-2007 08:52 PM
recover the grub of fc 4. jimit_jan Open Source 6 30-10-2005 10:18 PM
GRUB champ_rock Open Source 1 07-10-2005 10:16 AM
GRUB zerohourkill Open Source 28 28-04-2005 10:26 PM
Grub bernie Open Source 8 17-11-2004 12:00 PM
- by soumya
